Old 01-17-2013, 05:52 PM   #1
mike.bryan.94
Member#: 331884
Default i need help with my accessport
ok, i have a 04 sti with a perrin intake, mbc, fmic, and a whole bunch of other mods. i understand that the accessport only wants you to have a stock intake or the cobb sf intake. can i work my way around that? also i read that your not supposed to have a mbc when tuning through the accessport. help please
-thanks
mike.bryan.94 is offline   Reply With Quote
Old 01-17-2013, 05:56 PM   #2
big_scoggs
Member#: 206090
Oh god get ready lol
big_scoggs is offline   Reply With Quote
Old 01-17-2013, 07:02 PM   #3
wildt267
Member#: 161812
06 Wrx STi
CGM
Yes there is. Tune it. Get it to a legit tuner. Pay the $500 and enjoy good drivability, acceptable fuel mileage and a fun car. Or you can kiss your ringlands good bye. In the long run it will just be easier to do it right, do it once and just enjoy your car.
wildt267 is offline   Reply With Quote
Old 01-18-2013, 07:59 AM   #4
Cobb Tuning
Member#: 4803
-thanks
In order to use the off-the-shelf (OTS) maps we have designed for this car and the AccessPORT, you must use either the stock or Cobb SF intake. Using any other intake could potentially cause load errors, which would cause problems with fueling and timing (with potential engine damage). You must also use the factory boost control set-up, which would require removing the MBC, restoring the factory boost control solenoid set-up and factory restricter pill. More details about the boost control system here:
http://www.cobbtuning.com/Technical-...es-s/70674.htm
You can, however, get a custom tune through a protuner or e-tuner for the AccessPORT for you existing mods. This is where a tuner would create and revise a custom map for your car that you could use. A list of tuners that tune for the AccessPORT can be found here:
http://www.cobbtuning.com/Dealer-Ret...or-s/70471.htm
Bill
Old 01-18-2013, 01:35 PM   #5
mike.bryan.94
Member#: 331884
thanks for the information everybody. i am just going to go see a professional tuner and go from there
