Old 01-18-2013, 01:27 AM   #1
pharmer81
Member#: 341981
2008 STI
Charcoal
Default What is plugged in underneath the air cleaner in the passenger fender?
I'm still sorting through some things on my car. When I had the air cleaner out tonight, I noticed there was a wiring harness with two connectors underneath it inside the passenger fender well. There is a large two wire connector that looks similar to the one the smog pump plugs into, and then there is a smaller one beside it that looks more like the size of a micro usb cable end. What used to be plugged into these plugs? The car is an 08 STI. It's not for the fog light, because that is plugged in, but they are right behind the fog light.
pharmer81 is offline   Reply With Quote
Old 01-18-2013, 04:31 AM   #2
tac79phoenix
Member#: 342941
2008 Impreza WRX
Is it a yellow wire and a black (ground) wire together?
And does it appear to be a male end?
tac79phoenix is offline   Reply With Quote
Old 01-18-2013, 06:45 AM   #3
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
the daytime running lights relay?
Old 01-18-2013, 07:01 AM   #4
pharmer81
Member#: 341981
2008 STI
Charcoal
The large gray plug has a green and a white wire. I don't remember what the smaller plug had going into it. The big gray one was female. The smaller one I figured out. It fell off of the horn. They are both on the same subharness that comes from the headlight and radiator fan. I tried to take a pic of the gray one, but it didn't turn out very good.
Message Board Statistics All times are GMT -4. The time now is 10:24 PM.
