Old 01-06-2013, 02:10 PM   #1
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Default How To: "Fix" an armrest extension for about $2 and some glue
I was at the bone yard yesterday picking up some parts for my ImprezaS and came across a bugeye 2.5RS with an armrest extension. Of course the upper latch was broken but I've always wanted one of these in my car. I'm a tall guy and because of my tall torso my elbow doesn't hang low enough to use the arm rest. This use to bother me a lot when I went on long trips but now I have a big comfy gas guzzling SUV for that
So, I was planning to try and go to Home Depot and find something to rig up to work as a replacement latch. Then I remembered seeing some rare earth magnets for sale at Harbor Freight and thought those would work just fine.
What you need:
- Your armrest extension - Mine was already out but it is probably easier to do this with it out of the car. If you need to take it out you will need a Phillips screwdriver.
- A pack of these rare earth magnets, the ones on the left. I bought both kinds just in case. The rare earth ones are normally $2.99 but on sale this month for $0.99.
- Some glue. I used hot glue but halfway through decided it would be better to use super glue or something else. Unfortunately every tube of super glue around my house was hard and crusty, so I just stuck (no pun intended) with the hot glue.
A close up of the magnets. You want the ones on the left.
With the console open, take a look at the screws on the upper lid part. The hole is exactly the same size as these little magnets.
So perfect in fact that if you put one of the magnets in there it sticks to the screw and is a little tough to get out.
So the idea is your are going to glue one magnet in that little hole and one on the other side to match up.
Of course you don't want to have one magnet glued on upside down otherwise your console lid will magically float about 1/4 inch above the console.
So, take two of the magnets and then mark a little black dot on each side; this will be the side you want to glue "down".
Dotted, and unamused.
Now back to the glue:
Like I said, the hot glue works fine and can be undone if need be. Dab a bead in there and place a magnet in there black dot side down.
I'm good with that.
Seahawk is offline   Reply With Quote
Old 01-06-2013, 02:10 PM   #2
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Now close the console lid and eyeball where the other magnet should go.
Mark it with something and get ready to glue the other one down. I also wiped the area with an alcohol pad prior to marking the dot.
Put another dab of glue on the dot and press it in. I wiped the excess glue of before it cooled down.
The magnets hold strong enough that I could hold the console by the lid and shake it a bit and it would stay shut.
Here's a side shot so you can see that even though the lid now sits a little higher the gap is about dead even.
In the car. That button is a custom garage door opener.
And...the lid stays shut when the whole thing is open.
From the driver's side. Yes, there is a little paint mark or something and a tiny cut in the vinyl but for $15, not too bad.
Thanks and hope this can help some people!
Old 01-07-2013, 10:19 AM   #3
Legend STI
Member#: 41086
2015 Jeep Sahara
Good job. I need to do mine soon.
Legend STI is offline   Reply With Quote
Old 01-07-2013, 09:10 PM   #4
jimbosv650
Member#: 261307
04 wrx wagon
You know what, that's pretty cool. I love it when people take something and re-engineer it to work after it breaks. That's what I do too. Nice job
jimbosv650 is offline   Reply With Quote
Old 01-07-2013, 09:30 PM   #5
emericareaper2
Member#: 323008
02 WRX minivan
Haha funny part about my situation. All 3 of the Subaru's I've owned all had armrest extensions. They also all had broken tabs. I've done this method on all 3 of them! Works great & you don't have to pay the money to get a whole new armrest extension. Good write-up!
emericareaper2 is offline   Reply With Quote
Old 01-11-2013, 10:53 AM   #6
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
I was originally going to try and make it a little cleaner looking by gluing the magnets on the underside of the bottom part but it's just a one-piece molded part so there's no way to get in there.
Old 01-13-2013, 02:12 AM   #7
bangbang
Member#: 341404
2004 Impreza OBS
awesome! i just did this with some neodymium magnets off ebay. i had some trouble with them being stronger than the glue (and they naturally stuck to the metal piece in the center), so i just ended up with two magnets on bottom, no glue, and glued a steel tire valve cap to the top part. your install is cleaner!
bangbang is offline   Reply With Quote
Old 01-15-2013, 05:47 PM   #8
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
nice job. I have a broken one too. I guess I know what I'm going to be doing soon. Thanks
arco is offline   Reply With Quote
Old 01-15-2013, 08:47 PM   #9
itstony
Member#: 253911
1999 2.5rs
black
Lol i always thought about using maybe velcro or something but i'm definetly going to try this out this weekend. thanks for the diy!
itstony is offline   Reply With Quote
Old 01-16-2013, 11:00 AM   #10
KHunter25
Member#: 311147
Sedona Red Pearl
Nice DIY. I am going to do this to mine. Thanks
KHunter25 is offline   Reply With Quote
Old 01-16-2013, 10:45 PM   #11
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
Glad I could help. I'd recommend the super glue, or maybe even Elmer's glue instead of the hot glue. The bottom magnet came off and I need to reglue it. I just got back in town but when I get a chance to take it out again I'm going to see if there is a way to put the magnets on the latch itself.
Interesting. Where did you glue the valve cap? Any pictures? These magnets are strong!
Old 05-16-2013, 03:31 PM   #12
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
it costs more to ship the magnets from harbor freight to me than the product price... LOL.. what's the size of the magnets?
iNfEk is offline   Reply With Quote
Old 05-16-2013, 03:38 PM   #13
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
The magnets are exactly the same size of the "hole" if that helps. I didn't measure them. You might be able to find some on Ebay or something, I think they are pretty common. I don't have the car or armrest any more but I do still have some of the magnets and I can measure them when I get home.
Old 05-16-2013, 03:41 PM   #14
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks. That was the plan to go to ebay so I just need the size. I'm also thinking of a way to repair this since I still have the latch. Thinking of putting a price of metal and spacer that'll hold the latch in place. The magnet would be the alternative.
Old 05-17-2013, 01:03 AM   #15
i have used RTV to hold magnets to various surfaces....and YES....it is hard to 'glue' them as they are quite strong.....using something like RTV over/between them to keep them from actually touching either other magnets or ferrous parts that you are working with can make them less of a hassle and makes their 'engagement' and 'disengagement' a lot 'softer' and less abrupt
old hard drives have great magnets in them for lots of projects
Old 05-17-2013, 07:22 AM   #16
VTSubieRS
Member#: 90608
2005 STI, '08 3.0R
05 2.5RS, 92 Legacy L
nice DIY. However the replacement latch can be had from Subaru for less than 5 bucks.
Part# 92184SA010OE
VTSubieRS is offline   Reply With Quote
Old 05-17-2013, 11:12 AM   #17
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Part# 92184SA010OE
Thanks for the PN. the latch for me anyway isn't what had broken. The ones I've also seen also have the same issue. It's where the latch connects to the upper side of the arm rest that breaks.
Old 05-18-2013, 07:20 AM   #18
Seahawk
Member#: 71665
1994 Impreza Base
EJ205 Stage 2
The magnets are approx 8mm in diameter
Old 12-09-2015, 07:02 PM   #19
free mustache rides
Member#: 381694
nice fix for sure. i almost went this way but if you need the latch for just the upper armrest extension its 92068FC000. i work at a dealer ordered it for my '02, came in and its the right one. $5.00 and done
free mustache rides is offline   Reply With Quote
Old 12-09-2015, 07:28 PM   #20
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Thanks. My arm rest upper that holds the latch is what's causing it to break off. Still figuring out (not actively LOL) how to fix it effectively
Though this fix will eliminate the need for the latch all together. Hmmm
Old 12-12-2015, 11:53 PM   #21
yamazaho
Member#: 431214
2014 WRX Hatchback
WR Blue
nice work
yamazaho is offline   Reply With Quote
