Welcome to the North American Subaru Impreza Owners Club Tuesday May 31, 2016
Old 09-14-2012, 12:52 PM   #101
JayBoogs
Member#: 285290
2008 Impreza WRX 4dr
Lightning Red Pearl (LRP)
Originally Posted by gotsquat View Post
I'm 99.9% sure those are aftermarket wheels, not Subaru OEM. They only resemble the JDM B4 wheel, and the B4's are 17".
Thanks. This is exactly what I figured. Just found out it was "off" of a legacy and he's the 2nd owner. So he doesn't know much about wheels.
JayBoogs is offline   Reply With Quote
Old 09-15-2012, 04:17 PM   #102
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Originally Posted by Mach V Dan
2005-06 Impreza
Offset: +55
Bolt pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 205/55R16
Those are not the wheels that came with my car. Mine look like this: gtcarlot.com/data/Subaru/Impreza/2006/573171/Wheel.html
Counterfit is offline   Reply With Quote
Old 09-18-2012, 09:38 AM   #103
Mach V Dan
Member#: 12029
Okay. I assume the specs are all the same? Any chance you can get us a weight?
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 09-24-2012, 11:25 PM   #104
gcs5656
Member#: 111923
2012 WRX
Default great info
This thread has a lot of good info on buying wheels!
gcs5656 is offline   Reply With Quote
Old 09-24-2012, 11:55 PM   #105
Counterfit
Member#: 124254
"The Scoobinator"
I may be able to weigh them when I changed for winter. It'll be approximate as the Ecsta SPTs on there aren't at 100% tread.
But otherwise, yes. 16x6.5, I believe it's +53 (probably the same offset as the 16" WRX wheels)
Old 10-17-2012, 07:26 PM   #106
trife86
Member#: 301368
2012 WRX
PBP
I have a 2012 wrx and bought a set of steelies for the winter, will I need differant lugs than the stock wrx ones?
trife86 is offline   Reply With Quote
Old 10-18-2012, 10:45 AM   #107
Mach V Dan
Member#: 12029
No.
--Dan
Mach V
FastWRX.com
Old 10-18-2012, 11:02 PM   #108
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
This thread is awesome, thanks for putting it together Dan!
JSchell1309 is offline   Reply With Quote
Old 11-01-2012, 02:59 PM   #109
Forevaclevah
Member#: 324345
What about the XV Crosstrek wheels? Does anyone have them yet?
Forevaclevah is offline   Reply With Quote
Old 11-14-2012, 09:04 PM   #110
fredrik94087
Member#: 337075
2015 Wrx Cwp6M Stg2+
Ohlins+STBs+(275/40/17)
Default 16x6.5 2013 legacy steel wheel 22 lbs
Please add this to the list.
I weighed wheel and tire at 45 lbs. Tires weigh 23 lbs according to tirerack, so I'd put the 16x6.5 steel wheels at 22 lbs.
fredrik94087 is offline   Reply With Quote
Old 11-20-2012, 03:00 PM   #111
Mach V Dan
Member#: 12029
I don't like to interpolate the wheel weight that way. Too much margin for error. For now I'll put it as "estimated."
--Dan
Mach V
Old 11-20-2012, 03:09 PM   #112
Mach V Dan
Member#: 12029
I could use a photo of that 2013 Legacy steel wheel, by the way.
--Dan
Mach V
FastWRX.com
Old 11-20-2012, 03:33 PM   #113
matigas_TT
Member#: 322775
2012 WRX-4Dr
Thanks for this'
matigas_TT is offline   Reply With Quote
Old 12-16-2012, 10:24 PM   #114
Jive Turkey
Member#: 219492
any one know if 06' impreza 2.5i wheels will clear sti brembo's? i need cheap wheels for winter that are 17's.
Jive Turkey is offline   Reply With Quote
Old 12-16-2012, 10:37 PM   #115
sc00by4life
Member#: 97135
Nope.
I thought you were 5x114? Use crv steelies?
Old 01-17-2013, 07:32 AM   #116
DOHBOYWRX
Member#: 314698
2005 WRX
White "Phatbotti Tuned"
I was wonderring if anyone knew where i could find the specs on the wheel studs of a 2005 wrx usdm?
DOHBOYWRX is offline   Reply With Quote
Old 01-17-2013, 05:52 PM   #117
Counterfit
Member#: 124254
"The Scoobinator"
A month late, but '06 2.5i wheels aren't 17".
Old 01-20-2013, 04:33 AM   #118
danlucer
Member#: 333651
2004 Impreza WRX
Alpine White
Unhappy My new BRZ wheels wont fit on my WRX!?
Hi, I could use some help!
I recently purchased some 2013 BRZ (and FR-S) wheels for my WRX before I realized they wouldn' fit-on over my upgraded 4 pot front brakes. I figure I could buy some spacers but I really don't want to space my tires outs at all. Anyone have any suggestions?
If I must use a spacer, what's the slimest spacer I could use?
The BRZ wheels have the following specs according to this thread
Offset: +48
danlucer is offline   Reply With Quote
Old 01-23-2013, 12:39 AM   #119
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
World Rally Blue
Specs on the JDM Subaru RAYS 16x7 please
Daddy_Digital is offline   Reply With Quote
Old 01-23-2013, 09:47 AM   #120
DuoofDeath1
Member#: 344537
2012 Mazdaspeed 3
Black Mica
This might sound stupid but why does Subaru do all the switching between 5x100 and 5x114 throughout the years? That just makes changing wheels a pain in the ass. Especially between the WRX and STi. Those should atleast be interchangeable, IMO
DuoofDeath1 is offline   Reply With Quote
Old 01-23-2013, 10:06 AM   #121
SATSTI
Member#: 341814
2013 STI
I didn't see anything on the current STI.
If I'm not mistaken, aren't the 2013's a 18 x 8.5 with a 5x114.3 (55 offset)?
SATSTI is offline   Reply With Quote
Old 01-23-2013, 11:16 PM   #122
Tavery92
Member#: 312331
Sedona Red
Hey guys, I hope this is the correct spot. I'm looking at new summer wheels for my 02 wrx(bone stock suspension, with no plans to lower the car) would I be able to use a 17x7 wheel running the oem option 225/45/17 without issues rubbing(using the oem wheel offset) or with the speedo being off(my car came with the 205/55/16) I'm in the very beginning of wheel shopping so I'm trying to get all the info I can about my options
Again I apologize if this is the wrong spot. Thanks
Tavery92 is offline   Reply With Quote
Old 01-23-2013, 11:53 PM   #123
paperdukie
Member#: 214796
2004 OBS
Yes, you'll be fine. The speedo will be minimally off, you won't even notice. My car came stock with the same size wheel and tire as you and I run 17x7.5 in the summer with 225/45/17 and have no issues at all. My car is lowered a bit as well and I'm still good to go.
paperdukie is offline   Reply With Quote
Old 01-28-2013, 03:41 AM   #124
Brock Samson
Member#: 207553
07 STi
Originally Posted by mpb6990 View Post
Any info on the 15x6 alloys from MY98 Impreza?
Not sure anyone answered the question about these wheels. Even though it's from a while ago, I figured since I bought these for my DD wagon I'd post up the info anyways!
Stock tire size ran 195/60 R15. Wheels are 5x100.
Brock Samson is offline   Reply With Quote
Old 01-29-2013, 09:35 PM   #125
Mach V Dan
Member#: 12029
So you didn't read this thread first, I guess.
Other than spacers? Sell 'em. Or downgrade your brakes to the older WRX style. I'm sure you could get plenty of volunteers to trade straight across.
How about you do a little work and then come back and tell us? Try stacking some washers on top of the studs until the wheel clears. (We use painter's tape on the caliper so it doesn't get all banged up.) When you get enough clearance, measure the height of your washer stack. That's how much spacer you need.[/quote]
It's not switching back and forth. Since 1993, all Impreza variants have been 5x100, EXCEPT the 2005+ STI. Because of the large amount of power and grip that car has, stronger hubs were needed; hence the larger bolt circle.
2013 STI wheel options carry over from previous years. Sedans get Enkei wheels standard; Limited sedans get BBS. Hatches all get BBS.
If I'm not mistaken, aren't the 2013's a 17 x 8.5 with a 5x114.3 (55 offset)?
You are mistaken. 2013 STI, like previous STI since 2008, gets 18x8.5" wheels. 2013 WRX, like previous WRX since 2011, gets 17x8" wheels.
Originally Posted by Tavery92 View Post
Hey guys, I hope this is the correct spot. I'm looking at new summer wheels for my 02 wrx...
This is not the correct spot. This thread is for OEM wheel specs only, not for fitment questions.
Cool. Can you get us a weight?
--Dan
Mach V
FastWRX.com
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
