Old 01-18-2013, 08:34 PM   #1
04shizzel
Member#: 186206
13 wrx
Ice Silver Metalic
Hey guys, Finally got some logs for my car, and would like to have them reviewed. Im using the stage 2 93 lwg ots tune. I ran the reg 93 stage 2 and was getting slightly above target boost, so these logs are from the lwg map. Both logs are 3rd gear.
any feedback would be great.
thanks Dean
https://docs.google.com/spreadsheet/...FJzQ0YxWERfaVE
https://docs.google.com/spreadsheet/...Fg3Rkl3dWtzY3c
04shizzel is offline   Reply With Quote
Old 01-21-2013, 08:50 AM   #2
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
thanks Dean
Hi Dean,
Can you get a run from a lower RPM (starting at 2500 RPM in 3rd gear), if you can do so safely? This will give us a better look at how boost builds. Also add Inj. Duty Cycle to the logs (Via "Monitors" -> "Set Data Log List" menu). Thanks!
Bill
Old 01-21-2013, 09:55 AM   #3
04shizzel
Member#: 186206
13 wrx
Ice Silver Metalic
Originally Posted by Cobb Tuning View Post
Hi Dean,
Bill
I should be able to do that either tonight or tomorrow will add the injector duty cycle. I will post the logs once i get them done!
Thanks Bill
Dean
Message Board Statistics All times are GMT -4. The time now is 05:31 AM.
