Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 01-07-2013, 05:56 PM   #1
f0rz4m0t0rsp0rtf4n
Member#: 342257
2013 impreza premium
Marine blue pearl
Unhappy cold air intake or short ram intake for 2012 impreza 2.0L
help.is there any cold air intake for 2012 impreza 2.0L premium?
f0rz4m0t0rsp0rtf4n is offline   Reply With Quote
Old 01-08-2013, 01:07 AM   #2
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Im going to say no, not yet.
Get a NA intake for 93-07 it should work with in reason, and a MAF tube for the sensor with a generic filter. It may need to be modded a little in terms of pipe routing. Or you can always just buy some 2.75 -3" aluminum bends and coupler it all the way to the fender with a generic filter and the MAF tube.
Otherwise is a custom Fab job.....cha-ching!
In all reality you will see little to no gains
dangerousatom is offline   Reply With Quote
Old 01-08-2013, 01:32 AM   #3
dangerousatom
Member#: 70710
I didn't even realize either, but this should be in the NA or Nubies Forum, not Normally Aspirated with bolt-on Forced Induction Powertrain
Old 01-08-2013, 01:15 PM   #4
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Don't change you intake. You are likely to lose power or hurt the car. The stock intake is already cold air with the big scoop leading to the front grill.
jay25RS is offline   Reply With Quote
Old 01-08-2013, 01:23 PM   #5
Irongrave
Member#: 325040
2012 Impreza 5door
DMG
no gains to be had the stock intake flows very well and has the nice scoop off the grill area. You could open up the grill a little by removing some of the plastic. Add a drop in perrin filter and remove the pzev screen that would give you the best flow but most likely no gain in measurable horse power
Irongrave is offline   Reply With Quote
Old 01-09-2013, 06:07 PM   #6
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
ok. so i shld just stick w/ a dropin filter filter for now?
what abt suspensiuon wise?
Old 01-09-2013, 06:14 PM   #7
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
ok. well 2 days ago, i bought a drop in k&n air filter. felt lil HP gain till i picked up more speed. went looking around and found a MAF tubing and 2 couplers. i thought i could prolly use the stock sensors and bolt them on the MAF tubing.
Old 01-09-2013, 06:17 PM   #8
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
i was also sticking w/ 12 inch rims and go 215/45 tires...or 225/40. think that would be wise? i hate plus sizing the rims to 18s...they cost alot. i was hoping to go wider on 17 inch rims to acomodate the said tires sizes.
Old 01-09-2013, 07:58 PM   #9
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
made a booboo. meant 17 inch rims
Old 01-11-2013, 05:22 PM   #10
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Yep. What this guy said. Those engineers are pretty smart guys when it comes to flow/turbulence calcs.
Hoon Goon is offline   Reply With Quote
Old 01-11-2013, 05:27 PM   #11
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Unless you want to spend $$$$$ on some coil overs, the best bang for your buck is some beefy swaybars and endlinks. You will like and relatively cheap. Whiteline and others make some adjustables so you can get it feeling like you want in the twisties. Even just a stouter rear bar will do wonders for bodyroll and understeer and a rear bar is easy to install. The front takes a bit more work.
Old 01-11-2013, 08:38 PM   #12
XSV Klutch
Member#: 259013
2007 Impreza 2.5i
Greyish- Boosted
You need to do some research. You have been on this forum for less than two weeks and are asking questions in the wrong part of NASIOC that have already been answered many times. Pics will help you with you decision of what size tires to go with.
XSV Klutch is offline   Reply With Quote
Old 01-15-2013, 08:21 PM   #13
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
sorry bout that. my bad.
Old 01-17-2013, 01:51 AM   #14
Tenament
Member#: 246813
"Felt a little HP gain" Man, you must have ultra-sensitive buttocks brotha. I'm talking about laboratory-grade measurements, cause that drop-in k&n filter equates to virtually no gain in torque or HP for a horrible risk of running one of the world's marketing success stories. Please read up on how k&n filters actually impact our cars.
Tenament is offline   Reply With Quote
Old 01-17-2013, 06:03 PM   #15
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
will do. hehe
Old 01-17-2013, 06:46 PM   #16
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
well..looks like ill have to get that CAI system. better than the drop in version..at least w/ the CAI...ill get a few HP gain.
Old 01-17-2013, 06:49 PM   #17
Irongrave
Member#: 325040
2012 Impreza 5door
DMG
the factory system is cold air your not going to see gains on the intake side of things on this motor. Exhaust side there are some possibilities with removing the neck downs and such.
Old 01-17-2013, 06:58 PM   #18
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
i hear greddy may come with an CAI system. i hear they are doing a R&D on those. it will be awhile tho.
Old 01-17-2013, 07:00 PM   #19
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
axleback mufflers w/ the works will have lil HP. saw this on the perrin site.
Old 01-17-2013, 07:17 PM   #20
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
well, ill still do more search and get more advice on the mechanics. hehe
Old 01-19-2013, 02:00 AM   #21
ans2k
Member#: 315631
2012 Impreza Sport
wow... or just burn your money either way this isn't a sports car nor is it a "sporty" car. you are wasting time. just get a custom exhaust, better money spent. sway bars, suspension is also a good buy to make it feel sportier. also, if you have the factory 17 inch rims, you could run a 225/45 tire without changing the rim. but that will make your car much much slower.
Old 01-19-2013, 08:52 AM   #22
imprezafreak3
Member#: 184136
2013 WRX
PBP
how has this thread not been locked?
imprezafreak3 is offline   Reply With Quote
Old 01-19-2013, 10:35 PM   #23
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
What exactly is your definition of a "sporty" car?
OP, just look at what Rally Sport Direct has done with theirs. It's all spelled out for you.
geronimo81 is offline   Reply With Quote
Old 01-20-2013, 03:39 PM   #24
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
well, as of now, am working on exhaust system and suspension. i dont really need serious HP. if i really wanted to to, i would swap to a turbo engine and and a different drive train. but that's later on down the road. my warranty is not expired yet. hehe
Old 01-20-2013, 03:42 PM   #25
f0rz4m0t0rsp0rtf4n
Member#: 342257
Marine blue pearl
i always wondered abt fat tires. lol. right now am on 205/50. have to wait till the tires are shot. then that would be the time to go wide and low tires.
