Old 01-07-2013, 08:56 PM   #1
hendo741
Member#: 40834
2009 DGM STi E85+
08/13 WRX,03 EVO,12 GT500
Default AP from Perrin
I am getting ready to purchase an access port, and my question if I should buy it from Cobb or Perrin. Will I still have access to all of the Cobb OTS maps as well as the Perrin maps?
hendo741 is offline   Reply With Quote
Old 01-07-2013, 09:10 PM   #2
hutch959
Member#: 267463
the perrin maps knocked to much in my car
hutch959 is offline   Reply With Quote
Old 01-07-2013, 09:17 PM   #3
hendo741
Member#: 40834
2009 DGM STi E85+
What year/model is your car? Do you have any mods.
For others that may read this or want to know, all I've done to my car so far is an Invidia q300 CBE, and I will install a DP next.
Old 01-07-2013, 09:17 PM   #4
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
All of cobbs ots maps are available on their website
Old 01-07-2013, 09:17 PM   #5
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
You can download all Cobb ots maps from their site
Edit: dang yea beat me to it
m1r4g3 is offline   Reply With Quote
Old 01-07-2013, 09:19 PM   #6
hendo741
Member#: 40834
2009 DGM STi E85+
So it's better to buy from Perrin. The price is the same, and that would give me access to additional maps at the same price. If the Perrin maps end up being to aggressive I can always use the Cobb maps.
Is my reasoning on point?
Old 01-07-2013, 09:29 PM   #7
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Your best bet is to PM boston motorsports for their best shipped accessport price. Then go to Eric at torqued performance.com then order whatever map you want for 85 bucks. This will give you a map that is an e tune. You datalog then send logs to Eric, he then makes adjustments to your car personally. This is the best option other than a protune. You will be better off and your car will thank you. Forget about any ots mapping from everyone.
Old 01-07-2013, 09:33 PM   #8
Ishart
Member#: 332001
I have a 200 dollar off coupon ill sell for 100! Buy my v1 and trade it in!
Ishart is offline   Reply With Quote
Old 01-07-2013, 10:00 PM   #9
hendo741
Member#: 40834
2009 DGM STi E85+
Once I go to stage 2 ill hit up TP, but plan on sticking with OTS for stage 1. I will look into Boston motorsports though, thanks.
Old 01-07-2013, 10:29 PM   #10
m1r4g3
Member#: 220476
WRB & SWP
if you are going with ots maps and waiting till later, who cares where you get it from. i am running a perrin map right now with no problems
Old 01-07-2013, 10:36 PM   #11
hendo741
Member#: 40834
2009 DGM STi E85+
Just wanted to verify that an AP ordered from Perrin will still have all the Cobb maps on it as well.
Old 01-08-2013, 09:49 AM   #12
Cobb Tuning
Member#: 4803
You will want to contact Perrin to see if they replace or add to the maps on the device. Really, it doesn't matter as you can download any of our OTS maps for your car from the maps section at cobbtuning.com. You then use the AccessPORT Manager software to transfer any of those downloaded maps to your AccessPORT.
Bill
Old 01-08-2013, 08:37 PM   #13
hutch959
Member#: 267463
2012 sti. at the time i was stage 1. no modes except the AP
Old 01-15-2013, 04:46 PM   #14
hendo741
Member#: 40834
2009 DGM STi E85+
Bill
Great. Thanks Bill.
Next question about the AP. Is it possible to install it on a vehicle without flashing a new map. I wanted to do a few stock data logs to make sure everything is running right before I flashed a stage 1 map.
Also, does a different air filter such as the Perrin drop in filter affect the OTS tunes? The map info on the Cobb website for stock air box also states stock filter. Is this an issue, or is the Perrin custom map the only one that I should run??
Old 01-16-2013, 10:45 AM   #15
Cobb Tuning
Member#: 4803
Great. Thanks Bill.
You can download the "installed stock mode" map from the maps section at cobbtuning.com and then use the AccessPORT Manager software to transfer the map from your computer to the AccessPORT. This will allow you to select it on install or you can reflash it later if you've already installed one of the performance maps. The "installed stock mode" map will run the stock tune while the AccessPORT is installed (allowing you to data log with stock tune).
In theory, an aftermarket panel filter could require tweaks to MAF calibration, but usually is not a concern (and certainly not to the level of using an unsupported intake with a particular map). We test with the stock panel filter for our stock intake maps and have not done any extensive testing with aftermarket panel filters to be able to say, for sure, one way or another.
Bill
Old 01-18-2013, 01:10 PM   #16
quoiasdaddy
Member#: 147711
2002 WRX/Stg 2
I've had a Perrin drop in filter for years and it hasn't affected anything as far as how it runs. I have 143k on my car now and put the filter in around 80k. No problems here! My car is on a Stg2 OTS Cobb tune.
quoiasdaddy is offline   Reply With Quote
