Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 01-18-2013, 10:30 PM   #1
OkobojiClassicCars
Member#: 338524
Default stage 2+ 03 wrx, jdm motor, just installed by perf shop, edit zero wg duty reading
I posted this same thin g over in the 2.0 thread i made which is this:
http://forums.nasioc.com/forums/show...2#post38943702
this is my last post:
got the car back from DB Performance in Rodgers, MN and absolutely zero complaints. did great work!! and would recommend them for any domestic or foreign guys too!
But the problem is mainly I didnt have enough $$$ right now for a complete dyno and custom tune. CC ran dry at 2g but they put a custom cobb map on it basically stage 2+
the car has the motor above
but does NOT have TGV deletes as originally thought
has AVCS but isnt hooked up (usdm ecu, same ecu that came with car)
Perrin Ram air intake
Cobb AP
Billet Pitch Stop
Full catless turbo back exhaust
Catless up pipe
of course always running 91+ oct
I didnt have the cash for a full custom dyno and tune right now. That will come when I get some tgv deletes (now), and my parts back from grimm speed (PNP throttle body, intake manifold and VF39). Plus DW 1kcc inj and DW 320lph fuel pump.
But before that happens I ran my cobb ap for the first time today and my a/f ratios were all over the place from -3,81 @ 3500rpms on gas in 3rd (idk how its possible to have a neg result) then to 17.5 full throttle 3rd gear as well. I have all the excel sheets on my pc now so i can send them or if i can u/l them directly to this page i will.
My tuner said after the 10 miles he drove in the car not to get into full boost (even if i try it has a horrible lag problem and also hits fuel cut) obv thats the reason he said no full boost, it will throw a code. po244 i think it was. I really just want someone to look at the a/f points i have data logged, obv i would be fine if it was too rich but to lean causes det and well i cant afford that right now. i can park it and drive my ****teh exploder for 3-6wks while i get the stuff back from GM but prefer to drive my subaru. at this point idk what to do!
I have all the excel sheets I think i did about 10 runs when i found out from a friend not to run them longer than a few minutes at most (was 1st time with AP) Im not sure how to post them here either to show up correctly?
Either im looking at the wrong AP screen, it always say a/f learning as well, tomorrow I'll take out and get some pics or video of what Im seeing on my ap if that doesnt make sense, or if im doing something wrong.
I just want to keep this motor safe for another 4-6wks till it gets a full tune from DB Performance.
Or if someone can make an e-tune where it will run correctly, boost/af/etc... for the time being thatd be great too.
OkobojiClassicCars is offline   Reply With Quote
Old 01-19-2013, 02:11 AM   #2
OkobojiClassicCars
Member#: 338524
https://docs.google.com/spreadsheet/...QWGh1ZGc#gid=0
or
hopefully that shows up. if not my wastegate duty shows zero thru the whole thing is that from the jdm motor or could it be from a guy running a ewg on this motor before buying it? Thats what a subbie owner said at least? not sure though. but looking at other graphs from other people running a stock turbo it shows a massive waste gate acc amounts. On all of my graphs it shows zero.
Old 01-19-2013, 04:04 PM   #3
OkobojiClassicCars
Member#: 338524
ok im an idiot i didnt see how to change and show the af other than learning, so now i have the real #'s
https://docs.google.com/spreadsheet/...3BYLWZmZXprQ0E
https://docs.google.com/spreadsheet/...lRKaDMwZEtDNUE
Old 01-21-2013, 10:06 AM   #4
Cobb Tuning
Member#: 4803
With the DAM at 16 and WGDC at 0% during the entire log, it means that the tune is calling for 0% WGDC. The might be because this was simply a map to get you by until you get a custom tune so they only wanted you running wastegate boost. Certainly, you will need a custom tune for this combination of mods, but, until then, I would not do any high load pulls.
Bill
Old 01-21-2013, 09:42 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
limp map to get you by until you can get a proper tune.
weren't you reading the what your tuner wrote to you?
