Welcome to the North American Subaru Impreza Owners Club Thursday May 7, 2015
Old 01-20-2013, 10:41 PM   #5476
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
I've already driven my 02 wrx wagon over 4,000 miles since the ej207 swap, the miles really pile on fast been my daily driver. I can honestly now answer the original poster question on this thread. Do I regret not having built a 2.5 instead of going with an ej207 ? No i don't, I definitely made the right choice. With the help from people here ( you know who you are that helped me) and the swap process I've learned a great deal. Thank you very much, my swap is a complete success. My bugeye is an absolute pleasure to drive, I look forward to it every day. My next ej207 swap will be when the time comes to replace the engine on my 05 Saab 92x aero, my saabaru.
Old 01-20-2013, 11:45 PM   #5477
tylerbryant
Member#: 292945
Midnight black pearl
i finished my swap today. i have the tgv circuit open codes as expected but when i started to drive i got a p0171 lean bank 1. i got the code under load doing about 50mph so im assuming MAF sensor?
BTW i feel a huge difference in the car. i dont have ACVS hooked up as im running the usdm ecu and its amazingly responsive and way more throaty.
tylerbryant is offline   Reply With Quote
Old 01-21-2013, 12:13 AM   #5478
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
That just means one of the air fuel learning trims has become maxed out. You just need to have it tuned.
Old 01-21-2013, 12:58 PM   #5479
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by Fierysun View Post
What's the difference between a ej207 v8 throttle body and under the intake manifold wiring harness than a ej205's?
Anyone?
Old 01-21-2013, 07:11 PM   #5480
AnthonyWang
Member#: 292823
Fuji Factory
Bugeye
Anyone?
i dont think there is any difference, my wiring harness was a plug and play for the most part.
AnthonyWang is offline   Reply With Quote
Old 01-21-2013, 07:12 PM   #5481
AnthonyWang
Member#: 292823
Fuji Factory
Bugeye
Engine Bay by Genghis Chon, on Flickr
Old 01-21-2013, 07:26 PM   #5482
Clark Turner
Member#: 178047
02 WRX STI Spec C
Anyone?
The differences in the engine harness will depend on the year of the JDM and US motor. Some had the intake temp sensor for example where the US will not. The later models had the blow by sensor connector where the early did not for another example.
C
Clark Turner is online now   Reply With Quote
Old 01-21-2013, 07:45 PM   #5483
WRick
Member#: 86107
Originally Posted by dr20t View Post
That's a fantastic idea Vlad - ill also chime in with my thoughts on that thread
Mick
Interested to learn and share !
WRick is offline   Reply With Quote
Old 01-21-2013, 11:30 PM   #5484
D-Rodman
Member#: 110078
05 saabaru artc gr
It's a looker Mr.Wang, congrats.
Old 01-22-2013, 12:42 AM   #5485
AnthonyWang
Member#: 292823
Fuji Factory
Bugeye
thanks! I am in love with my EJ207. But damm this thing hits 100mph with ease lol.
Old 01-22-2013, 07:47 AM   #5486
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Yup
Old 01-22-2013, 03:27 PM   #5487
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
So, the Bugeye was never designed for the Spec C oil radiator.
As a result, to route the oil conduits, you have to cut into the headlight bracket, to make room for them.
I'm now switching to JDM HID. I'm hoping that by this time (late 2002), they were starting to have thoughts and doubts that an oil conduit will...one day..pass by and these brackets have room for the conduits.
If not, I will have to make room.
Of course, the S202 did have steel braided oil hoses. But odds that someone has an actual photo of the OEM routing of those hoses and how they cleared behind the headlight are small.
Actually, since the S202 did have the HID, this would seem to indicate that they would have had to make room for the hoses in all the HID lights, otherwise you'd have S202-only headlights..
Then again, maybe those hoses take a different route.
Old 01-22-2013, 05:01 PM   #5488
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
The OEM setup uses hardlines to go through the headlights on the pics I have seen of the spec-c setup. It is much easier to go around the AC condensor and radiator. I just redid mine this past weekend and went this route. Some day I might step up to stainless lines but this works well as an alternatives.
Mine
OEM, PS cooler loop on top, engine cooler on bottom
Old 01-22-2013, 05:21 PM   #5489
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I am running hard lines from the cooler around the AC condenser. From there I will run some small sections of soft line to the motor. Though, like everything I try to do on this car, I'm sure this will fail in some way and leave me stranded by the side of the road. I'm sure of it.
Old 01-22-2013, 07:40 PM   #5490
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Thanks for the photos and info guys.
Turns out that the brakets of the "new" lights are iffy anyway , so I won't feel bad.
The way I see it, it is more important (and difficult) to get an oil cooler/radiator system that you can trust, than keep the resale value of HID lights.
I thought so much about which way to go, at the time when I decided about oil cooling, I gave myself not just one headache.
Some thoughts:
-steel braided tubes look good, but hide the condition of the tubing underneath. A proper rubber compound tube is more "honest"
-To crimp the AN fittings on the braided tube, I feel I'd have to receive some taining and practice with non-critical applications, before I graduate to the oil radiator. This leaves machine crimped braided hoses, a smaller category of vendors. Mock-up of the route becomes very important.
-In all honesty, the braided tubes should touch...nothing. Except for special guide fittings.
-This is why a conduit riser is safer, it's allowed to touch things and it carefully separates the flex rubber sections, so that they touch nothing.
And I'm sorry, but I could continue writing for a long time about this.
I think that after 2 years I'm entitled to say that I have a reliable system, except I don't have track time with it. I'll keep it unchanged and modify the lights..
Old 01-24-2013, 12:05 PM   #5491
shamrock 05
Member#: 120057
2004 "Bugeye" WRX
So hypothetically, a
JDM v7 207 with 6 spd (wrx swapped)
vs
USDM 04-06 STI
lines up next to each other, both are "stage 2/full exhaust and tune"
Same mods and driver
Which car is going to be faster/pull ahead?
Im just curious as to what car would be faster....
shamrock 05 is offline   Reply With Quote
Old 01-24-2013, 12:09 PM   #5492
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
please take the hypothetical drag racing scenarios elsewhere
Old 01-24-2013, 12:13 PM   #5493
Clark Turner
Member#: 178047
02 WRX STI Spec C
Dan. The thread and most of the forum is gone man. There is no way to fight it anymore..
Old 01-24-2013, 12:23 PM   #5494
WRick
Member#: 86107
yeah, we all know a supercharged 2.5L N/A is faster.
Old 01-24-2013, 12:37 PM   #5495
kpluiten
Member#: 120273
06 WRBWRXWGN
Old 01-24-2013, 12:38 PM   #5496
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Ok, i'm heading back to jump the v7 into the Grand Canyon now
Old 01-24-2013, 12:56 PM   #5497
mrxr250rider
Member#: 271412
05 ej207 wrx wagon
wrb
I think the Jdm would be faster. Should be close though
mrxr250rider is offline   Reply With Quote
Old 01-25-2013, 01:34 AM   #5498
frozie
Member#: 215927
05 JDM Swapped
V8 Spec C EJ207
Hi just swapped a v8 spec C 207 into my 05 Euro wrx. Ran into abit of wiring problems with the Jdm ECU. Apparently it's not the same as the swap into the USDM cars. Car won't start with the Jdm ECU (no CEL) even with both the IA performance bulkhead harness and wiring kits installed. Anyone have access to the Jdm ECU pinout diagram? Much appreciated.
frozie is offline   Reply With Quote
Old 01-25-2013, 02:11 AM   #5499
stlnation
Member#: 321805
2002 Jdm v9 STI
hi it sounds like you've ran into a common problem and that is that the ecu that came with your jdm motor is immobilized. the common solution is to purchase a non immobilized ecu. you well probably notice that when you turn the car on you will not hear the fuel pump prime and the motor well not even attempt to turn over.
another solution is to have your key and immobilizer synced to the new ecu. not sure on the cost of this
stlnation is offline   Reply With Quote
Old 01-25-2013, 11:53 AM   #5500
Clark Turner
Member#: 178047
02 WRX STI Spec C
What is the code on the top cover of the ECU? If your 05 euro has the Blow by connector, unplug it, It will fault the JDM ecu as it does not use that sensor. Also. If your engine has the charge air temp sensor, Unplug that, The 05 wiring does not route that sensor to the ecu correctly and it will fault the ecu. Some had the sensor and some did not. You state its a spec C, However, Most Spec C's are fake with fake stickers so the import/export people can get more money from you for the engine.
V8's did not have immobilizer, This would be an issue if you had a V9 or later ecu. Showing me what ecu you have will help.
C
