Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 12-22-2012, 10:40 AM   #576
mmfullen
Member#: 236685
2006 Legacy GT
2008 base wrx hatch
Facility: Mach V Motorsports
Tuner: Mach V Dan
Temp: 42 outside, 68 inside
Type Of Dyno: Dynojet
Fuel: 93 pump
Mods:
Stock Internals...therefore i asked dan to back it off a little.
Cobb Accessport v2
Garrett GTX3076 w/ .63 ar housing
Perrin rotated kit
Perrin front mount
Injector Dynamics 850cc injectors
Walbro 255lph fuel pump
Tsudo 3" cat'back
Agency Power Unequal length header
ACT Streetlite Flywheel
ACT Heavy Duty Full Face Clutch
and just for the 400+ bragging rights.
mmfullen is offline   Reply With Quote
Old 01-08-2013, 07:47 PM   #577
horrorbiz
Member#: 77290
15 VW GTI / FiST
Car: 2011 WRX
Facility: Dent Sport Garage
Type of Dyno: Dyno Dynamics
Boost: 19
Fuel: 93 Octane
Peak HP at RPM: 298.1 @ 5650
Peak Torque at RPM: 322 @ 3650
Power Mods: Invidia catted downpipe, Cobb SF intake w/ box, Perrin single catback
horrorbiz is offline   Reply With Quote
Old 01-14-2013, 02:11 AM   #578
SuperScubi
Member#: 233407
2004 Aspen White STi
PIA Tune 347whp 327tq
Car: 2004 STi
Facility: Maxwell Power Services
Type of Dyno: Dynocom
Boost: 21.5psi
Fuel: 92 Octane
Peak HP at RPM: 380.5 @ 5450
Peak Torque at RPM: 415.8 @ 4150
Power Mods:
- Invidia Catless DP
- HKS Hi-Power CBE
- APS 70mm CAI
- AVO Turbo Inlet
- DW 850cc Injectors
- Walbro 255 Fuel Pump
- Tomioka Racing TD05 20g Turbo
- Perrin Stealth fmic
- Grimmspeed PnP exhaust manifold with crossover pipe
- Perrin Lightweight Crank Pulley
SuperScubi is offline   Reply With Quote
Old 01-16-2013, 03:49 PM   #579
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
-2010 STI SE
-tuned by Ron of Phatbotti Tuning
-24ish PSI
-E85
-Modlist: Built short block, Dom2.5xtr, Walbro400, Fiveo 1200cc EV14s, custom 3" CAI, EL headers, UP, DP, TBE, FMIC, Grimspeed ebcs, Forge bpv
-tires: Bridgeston Potenza 050A rft 255/35/18
http://i1085.photobucket.com/albums/...103_003328.jpg
Old 01-19-2013, 09:03 PM   #580
jdmfantasy2k
Member#: 333104
Proud to say I'm finally a member of the open sourced tune club, and omg is it fun!
2011 wrx limited
Facility:Bren Tuning @ PSI in Auburn, Ma
Type of Dyno: Dynapack
Baseline # for a stocker at the dyno: 228hp/223tq
Boost:17
Fuel: pump 93
Target AFR:
SAE Corrections:
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]
Mods: Perrin foam filter
jdmfantasy2k is offline   Reply With Quote
Old 01-20-2013, 02:18 PM   #581
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Facility: The Boost Creep Ltd
Type of Dyno: Dyno Dynamics Dynamometer
Boost: 19 psi on 91 oct 22 psi on E85
Fuel: 91 oct and E-85
Target AFR: 14.7:1
SAE Corrections: 15%
Peak HP at RPM: 295.8 @ 5500 rpms and 381.3 @ 5900 rpms
Peak Torque at RPM: 291 @ 4700 rpms and 381 @4700 rpms
Mods:
Here is my current list of mods.
Engine & Transmission:
Engine a 2.5/2.0 hybrid shortblock built by Suba.
11mm oil pump
Eagle rods
Cosworth oil baffle
Cosworth rod and main bearings
Cosworth head gaskets
Cosworth pistons
ARP head studs
Blouch Dom 1.5 XT-R 3" inlet 10cm housing
Extreme Turbo Systems TMIC
AMR 3" inlet
KS Tech 83mm Mega MAF intake
Motive Autowerks composite TGV deletes
Injector Dynamics EV14 950cc injectors
Tomei UEL Header w/ 3 bolt up pipe
Invidia divorced wastegate catted down pipe
07 STi 6 speed w/ matching R180 rear diff
Subaru short shift kit and linkage
renegadeSTi is offline   Reply With Quote
Old 01-22-2013, 11:58 AM   #582
bruzzia
Member#: 343968
03 Wrx Wagon
what turbo should i use
bruzzia is offline   Reply With Quote
Old 01-22-2013, 11:59 AM   #583
bruzzia
Member#: 343968
03 Wrx Wagon
and can i have a list of websites to get it at
Old 01-22-2013, 03:30 PM   #584
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Try search... blouch turbo...
Old 01-25-2013, 12:58 AM   #585
byun
Member#: 258046
2011 Impreza WRX
Car: 2011 WRX
Facility: Equilibrium Tuning
Boost: 19psi
Fuel: 91 Octane
Peak HP at RPM: 386.4 @ 6800
Peak Torque at RPM: 374.9 @ 4400
Power Mods:
- EQ Stage 1 Built Motor (Stock compression)
- EQ Stage 1 Heads
- AEM Cold Air intake
- Perrin Turbo Inlet
- EQ 1000cc Injectors
- Blouch Dominator 1.5xtr Turbo - 8cm hotside
- Processwest TMIC
- EQ Crosspipe
- Harman Motive Catted Downpipe w/ EWG rerouted
- Invidia Q300 Catback
- Tial 38mm EWG
- Turbosmart BPV
The pink line is the 1.5xtr
The aqua green line is on the VF52
byun is offline   Reply With Quote
Old 01-25-2013, 06:43 PM   #586
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Target AFR: 14.7:1
Boost: 19psi
Fuel: 91 Octane
Power Mods:
- EQ Stage 1 Heads
- Processwest TMIC
- EQ Crosspipe
- Tial 38mm EWG
- Turbosmart BPV
Alright does an EWG really do that much for power? I was around 7,000 ft Altitude on my tune and your 19 psi 91 Octane map makes better power than my E-85 map on 22 psi.
Old 01-25-2013, 07:07 PM   #587
byun
Member#: 258046
2011 Impreza WRX
EQ just changed their calibration so i think the numbers are a bit ridiculous. On his previous calibration I think it put me around 330whp and 324wtq. Probably more realistic. Are you on the stock turbo?
Old 01-25-2013, 07:34 PM   #588
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
I have a Dom 1.5 XTR same as you only difference is I went with the 3" inlet and a 10cm hot side with an IWG. You are closer to sea level than me I take it.
Old 01-25-2013, 07:36 PM   #589
byun
Member#: 258046
2011 Impreza WRX
yeah, i'm at 100ft above sea level in San Francisco, so I think that is helping. I was putting down close to your 291whp on my vf52 before upgrading
Old 01-25-2013, 07:40 PM   #590
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Makes sense now, we were running the same psi very similar turbos and fuel. I would like to see your numbers on E-85 and crank up that boost 22 psi and you should see 400 WHP with the lower altitude.
Old 01-25-2013, 07:51 PM   #591
byun
Member#: 258046
2011 Impreza WRX
Only if E85 was more popuiar around here...
Old 01-26-2013, 07:10 AM   #592
BAMM
Member#: 344934
Talking
BAMM is offline   Reply With Quote
Old 01-26-2013, 10:37 AM   #593
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
BAMM your post is blank.
Old 01-26-2013, 10:48 AM   #594
BAMM
Member#: 344934
Ill try again ....
Old 01-26-2013, 10:58 AM   #595
BAMM
Member#: 344934
Thumbs up
Originally Posted by BAMM View Post
it looks fine to me ... i can see it
Old 01-26-2013, 11:41 AM   #596
byun
Member#: 258046
2011 Impreza WRX
Still blank
Old 01-26-2013, 12:34 PM   #597
BAMM
Member#: 344934
You using your cell phone or the PC ... Coz it's not showing up on my iPhone but it does show up on my laptop.... I use Dropbox if that's any help ?
Old 01-26-2013, 01:42 PM   #598
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
PC
You should try uploading to Photobucket or ImageShack they are free and work good for me.
Old 01-26-2013, 06:19 PM   #599
BAMM
Member#: 344934
Photo bucket here I come
Old 02-02-2013, 05:42 AM   #600
BAMM
Member#: 344934
right hope this works
plus the map day
enjoy guys
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
