#1 |
Member#: 298536
South East
Vehicle:2011 wrx Satin white |
Recently went stage 2 on my 2011 wrx hatch wanted some opinions on whether the car is running fine or not.
Parts: Invidia Q300 catback Invidia Catless DP w/ extra O2 bung Cobb SF Intake Cobb Accessport with "stage 2 SLWG" 93 octane map Log: https://docs.google.com/spreadsheet/...k1JeEtqWHJsUUE
#2 |
Member#: 264443
SCIC
Vehicle:2011 WRX Sedan Stg 2 OBP |
hmm, seems to be low on boost. Target i believe is 17-18psi. Is this normal wastegate?
#3 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#4 |
Member#: 298536
South East
Yes i was just worried since my mechanical spt boost gauge shows higher pressures, but i was told it is not accurate since the spring. This log was taken when it was 76 degrees outside should i move up to maybe low wastegate? I had it on low wastegate at first but would hear a fluttering noise when on fifth gear at WOT, definitely wasn't the BOV came from the right side maybe the wastegate?
#5 | |
Member#: 298536
South East
Yes i was just worried since my mechanical spt boost gauge shows higher pressures, but i was told it is not accurate since the spring. This log was taken when it was 76 degrees outside should i move up to maybe low wastegate? I had it on low wastegate at first but would hear a fluttering noise when on fifth gear at WOT, definitely wasn't the BOV came from the right side maybe the wastegate? |
#6 |
Member#: 298536
South East
Wrong log was posted that was at stage 1 +SF when i had to go to HWG map.
This is the correct log: https://docs.google.com/spreadsheet/...GdCdDhCdGVhZHc |
#7 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#8 | |
Member#: 298536
South East
#9 | |
NASIOC Manufacturer
Member#: 4803
![]() Which log would you like me to look at (first or second log you posted)? What map are you running with that log? What is the outside temp (approximately) when you took that log? EDIT: Typo on what I posted before "...while LWG maps are those you run when you are overboosting..." Bill |
#10 | |
Member#: 298536
South East
You could also take a look at these 3 logs i took today,running the same map and about 76 degrees at night. Boost seems so inconsistent sometimes doesn't reach target sometimes it does, and sometimes in 4th gear it goes to 19.5 psi https://docs.google.com/folder/d/0B0...E1S0ZsYXc/edit Last edited by ajmillan; 01-17-2013 at 01:08 AM. |
#11 | |
NASIOC Manufacturer
Member#: 4803
1. You can do a pull with the fuel economy +SF map. This will disable boost control and tell you if you can mitigate the overboost somewhat at 0% WGDC. Do a few pulls to high RPM (if you can do so safely) and we will get a better idea. If it does help quite a bit, then it means that some tweaks to the tune could mitigate the overboost somewhat at least at the current temps you are seeing. 2. If #1 doesn't help, then you must do something on the mechanical end. Examples would include: 1. put a catted downpipe on car 2. port wastegate + custom tune 3. external wastgate + custom tune. #1 is not guarantee that you won't still see boost creep but the chance are significantly reduced. Bill |
#12 | |
Member#: 298536
South East
https://docs.google.com/spreadsheet/...EMyZUxnZW93eXc |
#13 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#14 | |
Member#: 298536
South East
#15 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#16 |
Member#: 298536
South East
So why exactly is it bad to drive spiritedly with fuel economy map then can I have that map on fpr city driving?
#17 | |
Member#: 298536
South East
Let me know what you think and if a pro tune can sort out the issue. https://docs.google.com/spreadsheet/...zFHTHVKcjU4TkE |
#18 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#19 |
Member#: 298536
South East
The economy map has a rev limiter at 5400 rpm how am I supposed to go to redline?
#20 | |
NASIOC Manufacturer
Member#: 4803
We'll need to modify the non-fuel economy map via AccessTUNER Race software. This is easy to do, but it is up to you if you want to give this a try. If you do, first thing is you'll need to request a copy of the AccessTUNER Race software here: http://www.cobbtuning.com/accesstune...st-s/70716.htm Once you are emailed a copy of the link to the download, then install it on your computer and we'll go from there. Bill |
#21 | |
Member#: 298536
South East
#22 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#23 | |
Member#: 298536
South East
https://docs.google.com/spreadsheet/...VBzZWNaRnQ4dkE I also already have the Accesstuner software, how will we go about making this economy map? |
#24 | |
NASIOC Manufacturer
Member#: 4803
Bill |
#25 | |
Member#: 298536
South East
