Old 01-16-2013, 05:00 PM   #8651
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Originally Posted by DownhillSubie View Post
Bought a Belkin hook-up, now have music playing from my AUX in all speakers. Quick $9 fix.
You plan on doing any stereo upgrades?
fancyfootwork15 is online now   Reply With Quote
Old 01-16-2013, 05:16 PM   #8652
DownhillSubie
Member#: 342985
Zero.
DownhillSubie is offline   Reply With Quote
Old 01-16-2013, 07:17 PM   #8653
trishHUYNH
Member#: 248840
2011 Impreza
Originally Posted by KartRacer3 View Post
Nice modlist! You sure are catching up to the rest of us
Why is their no front lip on this list when you obviously have one pictured?
I did that exact same thing!
Get a bright flashlight so you can pinpoint where the bolts actually are and when you may be getting them close to the hole. Get a long screw driver or a telescoping magnet? Also your best bet is to get it through where the brake light/windshield washier fluid tubes go b/c of the bigger hole.
Just bought one of those magnet sticks today! Let's hope it works, because I've been driving around and can hear the bolts roll back and fourth.
A few quick shots while I was at school!
trishHUYNH is offline   Reply With Quote
Old 01-16-2013, 07:38 PM   #8654
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Looks good. What's on your door?
Old 01-16-2013, 09:27 PM   #8655
trishHUYNH
Member#: 248840
2011 Impreza
Someone hit my door causing a dent and it cracked the paint. I had the dent removed, but the crack just got covered by touch up paint and it looked unsightly. So I put a band-aid vinyl over it.
Old 01-16-2013, 09:31 PM   #8656
premier00000
Member#: 251060
2008 Impreza Outback
That's exactly what happened to me, and exactly what I did.
Old 01-16-2013, 09:56 PM   #8657
DownhillSubie
Member#: 342985
So RalliSport UEl Headers will take about 6 weeks to get here. Upon inspection when I took my airbox air duct off today, it looks like my header is seperated.
The part that is seperated is just below the arrow where the horizontal seam is, I was able to move the upper seam portion, so I assume it should not be moveable, correct?
Would like to get this rectified as soon as possible since I think that is the reason for the oil smell. Any of you guy's run the HKS 409 Equal Length headers? (https://shop.bostonmotorsports.com/H...ld_p_1347.html ) or know a place to pick up OEM headers?
I figure since I plan on doing the Tsudo Catback exhaust I might as well get aftermarket headers. Any input would be great, thanks.
Old 01-16-2013, 10:25 PM   #8658
aceofskies05
Member#: 326539
2008 Impreza 2.5
newport blue
I might just be retarded, but I cannot find the PCV valve to inspect it for cleaning/replacement. Anyone got a good picture? I tried to look at the pic from one of the maintenance topics, but I could not line it up to my engine. Or should I just avoid checking the pcv valve? No CEL, just checking for maintenance.
aceofskies05 is offline   Reply With Quote
Old 01-16-2013, 10:26 PM   #8659
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
for anyone whose running 17x9 how are they for everyday/autocross/track days/sprinted twisty road driving... running like a 235/45/17 tire im only lowered on h&r springs with koni shocks(along with a small grocery list of other suspension goodies) will i run into rubbing and needing to roll fenders?
Silver08Waggs is offline   Reply With Quote
Old 01-16-2013, 10:39 PM   #8660
Cmac13
Member#: 312011
2009 impreza 2.5i
white
Depends on the offset, around +35 it gets a little iffy you would have to roll the back (at least I did), but+40 would be fine with no fender mods
Cmac13 is offline   Reply With Quote
Old 01-16-2013, 10:42 PM   #8661
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
That's a heat shield? It may or may not wiggle, it's not a big deal.
Those headers are WRX headers. They will not fit on our cars.
Old 01-16-2013, 10:43 PM   #8662
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
ok they offer the wheel in 17x8 with an offset of 35 or 45 and in 17x9 with an offset of 45... if i have to do a little rolling i don't care i want them to sit almost flush with the fender ride nice and not give me any headaches
Old 01-16-2013, 10:46 PM   #8663
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
I have a 235 with a +48 offset. I had to roll, but I was also pretty low.
You may rub under hard cornering.
Old 01-16-2013, 10:46 PM   #8664
DownhillSubie
Member#: 342985
Damn, what other header options do we have that fit our cars aside from the Rallisport UEL.
Also, in the picture I am talking about the horizontal seam directly to the LEFT of the heatshield. The seam that is almost in line with that lower bolt at the corner of the heatshield.
Old 01-16-2013, 10:52 PM   #8665
Silver08Waggs
Member#: 283606
2008 Impreza 2.5i
i plan on doing autocross and maybe a track day or 2 and i take turns pretty quick on a daily basis if i have to roll i will i dont want to have to go crazy and like i said i would like it to fit either flush with the fender or maybe poke a little
Old 01-16-2013, 11:01 PM   #8666
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
I have a 17x8 +35 offset w/ 245's. no roll and no pull, just lowered about an inch on Rce yellows/koni inserts. Rarely rubs under extremely aggressive cornering lol.
Old 01-17-2013, 12:50 AM   #8667
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Obx, cnt, TWE [requires o2 extension ](equal length) , borla reps with fabrication (uel) do not recommend over rallisport. Not worth the headache. Surf the forums for details or maybe someone here can chime in.
Old 01-17-2013, 12:59 AM   #8668
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Custom modified WRX headers/cat-pipe/o2 extension/possibly CEL or Rallisport period.
Old 01-17-2013, 09:28 AM   #8669
theoutbackdream
Member#: 301179
2013 WRX Limited
Custom modified wrx oem headers or custom modified 2.5I headers for uel. At the moment, the stock headers are not 100% equal length, and have some what of a rumble. If you extend the 4th cylinder outlet you can get a boxer rumble. Someone on lgt did it.
But in my opinion, getting headers is more of a headache vs cost. While rallisport aren't perfect, they have the least amount of issues compared to modding your own.
Old 01-17-2013, 11:30 AM   #8670
Tentonted
Member#: 303864
2008 Impreza 2.5i 5d
Does anyone know what wheels these are? I think Prodrive but cannot find them via google, maybe long discontinued?
-Ten
Tentonted is offline   Reply With Quote
Old 01-17-2013, 12:14 PM   #8671
Cmac13
Member#: 312011
2009 impreza 2.5i
white
-Ten
Xxr makes a wheel like that
http://www.xxrwheels.com/xxr_518.shtml
Old 01-17-2013, 12:39 PM   #8672
premier00000
Member#: 251060
-Ten
Here's a closer picture if someone knows.
Old 01-17-2013, 01:14 PM   #8673
Sellars21
Member#: 304055
2008 2.5i Rallisport
UEL Headers Magnaflow CBE
It's prob not separated. The heat shields from the header work as a compartment for the cat pipe to sit into. The bolts that hold the oem header to the cat pipe are also built into the header the only way for it to separate is for it to shear the bolt off or the entire stud itself.
If it has I have a set of oem headers up for sale. I'll post a pic of the oem header connector when I get home.
Old 01-17-2013, 03:06 PM   #8674
Digital Dillon
Member#: 288727
2008 WRX premium
It's a Prodrive if you zoom in you can see the 'P' on the centercap. XXR does make a replica of the wheel though.
Old 01-17-2013, 03:13 PM   #8675
DownhillSubie
Member#: 342985
Ah thank you for that. After doing an oil change, it looks like oil was leaking from around the oil filter and dripping down onto the pipe causing that oil burning smell, thank previous owner.
Hopefully after driving it later tonight the smell has gone away. Today has been a productive day: car wash, RallyArmor UR install, plate holder installed, 3000k high beams, 4100k low beams, 3000k fogs, DRL delete, air filter change, oill change. Boy this car is easy to work on compared to my Audi.
08 2.5i and 08 Sti Suspension WRXbrother Brakes, Steering & Suspension 7 03-24-2012 02:14 PM
Will an 08 WRX intake fit an 08 2.5i? Racing101 Normally Aspirated Powertrain 26 01-19-2012 11:57 AM
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 09:46 AM
Will 08+ WRX gauges swap into 08+ 2.5i? Simeon Priest Interior & Exterior Modification 10 03-26-2010 02:17 PM
08 2.5i mod question deunique1 Impreza Forum 1 10-03-2007 02:35 PM
