Old 12-30-2012, 12:29 PM   #226
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
looks good. i still chuckle at all the ricers in my area with their cheap PnP HID's blinding folks vs. actual "usable" light w/o having to molest the car.
i'm at 4+ months, no issues... other than blowing one of the yellow fogs... which i got yellow overlays for anyway, so i just threw my white bulbs back in.
ChesterWRX is offline   Reply With Quote
Old 01-06-2013, 09:31 PM   #227
lj8915
Member#: 329252
2012 Subaru WRX
My headlights are noticeably VERY hot after driving with lights on for a while. Scares me a little.
They were never hot when I had an hid kit in there. I can basically feel the heat by putting my hand on the outside of the headlight.
lj8915 is offline   Reply With Quote
Old 01-06-2013, 09:37 PM   #228
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
they can't be hotter than HID's.
mine are still going strong. YMMV. you saw the OP in this thread right? temps were taken.
Old 01-06-2013, 09:47 PM   #229
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
My friend with a truck swears by those eBay hids. I hate the way they look and try to convince him to get some regular bulbs. He's about the most stubborn person I know though, so all he ever says is "nope". Last set he got, we drove around for about 10 min and it was blink blink out with the passenger bulb. He still doesn't agree with me : l
ColeBerkenbile is offline   Reply With Quote
Old 01-06-2013, 10:21 PM   #230
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
They can, and significantly more so. HIDs are way more efficient, whereas any halogen bulb dumps most of its power in heat.
Old 01-06-2013, 10:42 PM   #231
lj8915
Member#: 329252
2012 Subaru WRX
Oh they are, by A LOT (at least what I can feel).
Old 01-07-2013, 08:29 AM   #232
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
what wattage are your bulbs? mine are 65 watts.
this is a common bulb swap with the bulb life being the only down side.
Old 01-07-2013, 12:16 PM   #233
lj8915
Member#: 329252
2012 Subaru WRX
Mine are 65w also.
Old 01-07-2013, 08:05 PM   #234
lj8915
Member#: 329252
2012 Subaru WRX
Anyone know of any 4300k h9s? Something that isn't that blue coated crap, or are all clear halogens 3200k?
Just looking for something a little less yellow.
Old 01-21-2013, 10:30 AM   #235
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I got my h11 osram nightbreaker +90s about a month ago and the passenger bulb decided to go today. Would the h9 mod last longer? I know these bulbs don't last long to begin with, but for $50 a pair I was hoping they would last more than just a month
Old 01-21-2013, 06:14 PM   #236
veener79
Member#: 204304
2008 WRX 4D Stage 2
My first set of H9 lasted about 2 years.
veener79 is offline   Reply With Quote
Old 01-22-2013, 12:06 AM   #237
Dova
Member#: 315989
2012 WRX hatchback
H9 still going strong after a few months. Nice and bright
Dova is offline   Reply With Quote
Old 01-22-2013, 12:17 AM   #238
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
I've used osram 4100k 9005's before I switched to hid's they were really good, lasted two years, infact i'd still have them if I didn't break one of them accidentally
alt14 is offline   Reply With Quote
Old 01-25-2013, 06:49 AM   #239
lj8915
Member#: 329252
2012 Subaru WRX
Can't find those
I'm assuming it's impossible to find a 4300k halogen bulb unless they are coated blue.
Old 01-25-2013, 08:53 AM   #240
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Colour temperature ratings apply mostly to HIDs, not to halogen bulbs. Any filament bulb shifted towards blue is done by filtering out the red (i.e blue coating) - or, to a very limited extend, by increasing the voltage, which drastically reduced their liftetime. H9s are already "whiter" than a lot of OEM halogens...
Old 01-25-2013, 10:45 AM   #241
lj8915
Member#: 329252
2012 Subaru WRX
Makes sense. Thanks.
Old 01-25-2013, 07:31 PM   #242
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
I think you ment, "increasing the wattage", not voltage.
CRAZYHAWK is offline   Reply With Quote
Old 01-25-2013, 07:48 PM   #243
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
There is what I think is called the catz zeta or something, it is basically a voltage regulator for halogen bulbs that crank up the voltage a bit, and keep is constant too.
Other way or havingh whiter light is with an overdriven filament, burning hotter (hotter=whiter) like the +30 and +50 bulbs but the too have shorter life.
Only exception is the true hir bulbs like te toshibas or some of the philips (9012 latest versions I believe, to my knowledge the philips 9011 are not actual hir bulbs) which run hotter by having a reflective coating sending back rays to focus them back on the filament, and increase the burning temperature.
frederik is offline   Reply With Quote
Old 01-25-2013, 08:08 PM   #244
lj8915
Member#: 329252
2012 Subaru WRX
Would osram night breakers or one of those special bulbs be better than an h9 bulb?
Old 01-25-2013, 10:03 PM   #245
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Sorry I went kind of off topic/general about the hIR 9011 and 9012 bulbs, these exist only in two bulb types that replace 9005 and 9006 so it is not applicable to h9 and h11.
I am having a hard time seeing what halogen bulb would be better than the h9 conversion.
Old 01-25-2013, 10:35 PM   #246
ringe
Member#: 49998
2007 WRX CT Stg 2
H7? (If only for the sake of having the 65watt version)?
Edit: nevermind, I realize now that the H9s are plug and play with minor alternations, version serious changes to fit an H7... my bad.
ringe is offline   Reply With Quote
Old 02-03-2013, 03:50 PM   #247
tspunk
Member#: 345444
2013 Impreza 5-door
Okay, so I've read this whole thread. But I don't think I was able to find what was the whitest and brightest option between the PIAA or Philips.
I believe PIAAs cost more money and I would be fine paying if somebody can tell me that they are whiter.
Also, has anybody changed out their "eyebrow" lights? If so, was it easy to get to?
tspunk is offline   Reply With Quote
Old 02-04-2013, 11:41 AM   #248
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Is there any concern of a brighter bulb contributing to advanced lens yellowing?
foghelmut is offline   Reply With Quote
Old 02-04-2013, 08:59 PM   #249
alt14
Member#: 271928
2014 WRX Limited
Lens yellowing is usually caused by oxidation and the uv protectant coating wearing away (external conditions)
Old 02-05-2013, 01:38 PM   #250
SomeGoalie
Member#: 342696
2013 WRX Sedan
Just did the H9 swap today during lunch. Amazing how easy it is to change bulbs in this car, took about 10 mins total.
I used a small pair of wire cutters to snip off the tab, then found a set of small "hobby" files at Home Depot to file down the remainder. Worked real well and only took a couple mins per bulb.
Won't know how much brighter they are until I take the car out tonight after dark.
SomeGoalie is offline   Reply With Quote
need to fix a DIY r134a A/C conversion Niku-Sama Service & Maintenance 4 06-12-2009 08:50 PM
cant seem to find a diy thread on how to 949 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-06-2007 08:47 AM
MAP to MAF conversion from UTEC??? Do it today with Xede. turboICE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 10-01-2003 06:44 PM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
