Old 01-16-2013, 09:55 AM   #26
the suicidal eggroll
Member#: 51961
2005 STi
Originally Posted by RaceFaceXC View Post
Nice to know there is an adapter. Does it require a driver or is it simply a form factor change?
USB, mini USB, and micro USB all use identical communications protocols, just different physical connectors. You just have to pay attention to host (port A) or device (port B). With regular USB it's very obvious, host (A) connectors are the big rectangular ones you have on your computer, device (B) connectors are the big square ones that you often see on printers and external hard drives. With mini and micro it's much less obvious, the connector and jack are just shaped slightly different. There are even on-the-go ports which can act as either host or device depending on what you plug into it (the phone's port is almost certainly one of these, it can act as a device when you plug it into a computer, or as a host when you plug a controller into it). You don't want to get the wrong adapter and accidentally plug two host ports into each other, for example, or they'll both be trying to power each other.
Old 01-16-2013, 11:55 AM   #27
jthatch12
Member#: 321715
03 Big 16G WRX
Originally Posted by fateo66 View Post
No driver is needed. My cousin came over a few weeks ago and brought the adapter cable and a PS3 remote; plugged it all together and started using the controller to navigate the phone and then play some games. It was all pretty cool and got my thinking about using the cable to plug my tactrix into my phone to log. So here we are... How do we do it?
Can't do it with the torque app on android with the tatrix. I've tried on my AT100 which has a full USB... it detects the car but just can't log. Only way to log is to use a bluetooth obdII adapter.
Old 01-16-2013, 05:03 PM   #28
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Interesting. I used to be much more of a computer/electronics geek. Don't keep up anymore.
Excellent. That is good to know. Now I'll have to find out what OS I can run in my android phone (S3) that will be compatible with rom raider/ecu flash. Thanks for enlightening me
Old 01-17-2013, 01:10 AM   #29
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Originally Posted by LukkyStrike View Post
To tell the truth...it should not be hard to compile for the ARM RT tablets, all the coders have to do is run it through there ARM compiler, especially since RT has almost 99% compatible USB to the x86 versions....it would be a coup if they would do it.....
Maybe, but I have heard that Windows RT has the drivers locked down so only the OEMs can add them. EcuFlash needs its own driver, so if that's true then it's probably a showstopper.
I haven't heard that direct from Microsoft, but check this out...
http://www.displaylink.com/support/ticket.php?id=335
I'm not sure where to find an authoritative source, but it looks like X86-based tablets like the Surface Pro might be the only viable option.
Old 01-17-2013, 07:30 AM   #30
quazimoto
Member#: 70395
I have seen map switching also with the Bluetooth/Wifi PLX Kiwi.
http://www.speedport.us/speedportapp.html
Tactrix/romraider On Mac 07white450r Open Source Reflashes 3 09-01-2010 07:21 PM
RomRaider Works Romraider ecu logger doesnt tumtum411 Open Source Reflashes 2 06-03-2010 10:56 AM
Tablet Ignites Debate on Messiah and Resurrection poison Off-Topic 8 07-05-2008 11:12 PM
Enginuity on a Tablet PC? NJ2.5RS Commercial ECU Reflashes 3 11-25-2007 12:39 PM
NJ: Compaq Tablet Pc now on ebay burrito007 Private 'For Sale' Classifieds 1 05-02-2005 02:09 AM
