Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 01-13-2013, 10:11 PM   #1
orbs45
Member#: 300835
WRB premium
Default Strange whine after 5lbs of boost???
I have a 2011 wrx stage 2 with just cobb software (good data log numbers) and hks catless down pipe. today i was driving my car and after 5lbs of boost i heard this terrible whining sound almost like a supercharger every time i hit more than 5lbs of boost it continues to make the same noise and im afraid to try and make higher boost. the car only has 9000 miles on it so im a bit surprised as to why it would happen so soon. ive researched this but ive found a bunch of different things so i dont know what to really follow a lead on before i start taking things apart, any info helps thanks.
orbs45 is offline   Reply With Quote
Old 01-13-2013, 10:41 PM   #2
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
My bet is it's your factory BPV failing. Not too surprising.
Old 01-14-2013, 03:15 AM   #3
RoadKillDMD
Member#: 284792
2011 STI
Blurple
Either ^^ that, or those pesky TB-TMIC coupler end caps. Both common issues with running higher boost on the stock setup.
Old 01-14-2013, 08:14 AM   #4
orbs45
Member#: 300835
WRB premium
What's the best way to test to see if it's the BPV? The other leads I found were turbo inlet seal and the turbo whine of death, what do you think?
Old 01-14-2013, 08:16 AM   #5
orbs45
Member#: 300835
WRB premium
I have to check that out, I really don't wanna flash this thing back to stock and bring
It to the dealership because it's still under warranty I'd rather fix it at my friends shop if I can.
Old 01-14-2013, 08:27 AM   #6
subieguy87
Member#: 153412
1998 Impreza wrxRS
It to the dealership because it's still under warranty...
That's just a bad idea anyway.
Next thread: dealership sucks because they voided my warranty!
subieguy87 is offline   Reply With Quote
Old 01-14-2013, 09:20 AM   #7
cineris
Member#: 263329
2011 Impreza WRX
Upgrade your bpv? I got rid of mine a while ago for a turbosmart. Also ditched the stock tmic. Is the sound consistent all the way through or does it taper off towards redline?
I've got a few plausible theories.
1. As others have said, you have a boost leak somewhere (bpv, tmic, some vacuum line somewhere)
2. If it tapers off towards redline and sounds like a screeching banshee, its probably your wastage taking care of higher than stock boost numbers.
3. Our model WRXs are notorious for crappy intercooler hoses. Throttle body to IC hose kinks and makes a stupid whooshing sound like a vacuum cleaner.
Hope that helps a bit.
Edit: I just noticed Dr. Roadkilldmd already stated number 3.
cineris is online now   Reply With Quote
Old 01-14-2013, 01:00 PM   #8
1wrxtra
Member#: 316364
This guy hit the most probable causes on the head. Start there and let us know what you find.
Old 01-14-2013, 02:36 PM   #9
orbs45
Member#: 300835
WRB premium
Alright thanks
Old 01-14-2013, 02:37 PM   #10
orbs45
Member#: 300835
WRB premium
Alright thanks for the input, much appreciated
Old 01-14-2013, 04:30 PM   #11
orbs45
Member#: 300835
WRB premium
I took the car for a spin with my mechanic and the car is continuing the noise until red line and is maxing out at 16lbs of boost instead of the 18.5lbs I was maxing out at..so it's holding boost to a point but not the full boost that it was. I'm thinking a boost leak or the BPV went.
Old 01-14-2013, 04:44 PM   #12
nate_fisher
Member#: 270482
2011 turbotek fxt
11.85@117 4eat xt record?
Throttle body to tmic hose or one of the vac lines on the intake manifold.
nate_fisher is offline   Reply With Quote
Old 01-15-2013, 04:00 PM   #13
orbs45
Member#: 300835
WRB premium
Found the culprit, it was the lower in lC hose rubber gasket which sits between the hose and the throttle body and the clamp wraps around it..the problem was that piece ripped luckily only a 7 dollar fix.
Old 01-15-2013, 04:01 PM   #14
orbs45
Member#: 300835
WRB premium
You were right also IC hose
Old 01-15-2013, 04:45 PM   #15
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Do NOT install a new rubber piece!!!! There are many, many posts about this. There have been at least 3-4 posts in this very section of the forum on this topic in the last week!
The rubber end caps are a poor design and they will fail again. Remove them from BOTH ends of that hose and then reinstall. You will never have another issue again. My car runs double the stock boost and doesn't have a problem.
Old 01-15-2013, 05:24 PM   #16
nate_fisher
Member#: 270482
2011 turbotek fxt
^^^This take them both off asap.
Old 01-17-2013, 01:23 AM   #17
orbs45
Member#: 300835
WRB premium
I haven't installed it yet but Ill test it on Saturday without the end caps..I noticed the blow by as well hopefully they'll be less moisture from the oil when I take the end caps off
