Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 10-23-2012, 05:28 PM   #1
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Default Slamming A Forester
Ok so I just recently bought a 2001 Forester L and there was no way in hell I was driving it stock haha
So I decided to slam the crap out of it!
I went ahead and did some research on here as well as use my vast subaru knowlege (was a subaru tech at ajw performance for a year and a half)
I sourced most of the parts at the local pick and pull from a 90s Impreza wagon (except the actual suspension)
Parts:
-06 WRX Sedan Shocks and Struts (70k) with Eibach Sportlines (no spacers)
-Engine cradle bolt brackets (2)
-Trans cross member bolts (2)
-LCA Mounts (2)
-Shifter linkage and bushings
-Rear Sway Bar mounts (brackets) (L&R)
(I am also unsure why the flash made all the light rust look completely horrible...)
I didnt take pictures of everything but this is how I did it:
**SPRAY EVERYTHING WITH PB BLASTER FIRST**
I also used an impact gun for the majority of things to make it easier.
First off put the car on 4 jack stands (high enough so you can crawl under the car). I started with the rear suspension because there was less things to do.
Idk why subaru decided to do this on the older subarus but in order to remove the shocks you have to disconnect the brake lines... I was not about to do that and have to bleed the entire system. So I just removed the retainer clips, pulled the line as far out of the way as possible and used a cut off wheel to cut the bracket. Then I took a hammer and bent it out of the way. (and YES you have to do this to all 4)
Next I Removed the two bolts 19mm bolts that hold the shock to the knuckle. Next go into the hatch and pop the rear shock tower covers off (flat head screwdriver) and then remove the 3 12mm nuts holding the shock in. The shock will probably fall onto the ground or just slide down a bit. (it helps to have someone to help you but i did not). Do this to both sides.
Next I removed the 12mm bolt holding the rear sway bar to the mounting bracket on both sides and wiggled the bar free. Then there is just two 12mm bolts holding the bracket onto the frame. As you can see the Impreza ones are much shorter.
Then just reverse these steps (using the Impreza items) and you are done with the rears. (Use a jack to jack up the knuckle to hold the shock in place to get the bolts on)
And now for the front
First loosen/remove the the 12mm bolt that clamps the steering linkage to the steering column. Spray it with PB Blaster. This is so when the body lift is removed the linkage can slide up the shaft.
Remove the front struts by again cutting the small bracket holding the brake line in, removing the 12mm bolt holding the ABS line, removing the two 19mm bolts holding the strut to the knuckle and finally the 3 12mm nuts for the top-hat. (dont install the wrx stuff yet)
Next I decided to tackle the LCA Mounts. First remove the two 19mm Bolts holding the mount to the frame. You can then pull the lca down to access the 7/8" nut holding the mount to the LCA. Remove that and wiggle the mount off. Then replace it with the one from the Impreza (or wrx) using the factory Forester bolts. Do the same to the other side.
The next step was the removal of the trans cross member spacers. You just have to remove the front cross brace, not the entire support. There is 4 17mm bolts/nuts (2 of each) holding this on. Once it is out I used a cut off wheel and cut the two spot welds holding the spacers on, then using a hammer to knock them off. Once they were off i cleaned it up a bit and threw a coat of truck bedliner spray on it (thats all i had lol). Still wet, I put it back on using the shorter impreza bolts on the outside.
naCAnItihS is offline   Reply With Quote
Old 10-23-2012, 05:28 PM   #2
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Now for the hardest part. The engine cradle spacer removal. Now when I say hard I mean aligning the holes was a PITA!
Remove the intake piping 12mm bolt and a 10mm bolt and the coolant reservoir 2 10mm bolts and some wire connectors.
Now you can see the cradle bracket bolts. Place a jack under the motor to support it (on the cross member NOT the oil pan). Remove the 2 17mm Nuts on each side than hold the cradle in place. Now the brackets can be pulled up. (there is a stupid Phillips head screw that holds the bracket down). Once the bracket bolts are pulled up lower the motor about an 3/4". The spacers should now be able to move. They are held in with a plastic clip but of you smack the spacer with a hammer the clips should break. Remove the spacers and then insert the new bracket bolts (I ordered these from subaru). Aligning the holes to get the new bolts trough the cradle was a PITA. I used various prying and jacking points (with a 2nd jack) to do it. Good luck haha
Once you have the bracket bolts in place, tighten them up with the factory nuts. Also make sure the steering linkage is in good working order and then re-tighten the bolt.
Next thing is replacing the shifter stop bushing. You could just use the factory shifter and linkage but you have to remove the entire linkage to get the stop bushing off.. This is why I just snagged the whole linkage from the impreza. I now also with have a slightly shorter shifter anyway, which is good.
You can remove the linkage with the shifter still attached without having to take anything else off. Remove the shift knob, take the shifter surround out, and remove the 12mm bolt holding the shifter to the shifting rod. Next go under the car and remove the 13mm nut holding the round part of the linkage to the trans. Then using a ratchet and a 6" extension remove the two 12mm bolts holding the stay bushing to the body. (not much room but it can be done). Then just snake everything down and out. (pull the shifter itself through the rubber surround). Then snake the Impreza linkage, shifter and stay bushing back up in there (all as one unit) and reinstall everything.
After that is done reinstall your front Struts and you are DONE! (get an alignment)
This took me about 8hrs total including, a front brake job (pads and rotors) and drilling a tapping a snapped bolt for the rear sway brackets.. oh and eating some pizza
Old 10-23-2012, 05:29 PM   #3
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
And you can go from:
This
to THIS:
My 01 FOZ and 05 LGT
Old 10-23-2012, 05:30 PM   #4
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
More pic whoring
Old 10-24-2012, 11:44 AM   #5
North Star
Member#: 191334
2005 Forester XT
Cayenne Red
Nice! I'm digging the white on blue/gray.
North Star is offline   Reply With Quote
Old 10-24-2012, 05:38 PM   #6
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
^^ Thanks
Just a note:
The body lift removal will not lower your car any more. The height is determined from the distance from the knuckle to where the top hat is on the suspension. The removal of the spacers just moves the back of the control arm up. This makes the control arm more parallel with the ground vs the negative angle it would be at without the removal. A positive angle (ball joint lower than the pivot point of the control arm) is what you really want for proper geometry.
Old 12-31-2012, 01:48 AM   #7
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
I have a few questions...
Is it necessary to replace the engine cradle screws after you remove the spacers or can you just use the foresters ones and have a little longer length on the end?
What is the point of swapping out the shifter? A shorter shifter is definitely worth it but I don't understand the primary reason.
bugeye-brawler is offline   Reply With Quote
Old 01-01-2013, 11:17 PM   #8
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
I have complete suspension out of a 05 wagon, and was wondering if you know If I can also use the knuckles, primarily the rear because one of my forester bearings is shot but I have spares from my parts wrx wagon - it would be easy enough to swap that over when I lower it I just don't know if it's compatible.
Looks awesome! I hope mine looks as good
rs420 is offline   Reply With Quote
Old 01-02-2013, 01:57 PM   #9
canesman220
Member#: 295084
What year is your forester? Most parts swap over.
canesman220 is offline   Reply With Quote
Old 01-02-2013, 02:20 PM   #10
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
99 forester
05 wrx wagon parts
Old 01-03-2013, 02:54 PM   #11
Oroku Saki
Member#: 115650
1998 Forester
Nice! Much better than the stock height. Though I'm biased because mine is lowered too.
Good work.
Oroku Saki is offline   Reply With Quote
Old 01-15-2013, 10:34 AM   #12
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
yes you can. thats how people do the rear disc conversion on the L models with drums.
Old 01-16-2013, 11:48 AM   #13
1XtLuVeR
Member#: 341453
05 Fozzy XT
Caynenne Red
Very nice, cool to see a Forester this low. Makes me want to lower mines
1XtLuVeR is offline   Reply With Quote
Old 01-22-2013, 11:34 PM   #14
sarom058
Member#: 342904
2002 SF5 Forester L
Platinum Silver Metallic
I am planning on lowering mine; but I have quite a few questions that are difficult to get answered just by browsing forums. (NOTE: Excuse me if I seem inexperienced or na´ve, I am currently only a senior in high school)
1. What does the subframe spacer removal do, specifically? To clarify, what function does the subframe spacer have? Is this the same as the "engine cradle spacer"? Am I correct in thinking that this is only do-able for 5MT transmissions?
2. Further, what benefit does one receive from removing the transmission crossmember spacers? What does the transmission crossmember do, in general? Am I correct in thinking that this is only do-able for 5MT transmissions?
3. I'm running STi sway bars in the front and rear. What benefit would I receive from swapping the sway bar mounting brackets? Wouldn't that just bring the sway bar further up?
4. What are the most important things I should look for in regards to suspension geometry for a long-lasting and moderately functional set-up?
Thanks in advance, guys.
~Stephan
P.S. That SF5 is exceptional--I love the white wheels and the ride height. I'm incredibly jealous.
sarom058 is offline   Reply With Quote
Old 01-24-2013, 11:02 AM   #15
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Yes the subframe spacer and engine cradle spacer is the same thing (sry I use different lingo for the same part a lot..). Removing that spacer moves you engine up in the engine bay. It does nothing for ride height! Removing that spacer moves the cradle/subframe closer to the frame. By doing this you move the control arm mounting point up or closer to the frame, as well. This is needed because when you add shorter suspension (wrx stuff) the outside end (ball joint side) will move way up. If this spacer is not removed the ball joint side will be above the other end (like this \ /). This bad, the car will ride and handle like crap. You want the hub side to be, minimum, parallel with the subframe side (like -- --). It is proper if the ball joint side is closer to the ground than the subframe end (like / \).
From what I've read (as I have no experience with this on an auto) some people have done it while others experience a vibration from the trans touching the trans tunnel. I am unsure why this would happen since the Foz is based off of the Impreza chassis and those cars have Auto transmissions too so I dont see why it would touch the tunnel. Maybe the people with the autos didnt remove the trans spacers? I just dont have a confirmation answer for you. Try finding someone that did this with an auto and ask them. (try subaruforester.org) lots of helpful people on there.
Removing the trans spacer is necessary when removing the engine subframe spacer. It keeps everything properly in line, so there is no added stress points and everything fits smoothly. Same with swapping out the control arm bushing/mount.
Replacing that mount puts the sway bar in the spot it was designed to be for proper function. Yes it may work ok now but when you add the wrx suspension the sway bar end will move up with the hub. If you do not change the sway mount the bar will now be at a different angle and may not perform optimally.
Like I stated in the first answer. You want the ball joint side of the control arm to sit below the sub frame end (when sitting on the ground).
~Stephan
haha thanks! Those wheels arent even on my car currently. I let my roommate rock them on his Aspen white WRX. They looks pretty nasty on his car too. I have black Rota Boosts on the Foz currently for winter. Not sure what I am going to run in the spring/summer but I still have a few months to decide.. Maybe my gold grids? Maybe the white BBS again idk..
Old 01-24-2013, 11:29 AM   #16
DearDiaryJackpot
Member#: 343041
2013 sti
white
Totally digging your work. Enjoy it.
DearDiaryJackpot is offline   Reply With Quote
Old 01-25-2013, 10:55 AM   #17
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
I also have an 02 WRX RSB, 02 WRX Steering rack/linkage/column end shaft (quicker ratio rack FTW!) and a kartboy STS now too.
Old 01-26-2013, 11:29 AM   #18
joe r
Member#: 53412
2003 Outback
Black and Gold.
You should have left the factory Forester LCA bushings alone. You would have some great castor & it is a ALK when pulling the front subframe spacers!
joe r
joe r is offline   Reply With Quote
Old 02-22-2013, 10:11 AM   #19
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Could always put them back in.. What would the benefit of that be?
Old 02-20-2016, 12:50 PM   #20
shane_lxi
Member#: 440861
I know this is a crazy old thread, but can I use wrx shift linkage, I'm having a hard time finding first gen impreza parts, but wrx parts are ridiculously easy to find. Also, can I just use the stock universal joint on my steering column (correct wording?) if I loosen it up and compress it or so I need a shorter unit from an impreza or wrx?
shane_lxi is offline   Reply With Quote
Old 03-16-2016, 12:36 PM   #21
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
Yes 93-07 Impreza/WRX parts will all work. You can retain your factory shifter linkage you just need the impreza shifter bushings since they are shorter. You can use the stock u-joint for the steering. You may need to grind the shaft a bit to increase the flat spot length (where the pinch bolt goes. However I did notice the steering was a little notchy. I later upgraded to a WRX steering rack, WRX linkage and Hybrid WRX/FOZ steering column.
Old 03-20-2016, 10:56 PM   #22
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
I did all this to my 07 xt
I had to cut n weld the steering linkage.
To do the rear right you need a impreza cross member and trailing arm mounts. As well as a impreza driveshaft
NW2TONE is offline   Reply With Quote
Old 05-01-2016, 05:42 PM   #23
burnera
Member#: 56232
89 325I
i don't know
Is there any difference at all for a 4EAT forester?
I have a 99, and i've gathered almost all the needed parts from the local junkyard.
Crawling under my car though, it looks like i don't have the huge hockey puck risers on the transmission cross member. I couldn't find a matching cross member in the junkyard, so i just bought M12x1.25, 40mm bolts instead.
I have the engine cradle spacers just like in the OP, but the trans cross member appears to be different.
Also, would i run into problems with the 4EAT shifter assembly?
burnera is offline   Reply With Quote
