#26 |
Member#: 318667
Vehicle:2002 WRX Wagon Black |
Really?! I would think that would be kind of dangerous? I just asked him anyway and he said its at 7. This motor spun to over 8 on factory tune but it has the 02 WRX ecu. This issue just really makes no sense to me. All I can think of its the in the head and a valve is bad or something. I just wish I at least had a check engine light to have a clue. Im gonna drop the car off at their shop and have them dive in- leak down test, check fuel pressure, hopefully not have to build me a new 2.1 stroker....
#27 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
Not like he's seeing. The rev limiter is very consistent, it always kicks in at the exact same RPM. The RPM may bounce a hair higher before dropping back, but that's not what he's seeing. The rev limiter is most certainly not his problem. |
#28 |
Member#: 51961
RMIC
This issue is VERY common. Almost everybody who's been around Subarus for a while has seen it before on their car or a friend's car. It's not the rev limiter, it's not launch control. What it IS, is very hard to say, because it seems like everyone who has this problem finds a different solution. For one person it might be the speed sensor, for another a crank/cam position sensor, for another it's a throttle position sensor, etc. It seems like it's always a sensor of some sort, but as far as I can tell there is no way to know which one without arbitrarily swapping them out until the problem disappears.
#29 | |
Member#: 343299
NESIC
Vehicle:05 Impreza wrx Rally blue |
#30 |
Member#: 327229
South East
Vehicle:2005 Wrx Java Black |
The first thing I would check :everything to do with fuel, such as sensors, gaskets, filters ,lines, injectors, rails etc..
I know its very broad but so is your problem. As some of the other members said this is a some what common problem, but everyone has had a different solution. I would start general and move into the specifics. Something is not flowing right, and my guess would be involving A/FR. Just because your gauge or AP says you might be running the proper a/fr doesn't mean its 100% accurate. A O2 sensor could be loose throwing it off etc.. Also another common reason for engine cut or fuel cut is over boosting, check your waste-gate duty cycle. *please note that this doesn't mean i'm right, its just what I would do, hope this helps.* |
#31 |
Member#: 332887
Tri-State
Vehicle:2012 WRX stage 2+ DGM (sedan) |
Idk why I didn't ask this sooner... did you check for any codes?
#32 |
Member#: 100300
MWSOC
Vehicle:06 WRX CGM |
don't rev past 5000.
But seriously, good luck man. I hope you find it quickly and easily. |
#33 |
Member#: 343889
International
Vehicle:96 v2 sti white |
normaly , when the car wont rev above the 5k area it is caused by the vehicle speed sensor
easy way to check would be to pull the vss plug off and try the car out briefly if there is no change at all then that is most likely the cause |
#34 |
Member#: 318667
Thanks everyone! Ill have some time this evening to try a few more things. The crank and cam sensors we're easy to get but the vss is not so easy, not stocked anywhere and pricey. I was gonna drop it off at the tuers shop tomorrow but a may try a little more on my own. Time is precious for a working student.
#35 |
Member#: 336702
South East
Vehicle:2002 WRX Blue |
Wondering if you got anywhere with the issue? My 02 WRX was doing the same thing, and I found it was the speed sensor. My crank sensor went out in the midst of a '06 LGT trans swap. I fixed it and then realized that we never put the speed sensor in the new trans and my car was in a sort of "limp mode." Unhook the battery and take it for a spin...see if you can rev normally. Vss replacement whenever you can, its a pain, but I have to do it too! Good luck!
#36 |
Member#: 336702
South East
Disregard the "wondering if you got anywhere" bit. been reading to many forums and thought this was an older one. Sorry!
#37 |
Member#: 318667
I tested the speed sensor today, no change. I simply don't have time to work on this rigbt now. So i dropped it off at NF performance for them to give it a go. I think they are the best option and i know they have a very good reputation, im sure they'll have it going by the weekend.
#38 |
Member#: 336702
South East
good luck, I am pretty much in the same boat. No time and much to do!
