Old 05-14-2012, 02:46 PM   #26
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Hey all. SOrry for the delay we have been waiting for the rear end to come in before we could really make any more progress and start ordering parts. IT DID!!!
Got it set in place and I'll bea heading to the metal yard today to get the metal to bolt it in.
So now the Corollaru gets the rest of its name. SSAN. The Corollarussan is oficially formed... We have the coilovers and some of TSS-Fabs new a-arms coming so we hope to have it almost in rolling form in a couple weeks. In the meantime my buddy has been removing the undercoating so I can stitch weld it after all the chassis fabrication is finished.
More to come
Johann
Bad Wagon is offline   Reply With Quote
Old 05-14-2012, 07:09 PM   #27
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Awesome, what rear diff is that?
BeBop86 is offline   Reply With Quote
Old 06-19-2012, 02:49 PM   #28
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Hey all update time. Ordered in all the adjustable rear arms and got some TSS-Fab Adjustable Front arms which have been sent off for powder coating. Got the rear chassis modifications all welded up so once the arms come back the rear end can be rear installed. Suspension is on the way.
But yesterday I got do try something I have wanted to do for a long time. My buddy (owner of this car) used to have an EVO X. I got ran unto and was totaled. Before the car was taking we got a few of the parts off is and one of those parts were the 2pc Girodisc Rotors. He decided he wanted to put them on this car so here orderd up come calipers and I got to fit them to a set of STi Hubs.
It took a little bit of modification to the hub but it was pretty easy I have to day. Best part is that the EVO X uses the same piston sizing as the STi and the same front pads so the brake bias won't really be effected. Its grown from a 320mm to a 355mm rotor and because this rotor has a larger airgap then the STi the Girodisc rotors are the same weight at 39lbs for the pair. Its a pretty sick mod for those looking for something a little more then what the STi has and dosen't break the bank. I have designed a couple pieces to make it so you can just use the stock EVO X Rotor and caliper and I am going to make a few sets I think so I can do this mod to more cars.
As you can see the size difference:
Once the prototype pieces are finished I'll prolly put these on my forester to test out how that work and if everything goes well then I'll hopfully be able to offer this as one of my special skills when I start my new shop.
More to come in a couple weeks once parts start coming in.
Johann
Old 10-25-2012, 07:28 PM   #29
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Hey all. I have been slacking but I have some good progress on this build. Once I load up all the pics I post what I have.
Johann
Old 10-25-2012, 07:48 PM   #30
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Which trans are you planning on using again, welded Subaru?
Old 10-25-2012, 07:54 PM   #31
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
I finished the front end myself and he took the car to store at his place for the winter.
No William made a special bell housing to use some Toyota (T50 I think...) on it.
I'll have some pics up in a few. I should have taken more but it was working on to many other cars at the same time...
Johann
Old 10-25-2012, 08:04 PM   #32
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Oh man... I wish I didn't hear that, lol.
Now I'm really tempted to throw just a dirt cheap N/A subie motor in the SR5.
I'll wait a while until I get bored of the 75 carburated hp...
Old 10-25-2012, 08:21 PM   #33
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
OKay...
So we left the action with a few things set and the front brakes figured out.. Next we made an extension off one one of the original cross beams to mount the rear of the X-Member and then redid the rear frame rails to bolt the front on. Next we got some adjustable arms for the rear end an a set of TSS new Adjustable A-arms (same ones we prototyped in my Forester.
Everything installed:
Next we ordered a Set of custom Stance Coilovers from my boy Adam at TH Motorsports. 05 STi up front and 240SX rear with AE86 Springs rates. For the rear we cut out the original strut mounts and made new ones using a 5" pipe cut out with a place to mount them. In the front it got a little tricky.
I redrilled the towers to fit the STi Camber plates and trimmed the plates a little bit. I wasn't happy with all the extra metal on the Stock crossmember we originally mounted to the frame rails so we cut it back off and I got William at TTS to make me a tubular front X-Member but with out the ends. I trimmed that to fit in the rails and welded it in place it fit much better. After that I installed the A-arms but because the body of the 86 is not really similar to the Subaru in any way I switch the Left for the Right and ran the rear part of the arm which would normally bolt to where the PSRS would be towards the front and welded the mount to the new frame rail. It looks a lot like the original arm in the *^ with the Torsion bar. Bolted up the hubs and got her into a roller.
Derick the owner took the car this last weekend to his place where it will prolly sit for the winter. Once he unpack everything that he stored in it he'll take some pics of the new rear rails and pics of the front assembly. That is all I have for now. Hopefully in the spring we'll pick up where we left off and get the cage and the body parts ordered up so I can finish up the front core support and start building the turbo kit.
Johann
Old 10-25-2012, 09:29 PM   #34
russgt
Member#: 256322
Frig! Dude you're rediculous.
Super keen to hear about the Evo brake upgrade to sti hubs! Any chance you could pm me with what i would need to do it to an 04 sti?
russgt is offline   Reply With Quote
Old 10-26-2012, 01:28 PM   #35
Bad Wagon
Member#: 53022
1999 Top Scoob Lego
08 Lego 3.0R Flared
Yeah I'll shoot you a PM.
Johann
Old 10-26-2012, 01:39 PM   #36
03boxer4
Member#: 66622
2002 WRB wrx - Sold
Big White Jeep Unlimited
sub'd
03boxer4 is offline   Reply With Quote
Old 10-26-2012, 08:08 PM   #37
happycorey
Member#: 324849
2005 STI
So sick.. it's like the GT86 was modeled right after this thing haha
happycorey is offline   Reply With Quote
Old 10-27-2012, 11:52 AM   #38
Ferg
built to spill
Member#: 14145
02 WRX BLOD
76 C30 Dually
aaaaaannnddddd subscribed!
I want to drive up to Bham and see this in person.
Ferg is offline   Reply With Quote
Old 01-17-2013, 10:06 AM   #39
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
Can't wait to see more of this!!!
King of Poop is online now   Reply With Quote
Old 01-31-2013, 07:50 PM   #40
25rsti
Member#: 166324
Any new updates?
Old 02-01-2013, 01:39 AM   #41
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
I have an AE86 too. I'm definitely interested. I see the fenders are cut up already. Are you doing to do Accord full fenders like on your legacy?
arco is offline   Reply With Quote
Old 03-26-2013, 12:13 PM   #42
Dpwhitehead1
Member#: 139996
2004 IS 300
subsies for badassness
Dpwhitehead1 is offline   Reply With Quote
Tapioca Tea meet, take 2! shadowcat Bay Area Impreza Club Forum -- BAIC 64 10-08-2003 10:49 AM
STi rear diff mount install- take 2 BIGSKYWRX Transmission (AT/MT) & Driveline 0 01-12-2003 12:22 AM
Orlando Track on Friday Night- Take 2 jmimac351 South East Region Forum 7 10-26-2001 11:25 AM
('93-'01) Engine destroyed by BB's....take 2 RoadRashed Impreza Forum 4 10-18-2001 06:55 PM
