Old 01-14-2013, 05:53 PM   #2251
garudatwo
Member#: 322385
Placebo effect?
garudatwo is offline   Reply With Quote
Old 01-14-2013, 06:13 PM   #2252
OUScooby
Member#: 100449
'04 WRX 307whp278tq
03WRX wgn, '72 MGB
Originally Posted by Asymmetry View Post
Hacked group-N gearbox mount, all the stiffness but 60% less NVH
huh?
OUScooby is offline   Reply With Quote
Old 01-14-2013, 06:21 PM   #2253
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
looks like a terrible idea
m1r4g3 is offline   Reply With Quote
Old 01-14-2013, 06:39 PM   #2254
IkariEvn
Member#: 251099
2004 WRX
Originally Posted by tuzzio View Post
Not exactly unique, it's been done before. But certainly not common in most 05-07's:
Love the head unit. I have the same one. One of the best purchases I ever made.
IkariEvn is offline   Reply With Quote
Old 01-14-2013, 06:46 PM   #2255
Asymmetry
Member#: 92646
MY03 WRX Toaster
Originally Posted by Dale2011WRX View Post
How is that possible?
Less contact with the chassis in normal conditions less vibrations. under load the center will close the gap in the middle making it stiff. OEM mount has the same principle with the center triangle piece but further apart, ie more slop. I basically replicated the OEM 5MT mount with stiffer compound and less gap when under load.
I had the solid mount and couldn't stand the NVH, this is isnt much louder, works great.
Asymmetry is offline   Reply With Quote
Old 01-14-2013, 08:10 PM   #2256
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
It's amazing that an automotive engineer never figured that out.
Dale2011WRX is offline   Reply With Quote
Old 01-14-2013, 08:58 PM   #2257
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Interesting I did a similar thing to my Grp N mount, focused more on replicating the stock voids to make the mount more vibration absorbing. It worked well as a "happy medium" in my case.
Power6 is offline   Reply With Quote
Old 01-14-2013, 09:14 PM   #2258
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
Default Hardwired GPS
Originally Posted by P-Train View Post
Might steal this idea
Its pretty easy since the wiring for the auto dimming mirror is already there, and I used the mounting hole from the stupid little sunshade thingy.
thrasher is offline   Reply With Quote
Old 01-14-2013, 09:54 PM   #2259
Asymmetry
Member#: 92646
MY03 WRX Toaster
They are aware but would go a softer compound like a 6MT gearbox mount that is solid.
There is no solid soft rubber 5MT OEM mount, actually there is a GC8 STI RA mount is solid 5MT but all too old to be of any use.
Not sure what your GRB mounts looks like, they may be an improved designed over the GC/GD mounts(?)
Neat job! How did you cut it out? I was going to do a similar configuration but thought it was too much hassle to cut it all out, single line was irritating enough.
You were in a similar position as me, need a 5MT mount, choices are OEM too soft, or way too hard Group-N, aftermarket is worse.
Yep works well!
Old 01-16-2013, 11:36 PM   #2260
kh15
Member#: 132400
2006 WRX
hahah somewhere engineers are passing pictures of that around laughing.
"Hey bill come look at this ****"
kh15 is offline   Reply With Quote
Old 01-16-2013, 11:42 PM   #2261
easterbran
Member#: 307359
'05 STi Stage II
*reads this post
"How do they know?"
easterbran is offline   Reply With Quote
Old 01-16-2013, 11:46 PM   #2262
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
HT Autos side bottom line kit for the 2008+ WRX/STI dremelled down to size and installed on a bugeye. (front = JNA lip, rear = OEM lip with lower half wrapped in black vinyl)
test fit before cutting:
Will be wrapping the sides in gloss black vinyl soon to match the front/rear, redoing the rear, and want to further modify it to look like the S206 pieces http://i1219.photobucket.com/albums/...eFromDBphp.jpg
I know HT Autos has an 02-07 kit as well which is 'direct fit.' I actually own a set of those too (for sale soon). Test fit both and ultimately went this route. Couldn't be happier
silverF4turbo is offline   Reply With Quote
Old 01-17-2013, 12:15 AM   #2263
Darth Wagon
Member#: 269713
2015 Forester XT
Nice job all the way around, that's a sweet looking bugeye! The sides tie the front lip and rear diffuser together really well.
Darth Wagon is offline   Reply With Quote
Old 01-17-2013, 12:16 AM   #2264
Bradrcr
Member#: 276382
2005 SaaBeeru
Nice mod, the gloss will tie that together really well.
Bradrcr is offline   Reply With Quote
Old 01-17-2013, 07:54 AM   #2265
emazz104
Member#: 281811
04 WRX
World Rally Blue
Looks really good! Why did you choose the 08+ version over the 02-07? Is the fitment that much better? I'm waiting until spring to get a set, so maybe I'll go with 08+ instead.
emazz104 is offline   Reply With Quote
Old 01-17-2013, 08:39 AM   #2266
tuzzio
Member#: 292532
05 STI
That's a uh, interesting trunk lid set up...
tuzzio is offline   Reply With Quote
Old 01-17-2013, 05:43 PM   #2267
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
Thanks!!
Few reasons... the 02-07 appears designed for factory WRX sideskirts and with my slightly thicker OEM bodykit sideskirts I had difficulty lining up the bolts myself. Might have fit with some work, but didn't bolt up directly. Haven't heard of anyone having fitment issues with factory WRX sideskirts. Also, the 08+ is polyurethane, and the 02-07 version I have is flat-painted fiberglass (easier to vinyl-wrap urethane). HT also make a 02-07 polyurethane but it's two pieces. Finally, I thought the 08+ fits closer to the OEM bodykit sideskirts on my car, whereas the 02-07 hung down a little bit. I feel like the 02-07 would have looked better on my own car if I had a more aggressive front lip.
Thanks it's one of my favorite things on the car
(same setup on the gt-r in the background)
https://bugeyegarage.wordpress.com/category/mines/
Old 01-17-2013, 05:52 PM   #2268
atf78
Member#: 9017
2011 WRX 5dr
405whp 385wtq
After living with my scoop vent for a few days (original post), I wasn't completely satisfied with the way it turned out. Decided to go back to the drawing board and tweak it significantly.
I've decided to make something similar to the Aqua reverse scoop that is available for the 02-07 models. It's still a work in progress, but here's what I've got so far. My next step is to fiberglass and than bondo for a smooth finish. I will be spraying it WRB to match the car. It will be my first attempt at working with fiberglass so this will either work, or be a massive failure
Making the basic structure out of aluminum sheet.
Filled with expanding spray foam, trimmed and than sanded down to the almost final shape.
Side view. On the car it should look like a bulge that is incorporated into the factory hood.
atf78 is offline   Reply With Quote
Old 01-17-2013, 06:40 PM   #2269
cuztomimportz
Member#: 97904
World Rally Blue
I have a felling I'm going to enjoy the outcome of this ^^^
cuztomimportz is offline   Reply With Quote
Old 01-17-2013, 06:40 PM   #2270
cuztomimportz
Member#: 97904
World Rally Blue
Feeling*
Old 01-17-2013, 07:26 PM   #2271
tuzzio
Member#: 292532
05 STI
Finished my center console today, including wiring the innovate:
Old 01-19-2013, 09:06 PM   #2272
emericareaper2
Member#: 323008
02 WRX minivan
Not the most unique but fully functional & compatible. I also did this in my previous Subie. I use my GPS quite a bit (pizza delivery) & also charge my iPhone with it.
I wanted a new shift knob. The only appealing one was the STi one, but it had the 6 speed grid on it. So, I got this one & did a little "customizing". Now I won't have to explain to anybody why I don't have a 6-speed.
emericareaper2 is offline   Reply With Quote
Old 01-19-2013, 09:35 PM   #2273
garudatwo
Member#: 322385
If someone delivered my pizza in a WRX I'd tip him extra
Old 01-20-2013, 03:25 AM   #2274
Bradrcr
Member#: 276382
2005 SaaBeeru
Hey dude, I deliver kegs in the Saabaru! a few saabaru owners delete the amber, and have the side flasher blink through the hole left by the amber removal. Just replaced the bulb with a slightly flattened female clip:
Then fill in the hole with a triangle shape piece of chrome, or in my case, cut & stick mirror and put in an LED replacement; much improved look:
Old 01-20-2013, 06:15 AM   #2275
sc00by4life
Member#: 97135
thats how the mines spoiler was designed to be used.
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
