Old 01-14-2013, 05:50 PM   #1
pmellick85
Member#: 319418
2005 sti
wrb
Default first data logs pulled..opinions?
so i just got my ap the other day and pulled some logs today. the first 2 are 3rd gear pull and the last 3 are 4th gear pulls. i see that i have some knock. should i be worried. im still new and trying to learn what all the numbers mean so bear with me. im running stage 1 93 oct map using 93 oct. 05 sti no other mods but ap. thanks.
https://docs.google.com/spreadsheet/...jByMDV6Z1ZvX2c
https://docs.google.com/spreadsheet/...WI1ZGhJN0duMHc
https://docs.google.com/spreadsheet/...3g3S3FkclFpRVE
https://docs.google.com/spreadsheet/...1NWU29faXN2ZEE
https://docs.google.com/spreadsheet/...UhpTVo3dlE3UEE
pmellick85 is offline   Reply With Quote
Old 01-15-2013, 09:48 AM   #2
Cobb Tuning
Member#: 4803
The -1.4 fine knock learning is not a concern, but the feedback knock correction in the later logs at high load/higher RPM is potentially concerning. It may be that the 93 map is a little too aggressive for your local fuel quality, assuming there are no mechanical issues at play here. I would go ahead and reflash the stage 1 91 ACN map, which is the most conservative map. Drive through about a full tank of gas without reflashing any maps or resetting the ECU. Then take a look at your A/F Learning 1 A,B,C,D values. These should each generally be within about +/- 5%. Any one or more well outside of that could indicate a mechanical fueling issue. If that checks out after that period of time, then get some additional WOT logs on the 91 ACN map. During that period, also go through your maintenance items - spark plugs, fuel filter, air filter, etc. and take care of anything that has been neglected (or if you bought the car used - take care of items where you do not know the history of the maintenance).
Bill
Old 01-15-2013, 08:54 PM   #3
pmellick85
Member#: 319418
2005 sti
wrb
Ok thanks ill try that this weekend. I don't drive the car daily so it wont be driven till then. Would an etune help with the feedback knock?
Old 01-16-2013, 11:50 AM   #4
Cobb Tuning
Member#: 4803
Any custom tune from a reliable tuner would be able to tune for poorer than average fuel quality or car-to-car variances. But, before getting a custom tune, you want to make sure there is nothing mechanically wrong with the car.
Bill
Old 02-02-2013, 02:42 PM   #5
BoxoB
Member#: 344269
Default Data Log Question
Don't mean to hi-jack this thread but can't start my own yet...
Can someone take a look at this Data Log for me. Stock 2.0L 4th Gear
3280 +8.6 3.3 50 60 00 rich +16.5 46.2 +15.7 103 247.50 3.3
3261 +9.0 3.4 60 60 00 rich +15.7 47.2 +15.5 104 286.00 3.4
3350 +10.0 3.5 82 60 00 rich +14.7 52.7 +14.9 104 335.00 3.5
3363 +11.3 3.5 96 70 00 rich +12.3 56.5 +14.0 104 350.00 3.5
3418 +12.3 3.5 103 80 00 rich +10.4 60.7 +14.0 104 475.00 3.6
3450 +13.7 3.7 103 90 00 rich +10.5 66.5 +14.0 104 475.00 3.7
3527 +14.3 3.7 103 90 00 rich +10.6 67.7 +14.0 104 475.00 3.7
3542 +14.5 3.7 103 90 00 rich +10.2 69.4 +14.0 104 475.00 3.7
3588 +14.5 3.7 103 90 00 rich +10.1 70.4 +14.0 104 475.00 3.7
3599 +14.5 3.8 103 90 00 rich +10.1 70.6 +14.0 103 475.00 3.8
3745 +14.3 3.7 103 90 00 rich +10.8 70.8 +14.0 103 475.00 3.7
3716 +14.3 3.7 103 90 00 rich +11.0 72.5 +14.1 103 475.00 3.8
3724 +14.3 3.7 103 90 00 rich +11.9 72.6 +14.0 103 475.00 3.8
3831 +14.3 3.8 103 90 00 rich +11.8 73.2 +14.4 103 475.00 3.8
3835 +14.3 3.8 103 90 00 rich +12.6 73.3 +14.7 103 475.00 3.8
3871 +14.1 3.8 103 90 00 rich +12.9 73.8 +15.5 103 475.00 3.8
3921 +14.1 3.8 103 90 00 rich +13.2 75.7 +16.0 103 475.00 3.8
3987 +14.1 3.8 103 90 00 rich +13.5 75.4 +15.8 103 475.00 3.8
4050 +14.3 3.8 103 90 00 rich +13.7 76.9 +16.5 103 475.00 3.8
4055 +13.7 3.9 103 90 00 rich +13.4 77.6 +16.5 103 475.00 3.8
4095 +13.9 3.8 103 90 00 rich +13.4 76.7 +16.6 103 475.00 3.9
4125 +13.9 3.8 103 90 00 rich +13.4 77.7 +16.8 103 475.00 3.9
4177 +13.7 3.9 103 90 00 rich +13.6 78.6 +17.1 103 475.00 3.9
4214 +13.5 3.9 103 90 00 rich +13.8 78.9 +17.2 103 475.00 4.0
4312 +13.7 3.9 103 90 00 rich +13.8 79.6 +17.3 103 475.00 3.9
4357 +13.9 3.9 103 90 00 rich +13.8 81.6 +17.3 103 475.00 3.9
4363 +13.7 3.9 103 90 00 rich +13.5 81.7 +17.3 103 475.00 4.0
4444 +13.9 4.0 103 90 00 rich +13.4 81.7 +17.3 103 475.00 4.0
4456 +13.9 4.0 103 90 00 rich +13.4 83.8 +17.5 103 475.00 4.0
4492 +14.1 3.9 103 90 00 rich +13.8 84.0 +17.4 103 475.00 4.0
4486 +13.9 4.0 103 90 00 rich +14.0 85.3 +17.3 103 475.00 4.0
4610 +14.1 4.0 103 90 00 rich +14.0 86.6 +17.9 102 475.00 4.0
4610 +13.9 4.0 103 90 00 rich +14.3 86.5 +18.0 102 475.00 4.0
4610 +13.9 4.0 103 90 00 rich +14.5 86.9 +18.5 102 475.00 4.0
4728 +13.9 4.0 103 90 00 rich +15.0 86.1 +18.7 102 475.00 4.0
4803 +13.9 4.0 103 90 00 rich +14.9 87.8 +19.1 102 475.00 4.0
4728 +13.9 4.0 103 90 00 rich +15.3 88.5 +19.2 102 475.00 4.0
4816 +14.1 4.1 103 90 00 rich +15.0 90.3 +19.2 101 475.00 4.0
4916 +13.9 4.1 103 90 00 rich +15.4 90.3 +19.6 100 475.00 4.0
4938 +14.3 4.1 103 90 00 rich +16.4 90.2 +19.5 100 475.00 4.1
4916 +14.1 4.1 103 90 00 rich +16.7 90.4 +19.6 100 475.00 4.1
5005 +13.9 4.1 103 90 00 rich +17.5 91.3 +20.0 100 400.00 4.1
4990 +14.1 4.1 103 90 00 rich +16.7 93.6 +20.3 100 400.00 4.1
5089 +13.7 4.1 103 90 00 rich +17.8 92.3 +20.5 100 400.00 4.1
5005 +13.7 4.1 103 90 00 rich +18.5 91.1 +20.1 100 400.00 4.1
5167 +13.9 4.1 103 90 00 rich +18.6 92.7 +20.3 100 400.00 4.1
5096 +13.5 4.1 103 90 00 rich +19.0 93.8 +20.8 100 400.00 4.1
5249 +13.5 4.1 103 90 00 rich +19.5 94.2 +21.0 100 400.00 4.1
5151 +13.5 4.1 103 90 00 rich +19.4 91.9 +21.0 99 400.00 4.1
5274 +13.3 4.1 103 90 00 rich +19.6 92.2 +21.0 99 400.00 4.1
5224 +13.5 4.1 103 90 00 rich +19.5 94.5 +21.0 99 400.00 4.2
5420 +13.5 4.1 103 90 00 rich +19.5 91.6 +21.0 99 400.00 4.2
5324 +13.3 4.1 103 90 00 rich +19.6 94.7 +21.0 99 400.00 4.2
5367 +13.1 4.1 103 90 00 rich +19.6 93.7 +21.0 99 350.00 4.2
5473 +13.1 4.2 103 80 00 rich +20.2 94.6 +21.0 99 350.00 4.2
5385 +12.7 4.2 103 80 00 rich +20.4 91.8 +21.0 99 350.00 4.2
5592 +12.3 4.2 103 80 00 rich +20.4 93.9 +21.0 99 350.00 4.1
5640 +12.7 4.2 103 80 00 rich +21.3 95.0 +21.0 99 350.00 4.2
5546 +12.3 4.2 103 80 00 rich +21.7 91.8 +21.0 99 350.00 4.2
5592 +12.1 4.1 103 80 00 rich +21.8 92.6 +21.0 99 350.00 4.1
5678 +11.9 4.2 103 80 00 rich +21.8 92.5 +21.0 99 350.00 4.2
5583 +11.7 4.2 103 80 00 rich +21.4 92.4 +21.0 99 350.00 4.2
5698 +11.7 4.2 103 80 00 rich +21.6 92.7 +21.0 99 350.00 4.1
5640 +11.3 4.1 103 70 00 rich +21.9 91.6 +21.0 99 350.00 4.2
5707 +11.5 4.2 103 70 00 rich +21.6 93.0 +21.0 99 350.00 4.1
5757 +11.3 4.1 103 70 00 rich +22.4 93.5 +21.0 99 350.00 4.2
5747 +11.3 4.2 103 70 00 rich +22.0 92.5 +21.0 99 350.00 4.2
5727 +11.3 4.2 103 70 00 rich +22.1 93.8 +21.2 99 350.00 4.2
5757 +11.5 4.2 103 80 00 rich +22.0 95.3 +21.3 99 350.00 4.2
5827 +11.3 4.2 103 70 00 rich +22.2 95.3 +21.4 99 350.00 4.2
5878 +11.5 4.2 103 70 00 rich +22.5 97.0 +21.5 99 350.00 4.2
5847 +11.5 4.2 103 70 00 rich +22.2 96.7 +21.6 99 350.00 4.2
5941 +11.0 4.2 103 70 00 rich +22.2 96.1 +21.6 99 350.00 4.2
5963 +11.0 4.2 103 70 00 rich +22.4 95.9 +21.7 99 350.00 4.2
5973 +11.3 4.2 103 70 00 rich +22.1 96.3 +21.7 99 350.00 4.2
6071 +11.3 4.2 103 70 00 rich +22.8 98.2 +22.0 99 350.00 4.2
6038 +11.5 4.2 103 70 00 rich +22.6 98.8 +22.0 99 350.00 4.2
6016 +11.3 4.2 103 70 00 rich +22.8 ---.- +22.0 99 350.00 4.2
6082 +11.3 4.2 103 70 00 rich +22.6 97.5 +22.0 99 350.00 4.2
Saw I maxed out my injector and got scared. What would be the best way to take out some fuel? Since i'm rich all the way thru should i scale it back? Using the MAF? or changing the CC in Parameters?
BoxoB is offline   Reply With Quote
Old 02-02-2013, 07:41 PM   #6
Andrewxxcarlson
Member#: 316415
2006 WRX
Try uploading the log file here in google documents to help us better search through the data.
Old 02-02-2013, 10:02 PM   #7
BoxoB
Member#: 344269
Code:
3097  +4.9 3.1  32  40    00   rich +19.4   32.8 +18.4 101   200.00 3.1
 3118  +6.8 3.2  41  50    00   rich +17.9   37.3 +16.0 102   218.00 3.3
 3159  +8.0 3.3  52  50    00   rich +16.9   41.5 +16.0 103   258.00 3.3
 3267  +9.0 3.3  67  60    00   rich +15.8   46.5 +15.5 104   296.50 3.4
 3220 +10.2 3.4  79  70    00   rich +15.1   51.2 +14.9 104   335.00 3.4
 3330 +11.0 3.4  98  70    00   rich +13.7   54.4 +14.4 104   350.00 3.5
 3316 +11.9 3.5 103  70    00   rich +12.9   57.9 +14.0 104   475.00 3.5
 3384 +13.3 3.6 103  80    00   rich +11.6   63.9 +14.0 104   475.00 3.6
 3447 +13.5 3.6 103  90    00   rich +11.2   64.8 +14.0 104   475.00 3.7
 3523 +13.7 3.6 103  90    00   rich +11.4   64.7 +14.0 103   475.00 3.7
 3561 +13.7 3.7 103  90    00   rich +10.9   67.1 +14.0 103   475.00 3.7
 3615 +13.7 3.7 103  90    00   rich +11.2   67.6 +14.0 103   475.00 3.7
 3716 +13.7 3.7 103  90    00   rich +11.6   68.1 +14.0 103   475.00 3.7
 3724 +13.5 3.7 103  90    00   rich +11.9   69.0 +14.0 103   475.00 3.7
 3783 +13.7 3.7 103  90    00   rich +12.5   70.9 +14.6 103   475.00 3.7
 3822 +13.5 3.8 103  90    00   rich +12.7   70.6 +14.8 103   475.00 3.7
 3912 +13.7 3.8 103  90    00   rich +13.5   72.9 +15.2 103   475.00 3.8
 3963 +13.3 3.8 103  90    00   rich +13.9   72.3 +15.3 103   475.00 3.7
 3987 +13.5 3.8 103  90    00   rich +14.5   72.9 +16.1 103   475.00 3.8
 4050 +13.3 3.8 103  90    00   rich +14.6   72.8 +15.8 103   475.00 3.8
 4115 +13.1 3.8 103  80    00   rich +14.1   74.1 +16.3 103   475.00 3.8
 4203 +13.1 3.8 103  80    00   rich +14.1   75.1 +16.4 103   475.00 3.8
 4208 +13.1 3.9 103  80    00   rich +14.1   75.4 +16.6 103   475.00 3.8
 4257 +13.1 3.8 103  80    00   rich +13.8   76.1 +17.0 103   475.00 3.9
 4334 +12.9 3.9 103  80    00   rich +13.8   76.2 +17.0 102   475.00 3.9
 4363 +13.1 3.9 103  80    00   rich +13.7   77.2 +17.0 102   475.00 3.9
 4345 +13.3 3.9 103  90    00   rich +13.5   79.4 +17.0 102   475.00 3.9
 4438 +13.3 3.9 103  90    00   rich +13.9   78.9 +17.0 102   475.00 3.9
 4510 +13.1 3.9 103  90    00   rich +13.8   80.4 +17.0 102   475.00 3.9
 4450 +13.3 3.9 103  90    00   rich +14.1   81.9 +17.5 102   475.00 3.9
 4541 +13.3 4.0 103  90    00   rich +14.3   81.2 +17.2 102   475.00 4.0
 4597 +13.3 4.0 102  90    00   rich +14.4   83.9 +18.5 102   475.00 4.0
 4782 +13.1 4.0 103  90    00   rich +14.4   84.2 +19.0 102   475.00 4.0
 4803 +13.3 4.0 103  90    00   rich +14.8   86.4 +19.3 101   475.00 4.0
 4859 +13.5 4.0 103  90    00   rich +14.7   87.5 +19.4 102   475.00 4.0
 4803 +13.3 4.0 103  90    00   rich +15.1   85.6 +19.1 101   475.00 4.0
 4938 +13.5 4.0 103  90    00   rich +16.0   85.8 +19.6 100   475.00 4.0
 4816 +13.7 4.0 103  90    00   rich +16.8   88.7 +19.5 100   475.00 4.1
 5005 +13.7 4.1 103  90    00   rich +17.5   88.1 +19.7 100   400.00 4.0
 5005 +13.5 4.1 102  90    00   rich +17.6   88.7 +20.2 100   400.00 4.0
 5035 +12.9 4.0 102  80    00   rich +17.5   86.2 +20.3 100   400.00 4.1
 5065 +12.5 4.1 103  80    00   rich +17.4   85.4 +20.5  99   400.00 4.0
 5208 +12.7 4.1 103  80    00   rich +18.9   89.2 +20.9  99   400.00 4.1
 5216 +12.7 4.1 103  80    00   rich +19.3   88.1 +20.8  99   400.00 4.1
 5104 +12.5 4.0 103  80    00   rich +19.4   86.5 +20.9  99   400.00 4.1
 5316 +12.5 4.1 103  80    00   rich +19.5   88.8 +21.0  99   400.00 4.1
 5367 +12.7 4.1 102  80    00   rich +19.4   89.8 +21.0  99   400.00 4.1
 5359 +12.7 4.1 103  80    00   rich +19.6   88.9 +21.0  99   400.00 4.1
 5333 +12.5 4.1 103  80    00   rich +20.4   89.0 +21.0  99   400.00 4.1
 5509 +12.3 4.1 103  80    00   rich +20.2   89.2 +21.0  99   350.00 4.2
 5393 +12.1 4.1 103  80    00   rich +21.3   88.9 +21.0  99   350.00 4.1
 5527 +11.3 4.1 103  70    00   rich +21.5   87.4 +21.0  99   400.00 4.1
 5464 +11.3 4.1 102  70    00   rich +21.9   87.8 +21.0  99   350.00 4.1
 5473 +11.7 4.1 103  80    00   rich +21.5   88.5 +21.0  99   350.00 4.1
 5574 +11.0 4.1 103  70    00   rich +22.1   88.3 +21.0  99   350.00 4.1
 5564 +11.3 4.1 103  70    00   rich +22.1   89.9 +21.0  99   350.00 4.1
 5555 +11.3 4.1 103  70    00   rich +22.0   88.3 +21.0  99   350.00 4.1
 5630 +11.0 4.1 103  70    00   rich +22.2   89.3 +21.0  99   350.00 4.1
 5668 +11.0 4.1 103  70    00   rich +22.3   90.1 +21.0  99   350.00 4.1
 5688 +11.0 4.1 103  70    00   rich +22.1   90.2 +21.0  99   350.00 4.1
 5659 +11.0 4.1 103  70    00   rich +22.7   89.3 +21.0  99   350.00 4.1
 5698 +11.0 4.1 103  70    00   rich +22.5   90.5 +21.0  99   350.00 4.1
 5899 +11.0 4.1 103  70    00   rich +22.8   90.9 +21.0  99   350.00 4.2
 5889 +11.3 4.1 103  70    00   rich +23.1   94.1 +21.0  99   350.00 4.1
 5984 +10.8 4.2 103  70    00   rich +22.4   91.0 +21.0  99   350.00 4.1
 5797 +10.6 4.1 103  70    00   rich +22.3   91.0 +21.4  99   350.00 4.2
 5963 +10.8 4.1 103  70    00   rich +23.0   92.6 +21.5  99   350.00 4.1
 5889 +10.8 4.2 103  70    00   rich +22.4   93.4 +21.6  99   350.00 4.2
 5952 +10.8 4.2 103  70    00   rich +22.4   94.4 +21.9  99   350.00 4.2
 5941 +10.6 4.2 103  70    00   rich +23.2   94.6 +21.8  99   300.00 4.2
 5984 +10.4 4.1 103  70    00   rich +22.7   93.2 +21.7  99   300.00 4.2
 6082 +10.2 4.1 103  70    00   rich +23.4   91.6 +22.0  99   300.00 4.1
 6038 +10.0 4.1 102  70    00   rich +23.3   91.4 +22.1  98   300.00 4.2
 6016  +9.8 4.1 103  60    00   rich +23.5   89.7 +22.1  98   300.00 4.2
 5995  +9.8 4.1 103  70    00   rich +23.3   91.8 +22.0  98   300.00 4.2
 6038 +10.0 4.1 103  70    00   rich +23.4   91.4 +22.0  98   300.00 4.2
 6138 +10.0 4.1 103  70    00   rich +23.8   91.1 +22.0  98   300.00 4.2
 6116 +10.0 4.2 102  70    00   rich +23.5   94.4 +22.0  98   300.00 4.2
This Pull I did after I tweaked the fuel a little bit. Not maxing out the injectors anymore. YaY . Any advice or areas I should be looking at would help. Thx
Old 02-04-2013, 09:12 AM   #8
Cobb Tuning
Member#: 4803
Originally Posted by BoxoB View Post
Code:
That looks like a UTEC log. You will want to post in the UTEC sub-forum as this sub-forum is for the Cobb Accessport.
Bill
Old 02-04-2013, 02:41 PM   #9
BoxoB
Member#: 344269
Default oops
Bill
You sir are correct .. My fualt .. didn't see that
