Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 01-06-2013, 05:12 AM   #101
Kyle_J
Member#: 292364
ISM
Originally Posted by spoolinsti05 View Post
Hey you used my battery hook trick
That's ****ty man Look's like an oiling issue from the rod. How's the rod bearings look on the cylinders with the scored pin's?
Do you know bearing clearance? Who built this engine? Was oil pump packed for start up? Look's like it happened on start up.
BUT WHAT DO I KNOW LOL
I haven't split the block yet, just pulled those two pistons. I built the block, bearing clearances were good when assembling. I did not pack the oil pump but used lots of redline assembly lube and fully primed the motor before starting
Kyle_J is offline   Reply With Quote
Old 01-06-2013, 12:28 PM   #102
Maxwell Power
Member#: 190729
Looks like you had too much knock on that cylinder. The top ring land looks like it's seen quite a bit.
You said you tuned it yourself, right ?
How much knock were you getting ?
I've had guys think knock was ok because they had forged pistons. Knock is never ok.
Old 01-09-2013, 10:11 PM   #103
Kyle_J
Member#: 292364
ISM
Every time I've logged knock I had less than .3 volts. It was originally tuned by AMS with the old motor I just touched the tune up a bit after I built this block.
Old 01-10-2013, 02:07 PM   #104
Maxwell Power
Member#: 190729
.3 volts? What are you using for EMS?
Old 01-10-2013, 02:33 PM   #105
Kyle_J
Member#: 292364
ISM
AEM. The top of the piston has no signs of detonation. Also, this happened while using 2 step
Old 01-10-2013, 03:13 PM   #106
Maxwell Power
Member#: 190729
I can barely see it in the picture. It looked like a lot of small pits below the upper ring. Plus the wear on the wrist pin made me think detonation.
Old 01-10-2013, 06:17 PM   #107
ckyguy68
Member#: 316296
2006 STIROID
[email protected] on 29psi
Were these upgraded wrist pins??
I'm not going to bash said shop but I do know for a fact they are a little timing happy on their tunes and based on the dyno sheets I have from the previous owner they aren't exactly the most well-versed in Subaru tuning.
Old 01-10-2013, 07:33 PM   #108
Maxwell Power
Member#: 190729
Is it safe to say that nobody verified the pin to piston clearance?
Old 01-10-2013, 07:40 PM   #109
Kyle_J
Member#: 292364
ISM
They were not upgraded pins, I don't remember where timing was at. It made 450/449 on AMS's dyno. The tune really wasn't that great, drivability kind of sucked
Old 01-10-2013, 07:42 PM   #110
Juice66
Member#: 340526
2004 WRX STi
HTA86
Explain the drivability issues.
Juice66 is offline   Reply With Quote
Old 01-10-2013, 07:53 PM   #111
05_wRex
Member#: 170097
2007 WRX STi PTE6266
If his issues were anything like mine...the car would cruise so lean it would hesitate if you stepped on the gas faster than a grandma on a Sunday drive. Throttle so touchy it looks like you just started driving your first stick shift car. Throttle accel issues out the azz.
05_wRex is offline   Reply With Quote
Old 01-10-2013, 07:56 PM   #112
ckyguy68
Member#: 316296
2006 STIROID
Ahh yes, the AMS driveability issues.
Look at the ignition accel and decel tables. Mine were spaced out.
Old 01-10-2013, 08:19 PM   #113
Kyle_J
Member#: 292364
ISM
What they said^
Old 01-16-2013, 07:47 PM   #114
Kyle_J
Member#: 292364
ISM
Would it be worthwhile to replace all the wrist pins with JE's upgraded pins? I'm wondering if the wrist pin bent slightly because of the extreme load
Old 01-16-2013, 07:51 PM   #115
Maxwell Power
Member#: 190729
Pm sent
Stronger pins are always worth it.
Old 01-16-2013, 09:09 PM   #116
ckyguy68
Member#: 316296
2006 STIROID
Pm sent
+1!!
JE recommends the upgraded pins for over 500 hp.
Old 01-16-2013, 09:23 PM   #117
Maxwell Power
Member#: 190729
I think I have them in stock...
Old 01-17-2013, 11:12 PM   #118
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Do it... mine are and offset iirc.
spoolinsti05 is offline   Reply With Quote
Old 01-24-2013, 11:28 PM   #119
disturbed3269
Member#: 169062
2006 STi
I found out a tapping noise was one of my rod bearing being bad and the noise was only from 2.5k rpm-4k rpm. The rod and crank were f'ed up bad. So, a tear down would be adviseable if you have a spare car or borrow one.
disturbed3269 is offline   Reply With Quote
Old 01-24-2013, 11:45 PM   #120
Kyle_J
Member#: 292364
ISM
Problem was cyl 2 wrist pin. Rebuilding right now should be running in a couple weeks or less
Old 03-12-2013, 01:20 PM   #121
Kyle_J
Member#: 292364
ISM
UPDATE: just fired the car up anddddd the tick is still there although it doesn't sound as bad. I'm grabbing some 20w50 right now to try out and see if it goes away. It's only there now when completely warmed up
Old 03-12-2013, 04:14 PM   #122
Kyle_J
Member#: 292364
ISM
Another update..switching from 10w40 to 20w50 made absolutely no difference in sound..car still runs perfect. Swapped avcs solenoids around to see if the noise followed..it didn't. Car still runs perfect. I am seriously lost as to what this could be.
Old 03-12-2013, 04:27 PM   #123
kakarot09
Member#: 182375
08 Sti
Wrbm
Assuming you put new pistons and wrist pins in?
kakarot09 is offline   Reply With Quote
Old 03-12-2013, 05:04 PM   #124
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
upppdates!! if you swapped to new pistons, and replaced the rod bushing...seems tou should run car wihtout timing belt cover and visually look at tensioner. sounds dumb but very easy to do and only takes a short amount of time.
maybe its an oil flow issue, also did the lash check out before you installed new motor? if lash is good and all bearings/wrist pins are clearanced right shouldnt be any more noise loud tap wise...
maybe avcs issues......
stretchedk7 is online now   Reply With Quote
Old 03-12-2013, 05:28 PM   #125
Kyle_J
Member#: 292364
ISM
One new piston, 4 new upgraded wrist pins. Had all pistons and rods honed to correct wrist pin clearance
