Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 02-24-2007, 05:04 PM   #101
actionyoo
Member#: 125119
Default Radio Antenna
I did the installation and it worked fine. Attaching the 13 pin to the ground at the top of the radio has eliminated the ground loop hum.
Only one problem. While completing the installation, I managed to pull out the antenna wire from the radio. It appears to be a devil to reattach it. I contacted the Subaru service people about it and they said it required a special tool which they did not have.
Anyone out there no how to reattach the antenna wire to the radio?
actionyoo is offline   Reply With Quote
Old 11-24-2008, 05:27 PM   #102
bethurem
Member#: 195452
Default audio booster? plus full-time RSE
Thanks to scot3818, Kmartin, and all others who posted this data. I just got my MP3 player working on my '06 Tribeca.
A few things to clarify, I was a bit confused on how to enable the RSE without hooking up a power/ground to my MP3 player.
KMartin's post was a bit confusing as it kept referencing pin numbers on that connector and I don't know what pin is pin1 vs. pin16. So this is what I did to enable the RSE without having a power/ground connection to the MP3 player.
Just hook up the left, right and ground to the stereo as in scot3813's PDF File. Then, I just added another ground wire from the back of the stereo (where I attached the MP3 player's cable ground) to the chassis of the radio. Thats it. Just one extra wire. Works great. When I want CD, just press the CD button on the radio, AM press AM. MP3, press RSE. Easy.
So now that i've got this all hooked up, the audio out of my MP3 player is not as loud as the AM/FM Radio. I have the output volume of the MP3 player max'd. But its not as loud at the same radio volume as the AM/FM or CD modes.
Does anyone know of a volume booster that I can put inline with my MP3 player?
Thanks,
JB
bethurem is offline   Reply With Quote
Old 11-24-2008, 06:28 PM   #103
HB_Dad
Member#: 45190
2014 Impreza Sport L
Thanks,
JB
The DVD player's volume is also lower than the stock radio/CD, so it must have something to do with the head unit itself.
Does anyone know if there is a way to tap the aux-in with a 2-channel switch so both rear-DVD and and aux jack can be routed to the same button and be selectable by said switch?
HB_Dad is offline   Reply With Quote
Old 11-25-2008, 01:03 AM   #104
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Thanks,
JB
You could get a Fiio E3 line booster from Ebay for $6.99 + $4.99 shipping. I hear reports that it sounds decent. Stay away from the Radioshack boostaroo clone. All the ones I know for a fact are decent are over $60, so I wont post them unless I see a reply from you wanting more info. Heck, I have several portable headphone amps that cost $450-500, but that's another story.
ImprezaRS dot com is offline   Reply With Quote
Old 11-25-2008, 10:54 AM   #105
bethurem
Member#: 195452
Thanks, I just ordered one. Its says it gets 20 hours out of a AAA battery, if so, thats decent.
Thanks,
JB
Old 06-03-2010, 01:57 PM   #106
djfromgr
Member#: 94950
2002 Subaru Impreza
Blue Black Mica
Sorry for bumping this old thread, but does anyone still have any of the pictures or the power point presentation that was put together for this. Please let me know as I would like to do this with my wife's Tribeca.
Thanks!
djfromgr is offline   Reply With Quote
Old 06-04-2010, 04:45 AM   #107
ImprezaRS dot com
over boosted again
Member#: 1458
Yeah, I think I could use a copy of the pdf or powerpoint presentation, as I'm ready to do the mod too. My mail is larryganz at hotmail (dot) com if that helps.
Thanks!
Old 06-12-2010, 02:16 AM   #108
kmartin
Member#: 65346
2012 Outback 3.6 Ltd
Ruby Red
Thanks!
This wonderful Powerpoint document (complete with pictures!) was compiled by "slackr"on the NASIOC forum at:
http://forums.nasioc.com/forums/show...=896215&page=4
I did add some info about the ground wiring instructions for permanently activating the RSE button (near the end of the document). Although I am not a professional technician nor an electrician, feel free to contact me with any questions, or refer to the NASIOC forum directly. My setup has worked perfectly so far since 2-2-07.
FYI: viewing the radio connector from the back of the unit, pin 16 is the LOWER LEFT, followed to the right by 15, 14 and then 13.
http://members.cox.net/kamartin/AuxInstall.pdf
-Karen in AZ-
kmartin is offline   Reply With Quote
Old 06-12-2010, 06:28 PM   #109
kuoh
Member#: 127558
Nice work Karen, but I want to clarify my recommendations about the grounds. Pin 13 is the RSE enable, which should be wired directly to a ground, one of the nearby screws should do. Pin 14 is the signal ground for the AUX input, which should be kept separate from the vehicle ground and pin 13 for best results.
KuoH
kuoh is offline   Reply With Quote
Old 06-12-2010, 10:25 PM   #110
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
If someone can post some clear, close-up pictures of connector "i26" (the 15 pin connector that you're adding the aux wires to), I may be able to get the correct pins to snap into the plug. Perhaps even the shells to make a plug-and-play insert harness. Either way, much cleaner than the "shove wires into the holes" method
I need to see the pins side of both plug and socket. The top, bottom, and either left or right side of the car's harness plug would also be helpful.
SVXdc is offline   Reply With Quote
Old 10-18-2012, 12:48 PM   #111
uallanman
Member#: 335447
Default Newbie
Hi Everyone ...just picked up my used 2006 Tribeca yesterday. Would love to get a link to some of installs mentioned here about useing the aux feature for an Ipod or mp3 player..thanks..
uallanman is offline   Reply With Quote
Old 10-20-2012, 11:52 PM   #112
avk
Member#: 17252
'06 WX8
59E
That can be found on SB9T.
avk is offline   Reply With Quote
Old 01-19-2013, 05:15 PM   #113
iphonephanatic
Member#: 344117
Originally Posted by slackr View Post
I took the liberty of gathering the pics and instructions from scot3818 and Daloosecannon and created a powerpoint presentation. Thanks to those of you who took the time and risk to get this set up. Let me know if you would like me to send it to you.
Could you send me a copy of that presentation?
iphonephanatic is offline   Reply With Quote
Old 01-19-2013, 08:56 PM   #114
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
I attached a copy of that PDF to my post on SB9T here. However, the information in that guide is now obsolete -- read my post for details.
So please register on that forum (if you haven't already) and continue the discussion there.
Anyone know how to release the pistons in the rear calipers of this vehicle? BGPunk2001 Off-Topic 6 05-16-2009 04:07 PM
Anyone Know How To Tune A 05 Rs In The Hanover Pa Area????? smithrcing17 Open Source Reflashes 14 02-26-2009 06:53 AM
anyone know how to install a aux jack or wire for an iPod? db97 Car Audio, Video & Security 13 12-25-2007 03:45 AM
Anyone know how to install the JDM HIDs in an 04 ? Whiplash Interior & Exterior Modification 0 09-04-2003 04:45 PM
Anyone know how to remove the orange bulb cover in WRX headlamps GenMaster Interior & Exterior Modification 6 02-05-2002 02:20 PM
