Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 04-11-2012, 11:27 AM   #151
Si1ver&B1acK
Member#: 250668
2008 STI - (Silver)
06 Forester (Black)
I'm looking forward to trying out the new AP racing pads as soon as my 08 STI is back on track. Break-in miles in the next two weeks then the final Hydra tune in early May!
Si1ver&B1acK is offline   Reply With Quote
Old 04-11-2012, 11:11 PM   #152
okiedude
Member#: 37736
2003 WRX Race Wagon
OK, here are some photos, which hopefully will explain the face clearance difference between the Stoptech and AP calipers.
This is the RealWheel Wide 5 16x11 that we are using. It is a two piece welded barrel with a bolt-in center adapter drilled for 5x100/56.1mm hub bore. There is an AP Caliper hiding in there-LOL.
This is the adapter by itself. Note the rather thick base of the pressed in mounting studs. When installed these windup being in line with the face of the caliper. See second picture, which shows clearance using a 15mm spacer and a 3 mm spacer.
With just a 15mm spacer the the wheels clear the face of the Stoptech caliper, but I need the additional 3mm(+) to get clearance with the AP caliper, here is why. The hat on the Stoptech caliper is approx. .300 higher than the AP hat, see photo. This places the centerline of the rotor .300 further inboard (towards the center of the car) than the AP rotor, when mounted on the hub.
The difference can further be seen in the mounting brackets (2nd photo).
Though smaller the AP caliper still sits further outboard than the Stoptech. I can solve the clearance problem my getting a thicker spacer, which I will have made by Adaptec, they can custom make any thickness you require.
http://www.motorsport-tech.com/
okiedude is offline   Reply With Quote
Old 04-11-2012, 11:23 PM   #153
okiedude
Member#: 37736
2003 WRX Race Wagon
So anyway, they look pretty sexy.
But, they are hard to see behind my big tires.
Here is the difference in the calipers, Stoptech ST-40 and AP.
The Stoptech setup is 2.9 lbs. heavier than the AP (per corner).
I hope to have these on the track end of May, otherwise it will be end of June. I will report then!!!
Old 04-11-2012, 11:47 PM   #154
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
Okie,
How do you like those ER coilovers?
gagliano is offline   Reply With Quote
Old 04-11-2012, 11:59 PM   #155
okiedude
Member#: 37736
2003 WRX Race Wagon
Originally Posted by gagliano View Post
Okie,
Coilovers work well. They are custom valved, with 16/18kg spring rates from Element.
Old 04-19-2012, 10:36 AM   #156
gorjiam
Member#: 155357
Just got mine fitted. 17" OZ Racing HLT clears with space to spare. Amazing how small this kit is. Lots better pedal feel too. However, those in search of "bling" needs to take note: The rotors are amazingly noisy.
gorjiam is offline   Reply With Quote
Old 07-21-2012, 06:32 PM   #157
jlukowski
Member#: 292477
2005 WRX STi
Lots of interest in my AP Racing BBK on my STi today at the Subaru Showdown at Carolina Motorsports Park.
jlukowski is offline   Reply With Quote
Old 07-21-2012, 07:29 PM   #158
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Got my kit all on. They clear 18x9.5 nto3 with a 8mm spacer. Note that I had to beat the rotor on as the hub bore is VERY tight. Its going to suck getting them off but thats something ill worry about when the time comes.
scby rex is offline   Reply With Quote
Old 07-21-2012, 07:30 PM   #159
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I bet this kit would be awesome for the BRZ/FRS.
jamal is offline   Reply With Quote
Old 07-23-2012, 08:37 AM   #160
EssexParts
Member#: 308044
Call 704-824-6030
Essex for brake help
We actually have this kit just about buttoned up for the BRZ/FR-S. Prototypes will go on our shop BRZ this week. We'll have two options...first is a Heavy Duty option, which is more or less the same specification as our STI kit in this thread. That will be the best choice for someone looking to go big power in the future. Our other (Sprint) system is optimized for the lower weight and power of the BRZ. It uses the same caliper, but a slightly smaller, 60 vane disc. That one will shave roughly 7-8 lbs. unsprung weight per front corner vs. the stock BRZ brakes.
Got my kit all on.
I like that...'kill kit.'
EssexParts is offline   Reply With Quote
Old 07-23-2012, 09:35 AM   #161
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
Have you run the kit yet?
KNS Brakes is offline   Reply With Quote
Old 08-06-2012, 08:12 PM   #162
kos
Member#: 118334
2005 AW RS + 2006
Time Attack WRX
Any more updates on this setup? Highly considering this to replace my Wilwood SL6 Narrow BBK due to the lack of viable pad choices and the small pads.
Was either looking to this setup or the ST40 355mm BBK
kos is offline   Reply With Quote
Old 08-08-2012, 01:42 PM   #163
gorjiam
Member#: 155357
I finally got to run the BBK with DS1.11 in the front and DS2500 at the back.
Used Castrol SRF.
No problems with fade or stopping.
Just wondering about the nature of DS1.11: Does it still screech when it hits operating temps? This is because the DS1.11 screeched all the way during the track day.
Note: Track is a large 5km circuit with straights capable of 200km/h peak.
As I don't have anything to measure pad/rotor temps, so I was wondering if I was ducting too much air to the rotors.
Also I noticed more wear on the front tires then the rears. Should I be running DS1.11 on both front and rear?
Old 08-13-2012, 10:01 PM   #164
scby rex
Member#: 104878
02 wrxbastardchild
2 competitors at PPIHC were running these brakes on Evos, they loved them. Badly though one car is destroyed. ( They are ok though)
Old 01-16-2013, 01:24 PM   #165
KNS Brakes
Member#: 125739
2015 WRB WRX
back to life?
Old 01-22-2013, 01:40 AM   #166
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
2013 track season special?
Old 01-22-2013, 11:52 AM   #167
WhatTurboLag?
Member#: 243992
2006 WRX TR
About time you looked at these
WhatTurboLag? is offline   Reply With Quote
Old 03-14-2013, 04:08 AM   #168
SoyKraut
Member#: 263740
2002 WRX Sedan
MBP
I figure that it is about I chime in on these brakes. I have been running them since last May and they are absolutely excellent. So far they have 15 track sessions, (at 20 or 30 minutes each) 170 plus autocross runs and countless trips up and down my favorite mountain passes. For these brakes, that level of punishment is child's play! They never fade and the feel is always perfect.
I am currently running 5x100's so pad knock back was a problem on my previous brake setups. I don't even think about it now. It's a non issue.
The rotors do clack a bit when driving slowly and over rough roads. This has the tendency to weird most people out when riding in the car at first. But this true 2 piece design works absolute wonders for keeping heat out of the wheel bearings. This past year was the first time that I didn't have to replace a front wheel bearing at the end of the season.
The AP Racing C300 pads that are included with the setup worked well in every situation I threw at them and proved to be quite durable. For the first time I find myself replacing rear pads more frequently than the fronts (probably due in part to pad thickness). My only complaint about the C300's is the noise. They are freight train loud until you really heat them up, and that takes a lot of work. Proper bedding helps with this, but if you have to drive to the track they will be loud as hell by the time you get there. They a bit dusty, but not anywhere near the level of dust that you would get running a Hawk DTCxx pad. When not tracking the car I have been running the AP racing S100 compound pads. Obviously they don't provide quite the same stopping power as the C300; but they are whisper quiet making these brakes very tolerable on the street as well. The S100's also manage to keep the level of brake dust down to a minimum.
In the end I'm really glad that I went with these brakes instead of competing setups. The amount of money that I have saved with cheaper/thicker pads and longer pad change intervals is already more than the difference in price for some of the other systems that I was looking at. This means more money for track time! I highly recommend these to anyone looking for a seriously track worthy brake setup.
SoyKraut is offline   Reply With Quote
Old 03-14-2013, 11:35 AM   #169
KNS Brakes
Member#: 125739
2015 WRB WRX
We run the same setup on our C5 and it works pretty well on that as well.
Old 03-14-2013, 11:55 AM   #170
Dutch Devotion
Member#: 145985
Hi Guys
Big thumbs up !
Do you also have a 355/32 + AP 6pots kit front complemented with a 4pots 335/28 for the rear ?
Both 2008Sti.
Cheers
Erik
Dutch Devotion is offline   Reply With Quote
Old 03-31-2014, 11:58 PM   #171
aco19812003
Member#: 277338
2010 Sti
I need front and rears for my STI hatch.. 08-12.. is there a kit for my car?
aco19812003 is offline   Reply With Quote
Old 04-01-2014, 07:13 AM   #172
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
LOL, yes.
Go to KNS brakes website and put in your car info...up pops several kits
A-man07 is online now   Reply With Quote
Old 04-01-2014, 08:27 AM   #173
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Why stop at font size 6 when there's a font size 7?!?!
"7's the key number here. Think about it. 7-Elevens. 7 dwarves. 7, man, that's the number. 7 chipmunks twirlin' on a branch, eatin' lots of sunflowers on my uncle's ranch."
Old 08-25-2014, 04:10 PM   #174
LittleBlueGT
Member#: 96204
2013 STI GR
Anyone use these brakes for a dd/track car in the salty winter months?
Wilwood also makes calipers with SS pistons and no dust boots, but they say that you are fine running them for a DD (even in the winter) so long as you take a few minutes to clean the pistons with soap and water before pushing them in when changing pads.
I know some people will say you NEED dust boots for a DD. I am just curious if anyone is dd these things (preferably in the winter), and for how long.
LittleBlueGT is online now   Reply With Quote
Old 11-01-2014, 07:58 PM   #175
KNS Brakes
Member#: 125739
2015 WRB WRX
My vote is no boots is fine on a well maintained car.
-Ken
Praise for Carlson Subaru/ Track Day Craig W Bay Area Impreza Club Forum -- BAIC 0 09-19-2000 07:13 PM
Subaru Track Day Update: Driver List + Only 6 Spaces left SFsube Bay Area Impreza Club Forum -- BAIC 31 07-20-2000 11:33 AM
Subaru Track Day!!!??? Joel Gat, 1.8L Bay Area Impreza Club Forum -- BAIC 28 06-28-2000 12:52 AM
Subaru Track Day @ Thunderhill SFsube Bay Area Impreza Club Forum -- BAIC 10 06-15-2000 12:23 AM
The First Annual North American Subaru Track Day zaphod Legacy Forum 0 11-03-1999 05:58 PM
