Old 07-01-2012, 05:39 PM   #1
11SubieWRX4D
Member#: 264443
2011 WRX Sedan Stg 2
Default Stage 1 ACN91 Normal Wastegate Log
This is the result of the log with Stage 1 ACN91 Normal WG.
https://docs.google.com/spreadsheet/...FRGTHJjY3FXcEE
From the looks of it, its similar to nappynick's 1st run. Do you agree that I also need ACN91 HWG?
11SubieWRX4D is offline   Reply With Quote
Old 07-01-2012, 05:42 PM   #2
sogah87
Member#: 286573
2016 WRX STi limited
Crystal White Pearl
doesn't look like you need the HWG map, but I cannot remember what the stg 1 peak boost target is for an '11.
sogah87 is offline   Reply With Quote
Old 07-01-2012, 06:02 PM   #3
11SubieWRX4D
Member#: 264443
This is the result of Stage 1 ACN91 High Wastegate
https://docs.google.com/spreadsheet/...TR1S2FQYl91YUE
According to COBB:
Boost Targets: ~14.5psi peak boost pressure tapering down to ~12.5psi by the 7000 RPM redline, +/- 0.8psi.
It looks like i'm right on target with the High Wastegate.
Old 07-01-2012, 11:30 PM   #4
Cobb Tuning
Member#: 4803
According to COBB:
Log looks good with the HWG map. Enjoy!
Bill
Old 07-02-2012, 05:32 PM   #5
11SubieWRX4D
Member#: 264443
Thanks for checking it out. You have other feedback from the log besides the target boost?
Old 07-03-2012, 09:15 AM   #6
Cobb Tuning
Member#: 4803
Log looks good not just from the boost control side.
Bill
Old 07-03-2012, 05:25 PM   #7
11SubieWRX4D
Member#: 264443
Cool deal. Thanks!
Old 07-07-2012, 01:29 PM   #8
11SubieWRX4D
Member#: 264443
A week from my 1st Log, it looks like the boost has exceeded the target. Should i switch down to normal wastegate? Or is it normal for boost to go up and stick to HWG?
https://docs.google.com/spreadsheet/...nUwYkR2czRldkE
Old 07-08-2012, 09:54 AM   #9
Cobb Tuning
Member#: 4803
No, your fine. You want to be within +/- 1 psi of your target and you are good. I would just watch the boost when it starts to get cold out (take a few more logs then).
Bill
Old 07-15-2012, 02:31 AM   #10
11SubieWRX4D
Member#: 264443
Looks to be consistent after 2 weeks from 1st run. Guess gonna wait until winter and start logging again.
https://docs.google.com/spreadsheet/...245b0dsR25MTEE
Old 07-15-2012, 10:06 AM   #11
Cobb Tuning
Member#: 4803
Looks good.
Bill
Old 01-08-2013, 12:07 AM   #12
11SubieWRX4D
Member#: 264443
Looks like during the winter time i have to switch to Normal WG.
Do you agree Bill?
https://docs.google.com/spreadsheet/...0VMY1ZNWlR3X3c
Old 01-08-2013, 09:52 AM   #13
Cobb Tuning
Member#: 4803
Do you agree Bill?
This log looks fine so I would say use the NWG map in the winter. HWG may be OK (would have to see log with colder temps), but these cars can see a lot of airflow at cold temps so being on the more conservative side is better.
Bill
Old 01-08-2013, 02:56 PM   #14
11SubieWRX4D
Member#: 264443
Ok, ill see if I can do another test log with hwg and see if there's a huge difference.
Old 01-12-2013, 04:54 PM   #15
11SubieWRX4D
Member#: 264443
Here is my log for HWG 53F degrees during the winter time. It looks like I can use HWG as well. Although it will be short lived since I'm going Stage 2 tomorrow (Catted DP and Catback exhaust). But here's the log anyway
https://docs.google.com/spreadsheet/...WctZzhMT2pnM2c
Old 01-13-2013, 10:30 AM   #16
Cobb Tuning
Member#: 4803
Just be careful with colder temps. Of course, things could be completely different at stage 2 level - so you will need to do new logs when you make the transition.
Bill
Old 01-13-2013, 10:38 PM   #17
11SubieWRX4D
Member#: 264443
Stage 2 Normal Wastegate
https://docs.google.com/spreadsheet/...Wo5M0puU0ZiNHc
Yikes, seems way to low in boost. Agree i have to switch to HW?
One thing to consider, i currently do not have a heat shield installed since I was not aware that the dp will require an aftermarket, i ordered a heatshield but will not arrive for 2-3 days. Should I leave it in Normal wastegate to be more conservative and not increase the heat?
Old 01-14-2013, 10:00 AM   #18
Cobb Tuning
Member#: 4803
Boost is a little soft in this log. I think you can give the HWG map a try. Not having the heatshield on the car for a few days isn't going to matter that much unless you are doing a lot of idling or slow driving followed by heavy throttle pulls (i.e. any scenario where heat soak could be a problem followed by aggressive driving).
Bill
Old 01-14-2013, 10:03 AM   #19
11SubieWRX4D
Member#: 264443
Thanks Bill, I know I can always depend on you. Do you know why my boost is way too soft and during winter? Will it be an issue during the summer when I can't go over high wastegate and under boost will be an issue? Is this a normal occurrence?
Old 01-14-2013, 10:09 AM   #20
Cobb Tuning
Member#: 4803
Thanks Bill, I know I can always depend on you. Do you know why my boost is way too soft? Is this a normal occurrence?
There are a lot of variations between different cars, different downpipes, and sometimes the conditions the cars is driven under (altitude, outside temp, etc.). So, most cars are good with the normal wastegate map, while other underboost or overboost, which is why we supply the hwg and lwg maps.
Bill
Old 01-16-2013, 02:33 AM   #21
11SubieWRX4D
Member#: 264443
Ok, here is my log with Stage 2 HWG ACN1. Looks good? Should i also be concerned about the feedback knock?
https://docs.google.com/spreadsheet/...DAxXzF2UFpRS0E
Old 01-16-2013, 10:14 AM   #22
11SubieWRX4D
Member#: 264443
Did an incomplete log since i hit traffic this morning . I only got up to 4300 RPM.
https://docs.google.com/spreadsheet/...UIxNE1HYXZxeEE
Looks good in the beginning, but would like to go up to 7000 RPM to ensure no knock comes up.
My log above had knocks during low RPM. Chance that i would see that again?
Old 01-16-2013, 11:42 AM   #23
Cobb Tuning
Member#: 4803
You have a couple of threads with the same logs - I would stick to one of them as it gets confusing to follow the info in both threads at the same time.
Bill
Old 01-16-2013, 01:38 PM   #24
11SubieWRX4D
Member#: 264443
Yea sorry. I'll continue on the other log since I'm already on Stage 2.
2011 WRX Stage 1 + AEM 93 Data Log Game_Over AccessPort 19 07-17-2012 09:23 AM
2010 WRX Cobb Stage 1 93 OTS Data Log KPunk AccessPort 2 05-13-2012 09:50 PM
2011 WRX COBB stage 1 + SF 93 octane Log Check subiebosch AccessPort 4 04-30-2012 09:57 AM
2012 WRX Cobb Stage 1 ACN 91 data logs Knale AccessPort 3 04-24-2012 09:05 AM
2011 wrx stage 1 acn91 data log assist - overboosting? mattesonb AccessPort 9 02-10-2012 07:36 PM
