Old 01-21-2013, 11:10 PM   #1
Half Crazed
Member#: 321842
2008 STi
Default Dual compressor turbo
** EDIT ** I mean turbine wheel (exhaust-side) instead of compressor wheel - where mentioned in pictures! Sorry! **
Take, for an example, two turbine wheel blades placed atop each other. The smaller turbines would have some sort of "blocking" intake from the secondary turbine, until a certain rpm is met where the smaller intake can no longer take the pressure and then overflow into the secondary turbine wheel.
The primary (small) turbine would also somewhat feed into the secondary (larger) turbine. Both are on the same solid shaft. Since this doesn't make much sense, I went ahead and drew a couple of awesome pictures.
Also, instead of drilled holes.. what about potentially having "high temp" pressure activated valves? Hmmm..
Since I'm not too much of an engineer, this was just thought up in my head and it seems like it would work (probably with some caveats).
Thoughts? Does something like this already exist? Is it mechanically possible to be more efficient if so, versus a twin turbo?
*update* The COMPRESSOR wheel could be single but slightly larger than usual because it would spin at great speeds throughout the band.. maybe even a dual compressor wheel!
Or am I retarded?
Half Crazed is offline   Reply With Quote
Old 01-22-2013, 12:34 AM   #2
TIGWERKS
Member#: 256615
Already present in the diesel world. I believe the new ford 6.7l uses a dual compressor wheel setup.
TIGWERKS is online now   Reply With Quote
Old 01-22-2013, 12:50 AM   #3
Half Crazed
Member#: 321842
2008 STi
Damn! Like this? Does mine make sense? I wonder if it's the same. I couldn't find much of anything..
Old 01-22-2013, 01:03 AM   #4
rocketperson7
Member#: 283968
2003 WRX
MBP
rocketperson7 is offline   Reply With Quote
Old 01-23-2013, 09:33 PM   #5
3MI Racing
Member#: 200987
That compressor looks so cool. When doing turbo testing, back when I was in the diesel powertrain world, I would just stair at that thing and think of the g-code
Yippy for CAD-CAM programs
3MI Racing is offline   Reply With Quote
Old 01-23-2013, 09:57 PM   #6
wantsti
Member#: 134764
04 sti
java black pearl
That's way cool
wantsti is offline   Reply With Quote
Old 01-24-2013, 09:15 AM   #7
tja1618
Member#: 181995
2003 WRX
Originally Posted by rocketperson7 View Post
That's a pretty interesting article. Thanks for the link.
tja1618 is online now   Reply With Quote
Old 01-24-2013, 08:43 PM   #8
Half Crazed
Member#: 321842
2008 STi
Sorry guys, I was completely opposite of my terminology!
I meant the turbine wheel - not COMPRESSOR wheel!
Sorry! Look at it again
Old 01-29-2013, 08:53 PM   #9
rocketperson7
Member#: 283968
2003 WRX
MBP
yes, it's called
Holset VGT
or
Garrett VNT
Old 01-29-2013, 09:00 PM   #10
Half Crazed
Member#: 321842
2008 STi
Old 01-29-2013, 09:16 PM   #11
drewvdw
Member#: 255776
2010 LR WRX
MPS and PAR powered.
I think I understand what you mean, like two separate exhaust turbines sharing the same shaft and outlet, just two separate inlets. Small, quick spooling turbine closest to the compressor, then a larger, high volume turbine on the opposite end.
Think of it like having a 1.5 scroll up pipe, except only one could get flow at a time (That would take a little engineering). The exhaust flows through the small turbine until a specified turbine RPM, then a solenoid or some sort of device switches exhaust flow to the second, larger turbine.
Interesting thought to ponder...
Old 01-29-2013, 09:18 PM   #12
Half Crazed
Member#: 321842
2008 STi
Yes - something like that.. but I don't see why the first couldn't feed the second. There's got to be some sort of maximum flow for the first wheel that would cause the rest of the exhaust to hit the next turbine as well!
This would (theoretically) cause instant spool and then also have boost in higher RPM's.. hmm
All-in-all, current turbos are old school... why don't we have anything that supersedes it yet?
Old 01-30-2013, 04:57 PM   #13
BrioBriss
Member#: 345434
Wow that looks cool!
BrioBriss is offline   Reply With Quote
Old 01-30-2013, 05:34 PM   #14
Matty_STi
Member#: 333602
Why not vgt plus dual turbines and compressors with rocket style antilag thrown in for good measure!!!
So much torque you could screw with the earths rotation!
Damn. I want 100 psi of boost at idle!!!!!!!! Lol
Matty_STi is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 10:25 PM.
