Old 01-14-2013, 10:51 PM   #351
Layvon
Member#: 195711
STi 04/05/06/07
I really sucked at physics and didn't take chemistry, but this means that double the air pressure means double the volume thus fuel can simply double if the same afr was desired?
Which is supported by the fact that as you go from 100kpa to 200kpa on a map it is more than double because of the desire to be richer at 200kpa than 100kpa.
Old 01-15-2013, 01:00 AM   #352
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Log all your starts. Junior could use that info to tweak your map.
Old 01-15-2013, 07:59 AM   #353
Layvon
Member#: 195711
STi 04/05/06/07
I will do that. I tried a different approach this morning before leaving for work. I was way too rich but I did get a log in that I can send out.
Still running pretty darn rough for the few seconds it was running though.
Old 01-15-2013, 10:55 AM   #354
kellygnsd
Member#: 32669
LINK G4 hybrid STi
What are your AFRs during warmup?
Old 01-15-2013, 12:02 PM   #355
Layvon
Member#: 195711
STi 04/05/06/07
10 or less. Var only runs for 4-5 second.
Old 01-15-2013, 12:47 PM   #356
kellygnsd
Member#: 32669
LINK G4 hybrid STi
My car felt happy with AFRs between 12 and 13 during warmup. Sub 10 may be too rich.
If you don't feel comfortable or confident with the changes you need to make I'd wait for backup.
Old 01-15-2013, 12:58 PM   #357
Layvon
Member#: 195711
STi 04/05/06/07
I'd rather be rich and lean out that's not to o tough. Ill drop back some fuel and see if it improves . I still plan on sending junior a log to look for suggestions anyways.
Old 01-16-2013, 09:35 PM   #358
Layvon
Member#: 195711
STi 04/05/06/07
Ordered my flex fuel sensor tonight. ****s about to get fun.
Old 01-20-2013, 02:11 AM   #359
Layvon
Member#: 195711
STi 04/05/06/07
Saw the new motor for the Fozzy in action today at the auto show.
2.0, 250hp, Low mount Turbo, direct injection, and dual AVCS (from the look of it), Pretty cool looking. It was a Honeywell Turbo with a .60 AR. I couldn't see if it was a twin scroll or a T3 flange.
I couldn't tell if it was the actual drive or just for the model motor but the timing chain was interesting, and also that they used rocker arms vs buckets.
Old 01-22-2013, 10:29 PM   #360
Layvon
Member#: 195711
STi 04/05/06/07
Can't get this running. I played with fuel quite a bit tonight and thought I had AFRs right at some point. Guess I will have to look at timing. Something I know nothing about.
Just want to trailer it to P & L and be done with it.
Old 01-22-2013, 10:33 PM   #361
kellygnsd
Member#: 32669
LINK G4 hybrid STi
That's what your wideband is for. Add or subtract fuel as necessary.
What base map are you starting with?
Old 01-23-2013, 05:55 AM   #362
Layvon
Member#: 195711
STi 04/05/06/07
Fuel I had right in the thirteens and it would run rough then die. It was a combination of the base map that was included and looking at Antons map to check out fuel.
"Subaru V10 top board plug in" is the name of the map I've been modifying.
Old 01-23-2013, 06:42 AM   #363
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
I'm sure that you know that Anton's running ID1k injectors correct? You've compensated for the difference in your injectors as well as base fuel pressures?
Old 01-23-2013, 10:06 AM   #364
Layvon
Member#: 195711
STi 04/05/06/07
Yes l did. he's at 1375cc/min and I'm at appx 2300
Old 01-25-2013, 07:42 AM   #365
Layvon
Member#: 195711
STi 04/05/06/07
Somehow summit racing is going to get me my fuel line stuff to go from my ethanol sensor to surge tank. I needed a couple 90s and about 10" of -6 line. I ordered Thursday at 6pm. I will have it by saturday with the normal shipping. Gotta love it.
I'm also going to hook up the knock block this weekend. That shouldn't be too bad. I'm currently making myself a pin out diagram so I dont have to keep coming to check computer when I am working on it. Like I said, not that bad, just have to heat the garage up and do it.
The thing I'm not that thrilled about is my ethanol sensor. I plan on pulling voltage and ground from the fuel pump, because that is relay controlled and works well. The thing I dont know what in the hell to do is wiring in the damn output. I haven't looked into it that much, but it is slightly embarrassing.
I dont know which digital input is worth sacrificing for it. Was thinking the Air Conditioning request, but that is a useful button for a switch or something in the future... but I do have the cruise switch too I guess. Looking for some input for Anton / Kelly / Dominic on this one
Old 01-26-2013, 03:02 PM   #366
Layvon
Member#: 195711
STi 04/05/06/07
According to what my newly hooked up Ethanol sensor is reading, I have 2.8% ethanol in the tank right now. It has been sitting for a while, I'd estimate that this tank of gas is 2-3 weeks old. I need to get a few gallons to throw into it to see what she does then.
Old 01-26-2013, 03:08 PM   #367
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm guessing it 93 octane in the tank right now and not E85?
Old 01-26-2013, 03:22 PM   #368
Layvon
Member#: 195711
STi 04/05/06/07
Correct. I just measured it with a multimeter. Not hooked into the computer yet
Old 01-26-2013, 03:36 PM   #369
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Does your sensor have a 0-5V out? How did you read it with a meter?
Old 01-26-2013, 04:22 PM   #370
Layvon
Member#: 195711
STi 04/05/06/07
Well it spits out the signal.to go to ecu. I just put the neg on the battery terminal since it is wired directly through it. Fused of course.
In other news. I think I bought a big enough filter. Barely fit
Sorry for quality ... phone picture and upload.
aiming to get my knock block and IAT sensor wired in tonight yet, but tough to say if it will get done, I have to go over to parents to sing happy bday to my dad so depending how out of hand we get ... might not work on it tonight. MAF wires are the ones dangling there, I haven't snipped them off yet. Starting to come together!
Kelly - Do you have any idea about the Ethanol sensor question i asked?
Old 01-26-2013, 05:03 PM   #371
kellygnsd
Member#: 32669
LINK G4 hybrid STi
You're not using the cruise switches anyway unless you're using them for map switching.
Old 01-26-2013, 06:23 PM   #372
Layvon
Member#: 195711
STi 04/05/06/07
Okay thanks - I will be using a flex map so to speak so I won't need any map switching I hope.
The real concern I had was about which auxiliary output to hook it to for 5v. Like I posted above I don't know what 5v auxiliary outputs can be sacrificed. Is a GP output configurable to be 5V all the time?
Old 01-26-2013, 06:29 PM   #373
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Its not a 5V output, there is a 5V bus used to power sensors and such. I have +5V, +8V, and +12V pins on my ECU but mine is the universal one.
Old 01-26-2013, 06:44 PM   #374
Layvon
Member#: 195711
STi 04/05/06/07
Hmmm. That would be what I'm looking for
Does mine have one pf those?
Old 01-26-2013, 07:09 PM   #375
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Any 5V switched source would work if you can find one.
Maxwell Power EFR 7670 Bariga Proven Power Bragging 2042 12-06-2015 02:26 AM
WTB : 2002-2007 WRX/2004 STi Strut Assemblys, Rally Armor Flaps wrx. NWIC Private Classifieds 0 11-13-2011 06:49 PM
FS : NJ: 2004 STI Race Build dsds711 Private Vehicle 'For Sale' Classifieds 22 03-19-2011 11:39 AM
2004 sti build questions GA_STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-09-2009 03:31 PM
2004 STI Parts from Racecar Build TxSpeed1 Complete Car Part-Out 36 03-21-2009 03:00 PM
