Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 01-18-2013, 10:51 PM   #1
Ilovecugars
Member#: 299442
2005 Forester XT
Default Idel afr unsteady
Hi guys.
I have a 05 Fxt with a stage 3 setup and a pro tune through AP. The car have been like this for a while and has worked well. However lately it has had rough idel and has been a tough one for me to figure out.
At idel is the only time it does this, the rpm are steady within about 50rpm either way. But monitoring the afr I see it is jumping around a fair bit. It will fluctuate from 14 to around 15.5 and anywhere in between and when it jumps around it is causing a roughness felt through out the car. Once the car is rolling it has no issues and works great and even seems to improve a bit when the AC is on and has no idel issue when it is cold warning up on high idel.
I was having some surging issues at part throttle so I replaced my front o2 which did solve that issues but did not fix the idel. At least I can narrow it down to know that sensor is not at fault.
If any one has any suggestions of where to look for causes to this problem it would be a great help. The only ideas I have at the moment are perhaps a leaking bpv as it is stock or maybe a bad maf sensor. Both of which I can switch from my wifes car to rule those out.
One again any one with experience with this some help would be awesome.
Ilovecugars is offline   Reply With Quote
Old 01-21-2013, 09:55 AM   #2
Cobb Tuning
Member#: 4803
Originally Posted by Ilovecugars View Post
Hi guys.
Top of the list would be a post-MAF intake tract leak. I would get a pressure or smoke test of the intake tract done and fix any leaks you find and then reset the ECU via the AccessPORT. If you have a version 2 AccessPORT, you can take a look at the A/F Learning 1 A,B,C,D values (via Live Data function or data logging) which may give you more information as it pertains to a possible fueling issue.
Bill
