Old 01-14-2013, 03:02 PM   #4401
MidnightSti05
Member#: 74064
Originally Posted by PGT View Post
which? the MT/R or KM's?
Oh I see, whatever is mounted on your 5th wheel.
MidnightSti05 is offline   Reply With Quote
Old 01-14-2013, 03:14 PM   #4402
PGT
Member#: 57283
2014 4.7L of TT Fury
w/ 4Matic
MT/R's. The others are stock Rubicon KM's.
PGT is offline   Reply With Quote
Old 01-14-2013, 08:08 PM   #4403
ecb12
Member#: 214708
Did it fix your issue? I had the exact same pull on my '12 Rubi with 35 MTRs
ecb12 is offline   Reply With Quote
Old 01-14-2013, 08:55 PM   #4404
PGT
Member#: 57283
w/ 4Matic
100% yes.
Old 01-14-2013, 09:10 PM   #4405
Goatcrapp
Member#: 64289
2004 wrx wagon
wrb
Originally Posted by Predwolf View Post
What kind of power are they putting down with the tunes/bolts?
There's a 5.9 for sale up here for $3200, and although I don't have anywhere near that much, it's got me interested in them. I wanted a 5.9 Dakota for years, but I'd rather have a 5.9 ZJ.
for myriad reasons, the grand cherokees tend to be faster stock for stock, and mild mod for mod, than the dakotas. The dak's CAN fit a nice set of longtubes however, and that's where they'll start showing a difference from the gc's. Still a cold day in hell to get one to out-launch the jeep though
I've never thrown either of mine on a dyno, so i couldn't say. There are others with similar mods who have, however, and while the HP numbers are hard to get out of the 200's with just bolt ons... the torque gets pretty impressive - approaching 400 lbs isn't unheard of in an otherwise healthy 5.9 - and its a FAT torque band - not peaky, just meaty. If you've ever been a classic mopar fan, it's pretty much the same formula.. everything about this motor responds the way a classic v8 would - these magnums are little changed from their 50's and 60's ancestors.
in the black one, the mild cam doesn't really make more peak power (might make an extra 7-10hp, and similar tq) - but it makes a good deal more power under the curve.. again never having dyno'd myself, some guys on the jeep forums are reporting gains of +35lbs in the 2500-3500 rpm range.
If you do look to get one - they do have some very specific (but potentially expensive) common problems that you should look out for when buying. They're pretty solid, and mostly unstoppable, but there are things to be aware of - hit me up if you start shopping
Goatcrapp is offline   Reply With Quote
Old 01-17-2013, 01:58 AM   #4406
soslow
Member#: 95027
'13 BRZed
pretend racecar
I'm going tomorrow to look at a 98 Grand Cherokee, supposed to be a limited. Not sure what motor. Has 172,000 miles on it, $1,500.
soslow is offline   Reply With Quote
Old 01-17-2013, 10:31 AM   #4407
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
Now with new shoes.
K Dub is offline   Reply With Quote
Old 01-17-2013, 10:35 AM   #4408
Predwolf
Member#: 54292
Awesome!
I'm not looking for a powerhouse, just was wondering what kind of gains can be seen out of the engine as I've heard it's pretty stressed from the factory.
Thanks for the info, and I'll hit you up with a PM if I ever do decide to jump on board!
Predwolf is offline   Reply With Quote
Old 01-17-2013, 10:42 AM   #4409
PGT
Member#: 57283
w/ 4Matic
Originally Posted by K Dub View Post
Now with new shoes.
clip-on weights? did you kick the shop that mounted them for you?
Old 01-17-2013, 10:46 AM   #4410
tylerq219
Member#: 68213
'92 MaxAttack Justy
'16 Hyper Blue sti
clip on weights on AEVs!? id kill someone.
tylerq219 is offline   Reply With Quote
Old 01-17-2013, 10:54 AM   #4411
tylerq219
Member#: 68213
'92 MaxAttack Justy
'16 Hyper Blue sti
anyone have to deal with the head issues yet on the 3.6? It seems like that's all I do nowadays.
can you tell which cylinder had a misfire? haha
That and sand in the motor from manufacturing is killing us now. You have to replace the heater core, radiator and take out the freeze plugs to scrape out the sand. If that dosent work, replace the motor...
heater core in a '10
Don't even get me started with the Dart, rust issues with 500 miles on them
Old 01-17-2013, 11:00 AM   #4412
PGT
Member#: 57283
w/ 4Matic
you work at a dealer? mind looking up a P/N for a silver steering wheel bezel from the '13 Freedom Edition or Rubi 10th Anniversary? Looking for something that matches the bright silver in my '12 MW3. My local dealer says it costs $450 for silver while the standard black is $15 and titanium is $120. That maka no sinse.
Old 01-17-2013, 12:38 PM   #4413
tylerq219
Member#: 68213
'92 MaxAttack Justy
'16 Hyper Blue sti
P/N 1TE64SZ6AA BEZEL SIL RUIB
That's what my parts guy can find without the VIN. Im guessing its right. $151.29
Old 01-17-2013, 01:05 PM   #4414
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
Those wheels/tires were road force balanced on a Hunter Road Force machine.
I TOLD them to use real weights, on both sides, to get the best balance possible. Sticky tape weights on the inside of the rim are not for real sized rims/tires. They are for Subarus.
I am very picky about tire balance.
Old 01-17-2013, 02:48 PM   #4415
Joe Boxer
Member#: 63119
** Memoirs of a
Serial Bachelor**
I suppose that if the vehicle never (or rarely) sees rocks, you're fine. I imagine that the first rock to get after your wheel is going to rip the weight right off.
Joe Boxer is offline   Reply With Quote
Old 01-17-2013, 02:54 PM   #4416
PGT
Member#: 57283
w/ 4Matic
thanks. does that p/n account for the steering wheel buttons? I see parts lookups showing all the option codes (which are greek to me.)
Old 01-17-2013, 03:34 PM   #4417
tylerq219
Member#: 68213
'92 MaxAttack Justy
'16 Hyper Blue sti
it does include the uconnect buttons
Old 01-17-2013, 03:59 PM   #4418
soslow
Member#: 95027
'13 BRZed
pretend racecar
Some quick shots of the Jeep. Going to get some more info now
Thoughts?
Old 01-17-2013, 04:07 PM   #4419
PGT
Member#: 57283
w/ 4Matic
the good thing about rust is it shows where the leaks are quite clearly
Old 01-17-2013, 04:12 PM   #4420
Benhart21
Member#: 149617
Makes me glad I live in an area where rust is rarely an issue.
Benhart21 is offline   Reply With Quote
Old 01-17-2013, 04:31 PM   #4421
K Dub
Member#: 210438
2012 Jeepfiniti
G37X Rubicon
Not if you put your tires ON the rocks, like you are supposed to
Really though, I gave up rock crawling almost 10 years ago.
If I were rock crawling I would never run those tires or those wheels. I'd be running 15X8 black steelies, with bias play swampers. And those, well those you don't even bother trying to balance.
Old 01-17-2013, 05:14 PM   #4422
tylerq219
Member#: 68213
'92 MaxAttack Justy
'16 Hyper Blue sti
soslow: the jeep looks like its been sitting for a long time. No battery, flat tires, tons of rust. Id go through that thing with a fine tooth comb. Already those brake lines look scary. But you do have the uber rare running boards.
Old 01-17-2013, 05:36 PM   #4423
soslow
Member#: 95027
'13 BRZed
pretend racecar
Thanks, it has been sitting since August.
It does start and run but when I tried to put it in 4-LO it would pop right out as soon as I put back into Drive. I think I'm going to pass since I don't yet need a 4wd.
ALSO: For the life of me, I can't figure where the front CV driveshafts are... Am I blind? They look plugged and come to think of it that makes since because the rear and front tires are different sizes (225/70 fronts 225/75 rears which would typically tear the full time case up.
Old 01-17-2013, 05:44 PM   #4424
PGT
Member#: 57283
w/ 4Matic
thanks again.....local dealer ordered it for me to swap out for the titanium color version they tried to pass off on me.
Old 01-17-2013, 06:16 PM   #4425
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
That's the rare 2wd option lol.
PARANOID56 is online now   Reply With Quote
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 07:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 06:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 04:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 01:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 09:17 AM
