Old 11-29-2012, 07:59 PM   #251
biodude
Member#: 271720
Originally Posted by kakarot09 View Post
I think I had talked to supertech or Wossner can't remember which. But As Fuji said order through a vendor and you should be able to get what you want. 2.2L is like a curse word to Dom though lol he doesn't like them. He'd probably still be able to order them for you, or Micah at 3MI, Matt at Ball racing, Turn in concepts etc.
was before or after he made mine.
seriously, he had a group buy on a few last year
biodude is offline   Reply With Quote
Old 11-30-2012, 10:10 AM   #252
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
Sounds like it would just be easier to buy a 205 and go that route, less run around.
romanlynch is offline   Reply With Quote
Old 11-30-2012, 10:56 AM   #253
kakarot09
Member#: 182375
08 Sti
Wrbm
Supertech has a custom piston order sheet on their website too. It is less run around to build the 2.0 or 2.5 but there are only a few issues to building the 2.2 stroker. The pistons, oil squirters, and machining for the thrust bearing.
kakarot09 is offline   Reply With Quote
Old 12-02-2012, 11:11 AM   #254
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Just make sure you know exactly what you need or you could be stuck with custom paperweights.
Old 12-02-2012, 12:48 PM   #255
kakarot09
Member#: 182375
08 Sti
Wrbm
Lol very true. And they're expensive paper weights too.
Old 01-22-2013, 09:20 PM   #256
subarugod91
Member#: 334939
will a 12200AA330 crank fit in a ej25 block?
subarugod91 is offline   Reply With Quote
Old 01-22-2013, 09:36 PM   #257
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
Yes as long as its a 99 ej25D block or full phase 2(2000-up). These are the 99's were phase 2 blocks, so the crank and pistons work.
I've done 2 of these to date.
New2Sube is offline   Reply With Quote
Old 01-23-2013, 12:35 AM   #258
subarugod91
Member#: 334939
it is a EJ25 SOHC?
Old 01-23-2013, 12:55 AM   #259
Subikid90
Member#: 239233
1998 LGT
EJ25D is the older NA DOHC
Subikid90 is offline   Reply With Quote
Old 01-23-2013, 01:29 AM   #260
subarugod91
Member#: 334939
ya i just didn't know what you meant about full phase 2(2000-up)?
Old 01-24-2013, 09:18 PM   #261
loofer
Member#: 342743
Just read the whole thread and Love it! No buddy got into specs of different forgings of Pistons (i.e. 4032, 2618, etc.). What would be good for a daily 300hp or what would be best for a 400hp monster?
Just curious!
loofer is offline   Reply With Quote
Old 05-08-2013, 09:07 AM   #262
tvladev
Member#: 346400
1995 Impreza WRX
Hello everyone. I'm going to put together a stock 2.2 EUDM phase 1 short block with heads EJ205 and my calculation is as follows:
Piston volume - 13.5cc dished
Chamber Head - 49cc
Head Gasket MLS - 0.5 mm
Piston Deck Clearance - I don't know at this time
My result for CR is 9.35:1
Is my calculation correct?
Are the pistons enough strong for 2**hp?
I am going to start with TD04L but I have TD05H too.
On the piston there aren't separate openings for the oil. Insted of them there is an entire channel. I think this channel weakens the piston.
Does the piston of turbo version have separate openings or a channel?
Thanks in advance!
tvladev is offline   Reply With Quote
Old 05-08-2013, 09:48 AM   #263
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
@tvladev- if your deck height is 0 then you will have 9.4. What is the compression height of the piston? That will give you what your deck clearance will be when figure with rod length and stroke. You need to know deck height as that plays a large part in quench area. Def don't leave out quench when building your motor, it plays a large part and is overlooked by amature engine builders. You didn't give your piston bore size so I figured my calc with 97.5mm. Don't guess at what a value may be when calculating cr. Get all your information on part specifications and sizes before trying to figure anything.
fastblueufo is offline   Reply With Quote
Old 11-20-2013, 10:05 AM   #264
dropdfocus
Member#: 89756
1992 Legacy Sport
1997 Impreza L sedan
Glad I came across this thread in a forum search. Good info here for my build this winter (2.35L stroker).
dropdfocus is offline   Reply With Quote
Old 01-29-2014, 10:28 PM   #265
KitchenerWRX
Member#: 79934
02 WRX
MBP
Just to clarify - I'm looking to build an ej22t for my bugeye WRX. I'm contemplating which crank to use. Is the only difference between the phase 1 and phase 2 crank the location of the main bearing?? I rather not machine my block for #5 main thrust bearing if I don't have to. I can source a phase 1 ej22t crank quick easily if need be. I don't want to run into any problems with my pistons (JE 97mm STD bore) and OEM STi forged rods with a phase 1 crank.
Please advise. Thanks.
KitchenerWRX is offline   Reply With Quote
Old 01-29-2014, 11:00 PM   #266
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Phase 1 22T and 22E are the same crank so that should make your search a lot easier/cheaper.
monkeyposeur is offline   Reply With Quote
Old 01-29-2014, 11:08 PM   #267
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
That is the right answer.
Old 01-30-2014, 12:15 AM   #268
KitchenerWRX
Member#: 79934
02 WRX
MBP
Exclamation
Thanks for the quick reply. After a lot of reading, I believe I have come up with my ideal build. How does the following sound:
ej22t block - stripped down, cleaned, honed, standard bore 97mm
OEM STi rods (130.5mm)
JE 97mm pistons (see http://www.jepistons.com/Catalogs/Sp...baru/ej22.aspx for specs)
ej205 heads (well ported, polished)
ej22t phase 1 crank
ACL race bearings (52mm Rod Journal Size with Thrust in #3 Position)
ARP 12mm headstud kit
Timing belt kit/
11mm STi oil pump
.023" (0.60mm) - '97-'98 EJ22E Head gasket
I did my calculations, and came up with a CR of 8.57:1. Does this seem right? I believe all my numbers are correct but if someone could double check for me that would be great
Engine #1 (EJ22T Hybrid)
INPUT ->
Bore: 97
Stroke: 75
Rod length: 130.5
Piston Dish (cc): 14.7
Piston compression height: 32.7
Compressed head gasket thickness: 0.6
Combustion Chamber Volume (cc): 52
OUTPUT ->
Cyl Volume (cc): 553.954875
Quench Volume (cc): 6.46312898
Displacement (L): 2.2158195
Piston deck clearance: 0.2746
COMPRESSION RATIO: 8.571503334
QUENCH HEIGHT: 0.8746
Old 01-30-2014, 04:24 PM   #269
KitchenerWRX
Member#: 79934
02 WRX
MBP
bump for reassurance
Old 06-04-2014, 11:59 AM   #270
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Legos
Old 06-04-2014, 12:08 PM   #271
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Whats your latest project looking like?
Is there anything you haven't tried yet that you still want to?
Old 06-04-2014, 05:16 PM   #272
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
We have a few 2.1L builds running around with 20G, HTA FPGreen, 6266 turbos. Aside from the normal 2.5L builds; sleeved and boosted with 6266/6466/6766, I have my AVCS D25 heads, 22T long rod stroker. I'll make a thread for it soon if there is interest. Lol
Old 09-13-2014, 10:33 AM   #273
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Subscribed... I have access to too many things and EJ's are too Lego... So now I'm researching hybrids...
Seraphinwolf is offline   Reply With Quote
Old 09-28-2014, 08:32 AM   #274
rustylegasy5787
Member#: 379621
1995 legasy
green with a black roof
Fuji k.quick question for youI recently came across 2004 Forester XT engine turboI would like to put it in my 2.5rs which is a 98 now I know that the XT had variable cam timing I was wondering if you thought it would be possible to put my cams on those heads with my intake.or can i use the heads off of the 2.5 D. so I don't have to run the variable cam timing computer and screw around with the wires and all that oyher stuff . and run it on my computer and just buy a few gauges im not going for. 400. Hp build just want to do about 200. For now till i start making better money and i can aford a better body.didnt even get the cam pulleys off yet they're so tight that I shattered the outside ridges on the bottom left pulley and then I shattered my socket so im no hurry my Rs is still on the road and my tx engin is sittimg on my bench .please help me i need sum good solid advice
rustylegasy5787 is offline   Reply With Quote
Old 09-28-2014, 10:24 AM   #275
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Originally Posted by rustylegasy5787 View Post
Fuji k.quick question for you. I recently came across 2004 Forester XT engine turbo I would like to put it in my 2.5rs, which is a 98. now I know that the XT has variable cam timing. I was wondering if you thought it would be possible to put my cams on those heads with my intake or can i use the heads off of the 2.5 D so I don't have to run the variable cam timing computer and screw around with the wires and all that other stuff .
Your 98 2.5RS runs a phase 1 head. Cams will not swap with phase 2 heads. Intake manifold will not swap over from your 98 to the FXT heads.
You can however run your heads on the FXT shortblock. Now you need a computer to control fuel/timing. $$$ right there.
If your budget doesn't allow this, keep on saving and do more research. Would be easier if you purchased a WRX. If you truly love the GC8 chassis, a wiring merge with matching engine is best.
nj building n00b wants to build his own gaming desktop NJSwamplands Off-Topic 11 01-29-2010 03:50 PM
I want to build my engine... HELP! usmc 04sti Built Motor Discussion 1 08-30-2008 01:04 PM
to build up my 2.0 or to build a 2.5 pulser9 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-19-2007 08:13 PM
Wanting To Build Engine But Have Questions wrxxer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-04-2003 12:15 PM
I want to build a rally car... but I don't know where to start. majglow Motorsports 25 04-24-2002 12:55 PM
