Old 01-05-2013, 07:47 PM   #301
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
there is absolutely no reason to do this anymore. or if you're going to do it, theres no reason to guess if it worked or not.
1 - if your IAM/DAM is down, its most likely down for a reason. artificially raising it is stupid, unless you know what you are doing.
2 - vagcom logging cables are $10. so you can verify your IAM/DAM.
3 - using a vagcom/tactrix/AP it is simple to set the IAM/DAM at 1.0 for 32bit or 16 for 16bit.
This method is old and outdated and is no longer necessary with the tools that are available.
Old 01-09-2013, 02:27 AM   #302
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Can a mod sticky this version instead?
http://forums.nasioc.com/forums/show....php?t=2235130
Old 01-09-2013, 09:06 AM   #303
quazimoto
Member#: 70395
This "sticky" needs to be "unstickied". Waaaaaayy out of date.
Old 01-14-2013, 09:28 PM   #304
ForSakenAngelHMG
Member#: 343345
What do you guys think about Evo scan, and has anyone work on it before. Evo scan it a tune map for subie? I need more info from a subie that have use.
ForSakenAngelHMG is offline   Reply With Quote
Old 01-15-2013, 01:16 AM   #305
ForSakenAngelHMG
Member#: 343345
Default Evo scan
Have anyone use Evo scan on their subie. Evo scan it Similar to access port. I need all you guys feed back. Check it out http://www.evoscan.com/
Old 01-15-2013, 07:36 AM   #306
quazimoto
Member#: 70395
No need for Evoscan. We have Ecuflash.
Old 01-15-2013, 09:07 PM   #307
ForSakenAngelHMG
Member#: 343345
How you ecu flash?
Old 01-15-2013, 09:29 PM   #308
quazimoto
Member#: 70395
Old 01-21-2013, 12:05 PM   #309
ForSakenAngelHMG
Member#: 343345
Does anybody know what intake I can use for my stock ecu map.
Old 01-21-2013, 08:41 PM   #310
quazimoto
Member#: 70395
Yes. The stock intake.
Old 01-05-2014, 06:04 PM   #311
dead_ringer
Member#: 377848
2013 WRX Sedan
PBP
This is probably a total noob question but this trick will work with a stock ECU that has been flashed? I'll thank everyone for not laughing at my inexperience ahead of time!!haha
dead_ringer is offline   Reply With Quote
Old 01-06-2014, 12:27 AM   #312
NSFW
Member#: 140444
05 Stage Free LGT
Yes but there are better ways:
And if your ECU was flashed a while ago, then this "trick" is a complete waste of time. The ECU learns on its own after a few minutes usually. If you've driven for more than 20 minutes or so, it's almost certainly done, and there's no point doing it again.
It's really only use for tuners who:
a) flash between dyno pulls, and
b) haven't read about the superior technique described in that other thread, and in lots of other places online. Which basically means they haven't been paying attention for a few years, which basically means they kinda suck. Lots has been learned about tuning Subarus over the last few years, this is just one tiny example.
Old 01-07-2014, 04:27 PM   #313
ennigiser01
Member#: 378053
Smile
Thanks for share.
I want to try.
ennigiser01 is offline   Reply With Quote
Old 07-02-2014, 04:26 AM   #314
komietim
Member#: 395181
Default thx
thx
komietim is offline   Reply With Quote
Old 09-03-2014, 11:35 AM   #315
genjiwrx
Member#: 377436
*thumbs up*
genjiwrx is offline   Reply With Quote
Old 10-18-2014, 07:50 PM   #316
Wursty
Member#: 404203
look forward to trying this out when i need to reflash my 14 wrx again.
Wursty is offline   Reply With Quote
Old 01-14-2015, 03:00 PM   #317
hyper2
Member#: 410644
2002 wrx
blue
Thank you
hyper2 is offline   Reply With Quote
Old 01-28-2015, 06:10 PM   #318
Artizle
Member#: 251825
2004 WRX
Doing this is not a good idea. The ecu pulled timing because it heard knock. Resetting it will add all that timing back in and potentially harm your engine.
If it's false knock the ecu will learn it out by itself. If the false knock is not going away you have a different problem such as a loose bolt, heat shield etc.
The OP is from 2003. Now a days tuners can set the initial IAM/DAM to whatever they want within the tune so they don't have to do this every time a reflash is done. In other words this info is severely outdated.
Sent from my SCH-I535 using NASIOC mobile app
Artizle is offline   Reply With Quote
Old 02-15-2015, 12:28 AM   #319
NSFW
Member#: 140444
05 Stage Free LGT
I reported this thread to the mods a few days ago, and suggested stickying one that I wrote in 2011 with the modern approach. No change, and no response from the mods.
Anybody else feel like reporting this thread? I don't care whether or not you suggest mine, it would still be good to just get this old info buried.
Old 08-09-2015, 02:57 AM   #320
FRESHPRINCEoLC
Member#: 427630
2003 Subaru Wrx
How long does it normally take to learn the ecu after flashing? Im having problems getting over 10psi with a stage 2 tune and a DP
FRESHPRINCEoLC is offline   Reply With Quote
Old 08-09-2015, 08:59 PM   #321
Noximus
Member#: 368550
2009 STI Sport Tech
OBP Limited
5mins idling without, 5mins idling with ac, and about 20-30km of driving with and without ac.
Noximus is offline   Reply With Quote
Old 08-10-2015, 01:24 AM   #322
NSFW
Member#: 140444
05 Stage Free LGT
If you can't get over 10psi, learning is not the problem. It's hard to say whether the problem is in the tune or something mechanical, but data logging should help narrow it down.
Old 11-17-2015, 10:05 PM   #323
Chip_04sti
Member#: 434474
Thanks for sharing, have anyone tried it???
Chip_04sti is offline   Reply With Quote
Old 11-20-2015, 01:12 AM   #324
NSFW
Member#: 140444
05 Stage Free LGT
Old 04-11-2016, 11:22 AM   #325
Nightrhaven
Member#: 416073
2007 impreza STI
nice trick
Nightrhaven is offline   Reply With Quote
re-mapped ecu tiger20002 Subaru Conversions 2 09-03-2014 11:36 AM
Zero to 100% operational in .5 seconds Strider Off-Topic 31 02-01-2008 04:10 PM
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 12:15 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 01:55 PM
10-100mph in 7 seconds! BlownCobra Off-Topic 39 12-03-2003 12:02 AM
