Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 01-20-2013, 08:54 AM   #26
wrxadam05
Member#: 84070
2013 Honda Fit Sport
500whp GRB STI
Originally Posted by Concillian View Post
I imagine something like this:
Note that Mike had really bad things to say to me about 38mm EWGs in a road race situation. The flow was not the problem, the heat and failure rate were. He said GST wanted to use 38mm EWGs to ease plumbing, but after a couple failures just went back to 44s.
When I had Tial 38mm issues, I switched to Turbosmart Comp-Gate 40's (not watercooled) and had ZERO issues. Diaphragms would tear in half like a piece of cheese in the Tial's.
Regarding the header, It looks alright for someone looking to have no front core support, and mounting the radiator in the back or insane v-mount. I think doing a production run of them, even at a low quantity would only beneficial if you have the spare material and can wait awhile for ROI.
wrxadam05 is offline   Reply With Quote
Old 01-20-2013, 12:18 PM   #27
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by Bariga View Post
can IWG EFR be fitted?
I don't see why not, it's just a different flange.
I'm thinking we can offer it in several flavors; with or without WG stub, choice of turbo flange type, and maybe length since the non-WG version could be shorter.
KillerBMotorsport is online now   Reply With Quote
Old 01-20-2013, 02:12 PM   #28
reid-o
Member#: 103631
2004 STI
I'm curious about your design for a rear mounted radiator in general. I have my own thoughts that involve hacking up the rear of the car. I'm interested if you have one envisioned that doesn't do that.
Old 01-20-2013, 02:41 PM   #29
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
A radiator in the back will require penetrations through the budywork no matter what. The trick is doing it to provide adequate airflow and/or improve vehicle aerodynamics at the same time.
Old 01-21-2013, 09:29 AM   #30
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Funny that you say that as we found the opposite in our experience. Now we're on the tial MVS 44mm setup.
Old 01-22-2013, 03:07 PM   #31
albersondh
Member#: 196882
08 WRX
If you did just the header with a v-band flange right after the 4-1 collector, I would be VERY interested. This has kept me away from the holy header, I love the header, but the rest of it is worthless for my application.
albersondh is offline   Reply With Quote
Old 01-22-2013, 03:22 PM   #32
tja1618
Member#: 181995
2003 WRX
Yeah I'm wondering if something like WReXd mentioned would work; sort of like a lot of 4G63 manifolds are. My friend runs a twin scroll setup that has two wastegates basically welded to the collector. Seems to work for him.
tja1618 is offline   Reply With Quote
Old 01-23-2013, 09:35 PM   #33
3MI Racing
Member#: 200987
Sounds a lot like what Turn In Concepts and I were asking for last winter
I hope you bring it out, as I don't even want to make another manifold for my own car
I would suggest rotating the turbo up and more in front of the crank pulley to help those of us not scavenging oil out of the turbo.
3MI Racing is offline   Reply With Quote
Old 01-24-2013, 11:40 AM   #34
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'm considering how we can offer this setup with different options/flanges. Not exactly sure which ones would be best to start with, but this is something we're considering.
We're working on something. I can't give away the farm just yet but it will have single WG TS.
The intention here was for the drag guys that are really chopping up the front end and have a bit more space. Tough to do on a road coarse car unless the secondary takes a turn (to the side, or up, or however floats your boat). For MAX power (drag) having no bends in the secondary gains ~5% flow. On a 700+hp drag car this can add up to quite a bit.
I gotta ask... Why the aversion to running a scavenge pump?
Old 01-24-2013, 12:17 PM   #35
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Weight and more thing to have to worry about is what i would think.^^^
02WRX2.5 is offline   Reply With Quote
Old 01-24-2013, 02:09 PM   #36
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
eh, it's a couple pounds (all down low at that) and the service interval is 10,000 hours. With the reduction in tubing I bet it's still lighter (vs a rotated setup) even with the extra pump. I know compared to OEM bits the kit is WAY lighter.
Old 01-24-2013, 04:10 PM   #37
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Can we see this header on a car?
ckyguy68 is offline   Reply With Quote
Old 01-24-2013, 04:51 PM   #38
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It's never been put on a car Just a thought at this point. Looking for interest and feedback.
Old 01-24-2013, 08:18 PM   #39
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Sounds like the next Killer B Shop car needs a front mount!
I would be interested, but if it came down to it, I would probably fabricate my own! I feel like a lot of people willing to tackle a front mount setup have the means to fabricate everything. Doesn't mean some wouldn't buy, though!
Old 01-24-2013, 08:59 PM   #40
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
You will see the header next week hopefully. I am just waiting on my turbo to show up.
Next week it will be
Just want to point out that this header design Chris has envisioned will be getting put to the test on my 800+whp GC8 build. Chris is the man, just talking to the guy over a couple of emails really shows you how much he ACTUALLY knows.. not just theories or guess work... Plus he will not put out a product until he has tested it for tons of miles. Industry needs more guys like Chris/KillerB and less money hungry schemers.
Jr
Old 01-24-2013, 10:08 PM   #41
ckyguy68
Member#: 316296
2006 STIROID
10.5@131 on 29psi
Jr
Good to hear about the header and even better to hear about Chris and Killer B. I'm excited to be running their oil pan. Still waiting on that FB message Jr.
Old 01-25-2013, 12:08 AM   #42
Matty_STi
Member#: 333602
2012 STi
Jr
+1
Chris is the man! my few chats with him have been really amazing, he's good people!
-Matt
Matty_STi is offline   Reply With Quote
Old 01-25-2013, 03:41 PM   #43
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
This is about as frontal as my comfort level can stand, but not bad for a bolt-on setup
There are some decent fabricated setups out there, and some not so much. I think the advantage we have is the ability to design and engineer a setup before cutting a piece of metal, and testing before it gets bolted to your car. Some shops that will fabricate a setup on the fly, and you are the tester, that I don't get.
Jr
Looking forward to this as well!
Thanks for the kind words Jr!
Thanks for using our products
Originally Posted by Matty_STi View Post
+1
-Matt
Thanks Matt! You have more funky header questions you know where to find me
Old 03-11-2013, 09:41 AM   #44
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Here's a couple more...
Not enough interest to manufacture, but if anyone wants this particular setup, let me know, it's for sale.
Old 03-11-2013, 10:27 AM   #45
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Interested if this is a v-mount turbo kit like tino's while retaining the aircon.
berdugo is offline   Reply With Quote
Old 03-11-2013, 10:51 AM   #46
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
It was originally part of our low-mount kit that puts the turbo low and to the side like post 43
We cut it apart and put the turbo straight out front just for fun. This was never mounted to a car, but it would make for one highly efficient setup for anyone that has a dedicated drag car.
Old 03-11-2013, 05:51 PM   #47
kpadill2
Member#: 266208
hmmmmm...
I would love to do something different like this!
kpadill2 is offline   Reply With Quote
Old 03-11-2013, 06:47 PM   #48
creative wrx
Member#: 141754
04 stock wrx ;)
z31 project, passat dd
Run with the idea again and work on locating the turbo up like Xdrian did and soon to be Jr's car (Junior2jz) your radiator location still leaves enough room to stick the inlet there and just have to put a cone on it for street use.
creative wrx is offline   Reply With Quote
Old 03-12-2013, 04:59 PM   #49
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I have a difference of opinion. I like it low so the exhaust goes straight out of the turbine. I'd rather have a bend in the inlet vs the exhaust. Plus I like an amount of distance on the inlet since flow from a cone filter tends to be craptastic.
Old 03-18-2013, 01:39 PM   #50
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Pictured funky header is gone.
Thanks guys!
