Old 01-20-2013, 06:03 PM   #1
EPA H8R
Member#: 344127
Default Entire PCV hose system missing.. advice?
Ok, I've searched and MOST write-ups I've found dealing with oil catch cans are so old that the pictures no longer show, or have been removed. The others haven't really helped with my ordeal.
I recently bought a 2002 WRX that was, until 3 weeks prior to my purchasing it, completely stock. In those 3 weeks the owners son butchered a lot. After fixing the intake, exhaust, BOV, etc.. I'm stuck.
ALL the hoses dealing with the PCV system are missing, including the steel lines that bolt to the intercooler. A couple of good folks in another forum suggested I make my own catch-can setup, but couldn't provide pictures or a write up, or links to such... Could anyone here help me out? Pictures really help since this is my first car like this. I'm new to it but not to building/modifying engines entirely.
Thanks in advance.
EPA H8R is offline   Reply With Quote
Old 01-20-2013, 06:53 PM   #2
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
You could just as easily replace the hoses.
Old 01-20-2013, 08:42 PM   #3
EPA H8R
Member#: 344127
Part of why I was asking for pictures.. I don't know where they go
Old 01-20-2013, 08:46 PM   #4
HinshawWRX
n00b Moderator
Member#: 140114
06 18G Semi Built
SGM WRX
The PCV system routes (2 hoses each) from the valve covers and one from the top of the motor between the inlet tube and intercooler to 1 hose going to the inlet. (If I remember right, I'm 99% sure I'm missing something here)
I'd be interested to see pictures of what is going on.
Old 01-20-2013, 10:26 PM   #5
flores412
Member#: 337037
03 wrx
black
They have a ancillary hose kit to replace majority of Pcv and coolant lines for sale. And it comes with the directions to where they all go.
flores412 is offline   Reply With Quote
Old 01-21-2013, 09:51 AM   #6
EPA H8R
Member#: 344127
I'm gonna try to take some pictures today to help show whats going on
The cheapest one I've found is $100. I've already replaced the coolant and radiator hoses, and a couple others that were beginning to dry rot, so for my purposes that's too expensive. Unless you know where I can get a cheap one!
Old 01-21-2013, 11:21 AM   #7
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
So a pcv hose is just for emissions, nothing else. As long as you don't have a vacuum leak, and are not spewing oil, you're fine. If you are, then fix it.
Bacon117 is offline   Reply With Quote
Old 01-21-2013, 12:09 PM   #8
EPA H8R
Member#: 344127
I'm guessing that's why the car was running just fine before my upgrades..
However since I just corrected some less-than-correct issues, and went full Stage 2, I'd rather have everything hooked up as close to spec/stock as possible.
Old 01-21-2013, 01:07 PM   #9
flores412
Member#: 337037
03 wrx
black
I had the same problem with mine on the passenger side valve cover. I took the old on off an got 1/2" I think an had it long enough to wrap around the second coolant res. to the steel line it connects too. Ill try and get some pictures to show you.
Old 01-21-2013, 02:58 PM   #10
EPA H8R
Member#: 344127
Thanks, it be much appreciated!
Old 01-23-2013, 08:07 AM   #11
Purpose_Built
Member#: 222879
The metal runs from left to right. 2 inputs on the passenger and 1 on the driver side. Driver side hose goes from the valve cover to the metal hose. Passenger side valve cover goes to the rear metal crossover input. Intake source goes from the intake to the front metal crossover input. The hose is connected internally and is essentially a y pipe
Purpose_Built is online now   Reply With Quote
Old 01-23-2013, 10:00 AM   #12
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
LOL, with that screen name, I would have guessed you would jump at the chance to spew some combustion blow by into the environment.
Old 01-23-2013, 10:52 AM   #13
jthatch12
Member#: 321715
03 WRX
I can provide a write up if you shoot me a pm
Old 01-23-2013, 11:00 AM   #14
jonno
Member#: 283263
Here's another good diagram of the stock PCV system with part numbers and such. This site in general is a good place to check diagrams and part numbers.
http://opposedforces.com/parts/impre...llustration_1/
jonno is offline   Reply With Quote
Old 01-23-2013, 11:43 AM   #15
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
So, you have a catch can, is it still routed back to the intake? If so, why do you do it that way?
Old 01-25-2013, 09:21 PM   #16
EPA H8R
Member#: 344127
Haha its been my screen name and license plate for years.. started with an old K5 blazer runnin rich, then my Cummins, now this.
That link isn't working for me..?
I took some pictures.. can't figure out how to post them though
Old 01-26-2013, 04:25 AM   #17
jonno
Member#: 283263
Yeah the site is down for some reason I think...I'd expect it to be back in a day or two.
Old 01-26-2013, 11:52 AM   #18
EPA H8R
Member#: 344127
This is also what's confusing me.. My metal pipe is gone, and I can't see where it would've run to on the driver side. What I'd really like to do is buy about 25' of silicone hose and replace it ALL!
Old 01-26-2013, 11:02 PM   #19
AdventureBug
Member#: 258848
02 impreza wagon
bump as am trying to figure this out myself.
AdventureBug is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 07:27 PM.
