Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 12-31-2010, 07:18 PM   #51
jetski247
Member#: 188171
04 sti baby
wrb
yes, it has a flex joint which i did look down and saw nothing out of the ordinary but it is a good point.
jetski247 is offline   Reply With Quote
Old 01-01-2011, 11:25 AM   #52
jetski247
Member#: 188171
04 sti baby
wrb
i'll be posting a "putting everything back together" thread so you guys can see if it'll blow up or run like a champ.
Old 01-01-2011, 11:48 PM   #53
BraveSTi
Member#: 262030
...ouch
BraveSTi is offline   Reply With Quote
Old 01-03-2011, 03:36 PM   #54
BLK_VR38
Member#: 268610
2010 R35 / 997 Turbo
Black / Silver
Mis-routed vacuum lines, especially for say catch-cans or after a motor pull can result in over-pressure in the heads and ultimately excessively high oil pressure. Seen this happen a few times.
BLK_VR38 is offline   Reply With Quote
Old 03-23-2011, 08:57 AM   #55
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Any new updates?
TyranosaurusWRX is offline   Reply With Quote
Old 03-26-2011, 11:06 AM   #56
jetski247
Member#: 188171
04 sti baby
wrb
getting an engine builder to build an engine with forged pistons, going with a vf22bb turbo and ported the tgv's and tb, and port matched the intake manifold, other than that, not much to report, just another blown engine thread.
Old 03-26-2011, 01:39 PM   #57
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
WOW this thread is full of stupid comments. I would elaborate, but it is irrelevant at this point.
So you had a bad piston?
aboothman is offline   Reply With Quote
Old 03-26-2011, 01:44 PM   #58
McKenzie83
Member#: 207896
11 STi limited
you're my hero... LMAO
McKenzie83 is offline   Reply With Quote
Old 03-26-2011, 03:40 PM   #59
edberg
Member#: 258229
2006 WRX Wagon T518Z
Five Gears of Fear
I just bought an 18g and all this talk about banjo bolts and filters have me worried, Should I reuse all the stock bolts? Should the turbo come with a different banjo bolt? (bought used) Remove filter?
edberg is offline   Reply With Quote
Old 03-26-2011, 04:35 PM   #60
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
No. His pistons were fine. All his rod bearings $hit the bed. Cause is unknown (I think?. He hasnt updated his build thread recently that I've seen).
2Fast4U1DAY is offline   Reply With Quote
Old 03-26-2011, 07:48 PM   #61
jetski247
Member#: 188171
04 sti baby
wrb
he's collecting photos right now. among many other things.
Old 03-26-2011, 09:57 PM   #62
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Ya it sounded like oil starvation to me. That would explain the rod bearings and the turbo(s) going out.
Your posts were not exactly brilliant or insightful. Overboosting on the factory solenoid would generally lead to fuel cut. Assuming his tune actually has fuel cut set, but most competent tuners (and even some not so competent ones) set fuel cut a couple psi about boost target. Combine that with the OP saying he kept it out of boost after the turbo replacement, never witnessed any severe boost spikes, and the fact that these turbos are known for taking 25+ psi without instantly "exploding" and I am let to believe that overboost was not the cause of his issues.
Or it would have detonated due to overboost...and he DEFINITELY would have know if that had happened.
As for the boost solenoid, that line that returns to the intake is just there to ensure that metered air bled off from the solenoid is returned to the engine, so I highly doubt it being damage would cause you to overboost.
Either way, I am sorry to hear about your engine trouble, and I did not post in here to start a battle. I hope your build goes fast, and inexpensive. Don't skimp on some of the parts that could cause future issues...such as the oil heat exchanger
Old 03-26-2011, 10:28 PM   #63
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
first person i saw say what that line really is!!! thank you! on the stock 2port or 3port its a worthless line that just runs the air back into the system instead of venting it to atmos because the Govt. says thats a NO NO. all air must be vented back into the system to be used again and run out the exhaust through the CAT. just like your crank case vent and valve vents. all could be vented to atmos but stock wise their not allowed. HOWEVER, if you vent the line running off the BS to atmos you must cap the hole on the inlet. if not your letting metered air out of the inlet and you'll run like crap. well technically when in boost you'll be sucking in air through the little hole thats not getting filtered or messured by the MAF.
now since you said the car was running fine i highly doubt the line had a hole in it even though it looked dry rotted. letting metered air out of the inlet or in would be more a motor problem then a turbo problem. it would be the same as running a BOV. the car would run rich/lean and like crap but the motor would have blown not 2 turbos!!
now just to clarify, you said you just decided to remove the filter in the banjo bolt on the block just cause?? ever since you did that 2 turbos have blown. i personally can only think of 2 things why that happened. 1 your just that unlucky and 2 turbos went when it was their time. and 2 when re-installing that banjo bolt something went wrong. does Subi by chance say how the banjo bolt needs to be installed. like does the 2 holes in the banjo need aligned with the flow of oil running through the metal oil line??
synolimit is offline   Reply With Quote
Old 03-26-2011, 10:56 PM   #64
jetski247
Member#: 188171
04 sti baby
wrb
the hole was plugged on the turbo inlet where the boost controller vacuum line went so there was no un-metered air that i know of.
yes, two turbos went out after removing the avcs filters and the filter in the banjo bolt on the back of the block going to the turbo so with the loss of the three filters, maybe too much oil to the turbo?
i don't know either, i just guess that my original went out due to age, the second went out due to the vacuum line not being hooked up to the turbo inlet, ive herd both sides of the story on the vacuum line from the boost controller is important and not important but i have no idea.
it ran flawlessly until one cold day my fuel lines leaked like crazy and i had to replace them, thats when everything went to crap.
as far as the build goes, going with a subie engine builder so im putting my trust in him, oil cooler will be new, i cut my old one in half on the saw the other day and would not run it even if i cleaned it 100 times. so far i'm looking in the neighborhood of 3000 doing everything myself but the rebuild. my old engine is total trash.
Old 03-26-2011, 11:10 PM   #65
synolimit
Member#: 225225
11 WRX
hmm. now its impossible to tell. that leak of fuel for a minute or whatever could have run lean, something could have broke, and the turbine wheel could have broke by sucking up metal pieces which broke everything else in the turbo. O well sorry, GL!
Old 01-16-2013, 03:50 PM   #66
johnblahuta88
Member#: 221614
Default banjo bolt
Where did you buy the longer banjo bolt. its the middle of the three bolts. I really need a longer one with my feed line
johnblahuta88 is offline   Reply With Quote
WTB: You won't believe this. Two Different Caps rainmanjam Private 'Wanted' Classifieds 2 05-24-2005 05:30 PM
You won't believe this pooponford Warranty Issues & SOA Problems 5 03-22-2002 11:19 AM
You Won't Believe This, BUT.......... HotImprezaChick Southern California Impreza Club Forum -- SCIC 5 10-28-2001 10:16 PM
('93-'01) You won't believe this! kinda gross but true. hayscoob Impreza Forum 3 05-11-2001 11:41 PM
lol, you won't believe this story. M a t t General Forum Archive 18 12-09-2000 12:41 AM
Message Board Statistics All times are GMT -4. The time now is 05:40 AM.
