Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 01-19-2013, 09:09 PM   #1
CygnusPerformance
Vendor Sales Rating: (133)
Member#: 201606
2013 STi Hatch
PBP
Default Several New Super Pro BRZ Bushing Kits Just Showed Up!
Just wanted to let everyone know we had a bunch of brand new Super Pro Bushing Kits for the BRZ show up yesterday. A few of these offerings are not made by any other company at this time. These are really high quality bushings that are 100% designed and built in Australia. We also had some Super Pro swaybars show up, but we are still working on getting pics of them. For a full list of the BRZ bushing kits that are currently available in the US go here:
http://cygnusperformance.com/cart.ph...ategory_id=736
-Geoff
__________________
Phone: (321) 600-0889 Fax: (321) 600-9415
Aim: CygnusPerf Yahoo Messenger: CygnusPerf
CygnusPerformance is offline   Reply With Quote
Old 01-20-2013, 03:39 PM   #2
dwx
Member Sales Rating: (5)
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Do you know if their swaybars are solid or hollow?
dwx is offline   Reply With Quote
Old 01-23-2013, 06:26 PM   #3
CygnusPerformance
Member#: 201606
2013 STi Hatch
PBP
Super Pro makes both solid and hollow bars, but for the BRZ they are all solid. They are definitely the highest quality swaybars that I have seen. The are actually made in Australia. Almost all other swaybars are either made in China or Korea... Even the ones made by other Australian and Japanese companies. They cost more than their Chinese & Korean made counterparts, but when you see the finish and build quality up close you understand the cost difference. They are also 100% Australian spring steel. No telling what the others are actually made of...
__________________
Old 01-25-2013, 04:23 PM   #4
CygnusPerformance
Member#: 201606
2013 STi Hatch
PBP
Just to give a more thorough description of the bars:
Cygnus Performance has been a leader in Subaru suspension for years. After stocking nearly every available brand of swaybars we can say these are no question the highest quality, best designed bars that we've ever seen. They are 100% designed and built in Australia, while almost all other options are now manufactured in China or Korea. They have several impressive features which set them apart from the competition. They are made of 100% high quality Australian spring steel. All bars individually checked on a jig to ensure there is no more than plus or minus .5mm twist or distortion in the bar, this makes a perfect fit everytime, every bar. The bushing side locaters are fitted to the bar before powder coat and screw locked in place and then powder coating is completed over the top to ensure not being able to come lose. Powder coating is a three part process, 1/ zinc primer 2/ epoxy sealer 3/ blue powder coat which is formulated to stretch or flow on impact not chip easily. This avoids a break in the surface from road rocks and stones etc.. This unique process adds up to 1 mm to the bar diameter and the mounting bushings are all specifically sized to accommodate that increase to avoid over compression when assembled in the vehicle. For example a 22mm bar will have a D bushing of 23mm. If you do the research on all options available you'll find that no other swaybars even come close to the quality of these. If you want the best swaybars that money can buy, you want Super Pro.
All Super Pro swaybars include replacement urethane D bushings and bushing grease.
__________________
Old 01-25-2013, 06:08 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Do you have any figures on the 20mm adjustable front bar as to how much stiffer it is than stock?
Old 01-30-2013, 06:32 PM   #6
CygnusPerformance
Member#: 201606
2013 STi Hatch
PBP
I do not have any data on that at this time. I will keep an eye out for it though. I know a couple of companies have published % stiffer than stock figures in the past.
Thanks,
Geoff
__________________
