Old 01-22-2013, 05:35 PM   #1
JT7Dust
Member#: 271142
2011 STI Sedan
Default Need Help with Crawford AOS v2 on 2011 STI
I've searched and searched the forum but I ran into some confusion when installing my V2 AOS on my 2011 STI. My question is with using the Crawford AOS in conjunction with an aftermarket turbo inlet. I'm using the perrin one. The inlet instructs you to disconnect the white check valve and cap it off and then run the small hose from the crankcase breather connection to the turbo inlet fitting. I've done that. Here is my problem. Now when installing the AOS, it says to connect the "Y" connector to the crankcase breather port and run two hoses from the crankcase port to the AOS (Picture is below of that). I get that part. What happens to the turbo inlet fitting hose that was once connected to the crankcase port connect to? Do I block it off now? Or do I run a T connector to run in conjunction with one of the two hoses connected to the AOS? Does that make sense? The pic below shows the fitting I'm speaking of. I noticed some of the earlier versions of these turbo inlets did not have this extra fitting in the back above the BOV return hose.
Inlet fitting
"Y" Connector hoses to AOS
JT7Dust is offline   Reply With Quote
Old 01-22-2013, 06:41 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Aos bottom big hose goes off the y connector and the smaller one I "think" goes to steel line that runs along the tmic from the y connector or to aos. The hose that comes off the very top of the aos goes to the turbo inlet pipe. Make sure the very bottom hose off the aos to the y connector is long enough cuz mine wasn't and had to go buy a longer hose to keep it away from the turbo hope this helps.
Edit: where u have the arrow pointing on the turbo inlet pipe, that is not where the top hose from the aos goes. It goes on the large fitting that is all by itself beside the bpv return fitting.
I would have go out and look at mine to give u a step by step but not today its -18c lol.
Old 01-22-2013, 07:28 PM   #3
JT7Dust
Member#: 271142
2011 STI Sedan
I appreciate the help. I think I may have confused you. I've got the top hose running to the front/middle fitting on the turbo inlet. It's the far back fitting next to the turbo that I'm not sure what it will connect to. I've done a little photoshop to see if this helps.
Old 01-22-2013, 07:57 PM   #4
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Gotcha! That's the where the pcv was connected to correct me if I'm wrong. U can either leave that hose connected with the pcv capped off or just plug that fitting on the turbo inlet.
Old 01-22-2013, 08:13 PM   #5
JT7Dust
Member#: 271142
2011 STI Sedan
I figured that it might need to be deleted. I just wasn't sure. Thanks for the help!
Old 01-22-2013, 08:46 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
No prob
How did the bottom hose fit to y connector, was it long enough to run along the fire wall to the pitch stop mount before routing over to the y connector???
Old 01-22-2013, 09:54 PM   #7
JT7Dust
Member#: 271142
2011 STI Sedan
Yeah mine was long enough. I guess I was one of the fortunate ones. I know a lot of people where getting hoses that were too short.
Message Board Statistics All times are GMT -4. The time now is 04:36 AM.
