Old 06-24-2012, 10:27 PM   #1
Strider327
Member#: 131280
2004 Impreza WRX
Default CEL Nightmare P0457
So I have been having a P0457 CEL problem. I've checked the rubber lines on the solenoid, replaced the purge valve near the gas tank and check all the connections. Everything seems good, however I am still getting the code. I have NOT replaced the solenoid, only cleaned it. What else should I look for, because bringing it into the shop?
Thanks in advance.
Strider327 is offline   Reply With Quote
Old 06-24-2012, 11:06 PM   #2
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
That code is for a gross leak in the evap system. there is a solenoid bolted to the front of the intake behind the pw steering pump, I have found the lines off and the solenoids broken. Check that. If thats not it you need to smoke test the tank.
Old 06-24-2012, 11:09 PM   #3
Strider327
Member#: 131280
2004 Impreza WRX
Smoke test is probably next and then replacing the actual Solenoid. Thanks!
Old 06-25-2012, 02:06 PM   #4
StealthTL
Member#: 206912
2006 Forester XT
Gas cap?
StealthTL is offline   Reply With Quote
Old 06-25-2012, 04:30 PM   #5
Strider327
Member#: 131280
2004 Impreza WRX
Originally Posted by StealthTL View Post
Gas cap?
Nope that was the first thing I tested and replaced.
Old 06-28-2012, 02:05 AM   #6
iluvmyEJ20
Member#: 156307
04 wrx impreza
i have the same prob....i recently got that cel the other day...yall know if its ok to drive around still?...goin out of town 2mrw lol
iluvmyEJ20 is offline   Reply With Quote
Old 06-28-2012, 06:41 PM   #7
Strider327
Member#: 131280
2004 Impreza WRX
It's ok to drive, it might idle weird though. So my problem was a bad "Check Valve".
http://i1089.photobucket.com/albums/i360/ryun84/1.jpg
Everything was connected and working correctly except for that thing. Apparently it wasn't sucking vacuum or something along the lines of that. Replaced it and now its better. So just for the record I would like to list the things that a P0457 CEL could relate to and things you should check if you get this code ever.
1. Gas Cap
2. Evap Solenoid Hoses (Sometimes they get loose and disconnect)
3. Purge Valve under the Charcoal Canister (Under the gas tank)
4. Check Valve
Old 06-28-2012, 08:02 PM   #8
soysauce4u
Member#: 324592
I had this happen to my a few months ago and it took replacing the solenoid for me atleast. I've never heard of it ACTUALLY being the gas cap as the problem even though that's part of the code description because it's also happened to a couple other buddies with subies.
soysauce4u is offline   Reply With Quote
Old 06-28-2012, 08:05 PM   #9
skareemoutloud
Member#: 324316
2015 BRZ Limited
i actually had a similar issue on my RSX with the p0457. i dunno if this will help, but i'll throw in my $0.02. i kept getting a "Check Fuel Cap" message on my dashboard, but after replacing the gas cap nothing changed. so i took it to a mechanic and he smoke tested it and it checked out fine. he told me i needed to change my vent pressure sensor, purge control valve, and canister vent valve. so i ordered the parts and replaced them myself. if i remember correctly, the vent pressure sensor is located on the throttle body, and the other two parts are located on the EVAP canister under the gas tank. it got rid of my p0457 for good.
i dunno if it's the same for subaru's or not, but i figure some info is better than no info.
skareemoutloud is offline   Reply With Quote
Old 06-29-2012, 01:01 PM   #10
11stikmd
Member#: 324246
2011 STi
Make sure you have power and ground at all connections for evap system. Also underneath rear seat make sure no mouse damage. Seen short to ground because of mouse damage throwing P0457.
11stikmd is offline   Reply With Quote
Old 06-29-2012, 01:05 PM   #11
fr0st_wrx
Member#: 126717
2006 WRX
Have you removed the fuel pump assembly? I got this code due to the rubber gasket that sits beneath the top of the assembly, the oval one that the 8 studs pass through. Once I replaced it, it went away.
fr0st_wrx is offline   Reply With Quote
Old 01-08-2013, 09:54 PM   #12
tmonda
Member#: 268721
2005 STi
1. Gas Cap
4. Check Valve
Good to know! How much was this check valve? Also, did you troubleshoot this check valve or just replace it? Curious on how you may have troubleshot it.
tmonda is offline   Reply With Quote
Old 01-10-2013, 12:46 AM   #13
Strider327
Member#: 131280
2004 Impreza WRX
Vacuum test the check valve, found it faulty and got another one.
Old 01-21-2013, 08:56 AM   #14
Jordy05
Member#: 306271
05 Subaru Sti
Pure white
Where did you get the check valve from. Ive searched and cant find one.
Jordy05 is offline   Reply With Quote
Old 02-07-2013, 11:30 PM   #15
Strider327
Member#: 131280
2004 Impreza WRX
From Subaru.
CEL??????help P0457?? raggedoutsti Newbies & FAQs 2 08-26-2010 10:19 PM
boost backoff in 4th gear and cel code P0457 yamaha_rider619 Service & Maintenance 8 08-16-2010 09:59 PM
CEL issue P0457 - Help Rally_WRX1 Service & Maintenance 3 06-08-2008 07:24 PM
CEL P0442/P0457? (Help Needed) APSWRX1 Texas Impreza Club Forum -- TXIC 4 03-28-2006 02:16 PM
cel code p0457 flabele Service & Maintenance 12 12-09-2005 02:48 PM
