Old 01-24-2013, 11:26 AM   #1
subbi7
Member#: 241967
02 wrx
Default go with ewg or stay iwg
hi im running atp 3076 iwg .
what is the benefits with going ewg?
tank you
subbi7 is online now   Reply With Quote
Old 01-24-2013, 11:33 AM   #2
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
tank you
Much better boost control.
Flat 4 Motorsport is offline   Reply With Quote
Old 01-24-2013, 11:34 AM   #3
CatfaceType-R
Member#: 81102
Pros: Shifts your power to the left, increases efficiency, and holds boost rock solid (this with a simple mbc)
Cons: must think about what spring u need in your ex gate, more parts to break and this failing can cause engine damage, sound
Old 01-24-2013, 12:37 PM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
IWGs are not typically in the most advantagious of locationsand the flapper style gate is turbulent and they typically do not flow as much as an EWG.
As far as improvements in spool-up, I think a lot of that goes hand in hand with EBCS upgrades and the tunes that are done hand in hand with EWGs and has nothing to do with the gates themselves. During spool up the gates are closed. Closed is closed regardless of what style the gate is. Unless target boost is lower than the capable boost, the gate should be closed.
As far as parts failing like catface noted. The actuators have the same parts, IWG or EWG. They both a diaphram, spring and other bits to do their job. As far as betting on which one goes 100K miles problem free, I'd bet on OEM. It does take some thought to determine spring pressure, but not a lot (half target boost is a safe bet).
The EWG will modulate and control boost more accurately than an IWG and will definitely flow better, but if you're not having problems with the IWG or boost creep I'd leave it. I wouldn't spend that kind of money (gate, tune, install, etc...) for the marginal power gains, I think there's better places to spend that money.
Old 01-24-2013, 12:55 PM   #5
subbi7
Member#: 241967
02 wrx
tank you all for the help!!!
