Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 01-22-2013, 08:52 AM   #3101
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Originally Posted by CLL_OBP View Post
Oh, now that's something totally different. I haven't noticed anything like that and I fill up at half tank.
I mostly notice it with 1/4 tank or less it takes more gas to maintain the same speed. I cant explain it myself.
Old 01-22-2013, 10:07 AM   #3102
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
I've noticed it too. On other cars as well. The first half of the tank gets you a lot more miles than the second. My dad explained why to me at one point. Can't remember. He also was adamant about not letting the gas tank get below 1/2 full & that was one of his reasons why.
Old 01-22-2013, 10:18 AM   #3103
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
An explanation for the mpg issue is your car has more momentum with a full tank. Aerodynamics matter less when your car weighs more and you are traveling at a constant speed. Js.
goregasm is offline   Reply With Quote
Old 01-22-2013, 10:32 AM   #3104
CLL_OBP
Member#: 310435
2012 Sport Limited
PUP 5W20 93,516 miles
Just a wild guess but maybe it could have something to do with the smaller amount of gas and the EVAP system / charcoal vapor canister. The system was designed to reduce pollution and draw fuel vapor into the engine to increase fuel efficiency. As the fuel level decease, the concentration of vapors decrease and the mpg's decrease. Feels like I'm grasping at straws, lol.
CLL_OBP is offline   Reply With Quote
Old 01-22-2013, 10:34 AM   #3105
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
It's not that your car is consuming more gas when you get down to the last 1/4 tank. It's that the tank is tapered on the bottom, so the bottom portion of the tank holds less volume that the upper portions of the tank. It has nothing to do with momentum, weight, consumption of gas, and so on.
And the main reason many people fill their tanks at around the 50% point is to avoid the accumulation of condensation in the tank. This is most important in the winter time.
Old 01-22-2013, 10:13 PM   #3106
stevehnm
Member#: 329526
2013 Impreza Spt cvt
Just because the car has more momentum doesn't mean the aerodynamics matter less, except relatively with acceleration and hills. The additional weight will compress the springs a little more, but I can't see the 50 to 75 lbs making that much of a difference.
On an ideal flat and level road there will be no difference once the vehicle is up to speed, except rolling resistance, which is a minor consideration. Someone here had some stats on that - maybe the Commander.
I have noticed the dash gauge is a little more optimistic when the tank is fuller though - are you reading off the dash gauge or actually miles/gallons at a fillup?
Old 01-23-2013, 03:21 AM   #3107
SleepNMnky
Member#: 302491
Are you saying that a half full tank is not actually half full according to volume? But half way up the tank? That can't be right. Even given the shape & the sediment, etc. that's another topic & another reason to not wait until your tank is low to fill up. But that can't be the case. 1/2 full should be 1/2 by volume. How else would you define half?
Old 01-23-2013, 04:26 AM   #3108
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
By the time the fuel level gets low, some of the more volatile compounds in the fuel may have been boiled off and burned through the vapor system.
Additional weight hurts city driving more than highway, but it never helps.
Commander Keen is online now   Reply With Quote
Old 01-23-2013, 06:36 AM   #3109
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
They just use a float to measure fuel don't they? So when it is at 1/2 you very well could have less fuel remaining than the first 1/2 due to the shape/volume
Old 01-23-2013, 06:47 AM   #3110
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yes, that's exactly what I'm suggesting.
Old 01-23-2013, 07:17 AM   #3111
SleepNMnky
Member#: 302491
Well ludicrous as it sounds to not be measured by volume, I've learned something new. The tank is NOT half full. http://auto.howstuffworks.com/fuel-gauge1.htm
Old 01-23-2013, 07:19 AM   #3112
stevehnm
Member#: 329526
That's easy enough to check - fill it up when it's half full. It would be easy to alter the float measurement to adjust for that - I would find it difficult to believe Subaru doesn't do that. How about the dash gauge? I haven't noticed a big change with my Scangauge.
Old 01-23-2013, 11:07 AM   #3113
Commander Keen
Member#: 319157
The MPG numbers are not based on the float.
Old 01-23-2013, 11:26 AM   #3114
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Agreed. I'm simply explaining why the 2nd half of the tank seems to provide less range than the first half of the tank.
Old 01-24-2013, 11:35 PM   #3115
stevehnm
Member#: 329526
Do you mean when the gauge reads half tank it doesn't fill up to half the spec'd volume or what? What are you basing this on? Fuel gauge, tank fill vs. mileage, dash gauge, Scangauge (or similar) or what?
Old 01-25-2013, 06:23 AM   #3116
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
On page 124 I described exactly what is still being questioned. (Which has been answered a couple of more times since.) A simple float is what has been used for many years. It used to be brass float soldered onto an steel arm. Nothing magic. It measures the level of fuel in the tank, not the volume. On older cars, tanks were typically square, rectangular, etc. Not complex shapes to fit around suspension or anything, so it was pretty consistant. That has changed over the years, but a float is still a float. Like I said before, if a pyramid was the shape of your tank the level would drop quickly near the top and slow down as you worked your way to the bottom, (volume). If the pyramid was upside down, the level would drop slowly at the top and much quicker toward the bottom. A float is a simple device. Like I said, don't confuse level and volume.
As for the dash puter, it does not calculate based on the float level. It uses the puter and bases its readings on fuel flow, extrapolating injector pulse, air temp, engine temp, rpm, etc. It is giving you numbers based on engine management parameters.
John
Old 01-25-2013, 06:43 AM   #3117
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm getting awfully sick of always having a headwind. On this tank I have only driven 3 times.
1. Monday, -5f, 20mph headwind home.
2. Yesterday morning, -10f in the morning, 15-20mph headwind.
3. Last night, +10f, 28 mph headwind.
Now this morning when I leave it will be +1f, 35 mph headwind. Sigh.
The wind need to stop switching every 12 hours from north to south back to north etc
Old 01-25-2013, 09:46 AM   #3118
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
My gas mileage has sucked lately because it has been so cold! single digits or teens on my commute. I won't really be able to see if the reflash has helped until it warms up a bit. I do feel like the car is coasting better though, and also boggs down less, so I'm glad I had the reflash done.
imprzya is offline   Reply With Quote
Old 01-25-2013, 12:38 PM   #3119
Guzzi 1
Member#: 338666
SWP/Blk Leather CVT
Yeah, mine too. Looks like Flyboy is dealing with conditions worse than mine though.
John
Old 01-25-2013, 01:39 PM   #3120
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
John
I am expecting another 25mpg tank. The only thing I could control is the speed, but I can't wake up early enough so I do the limit or faster. Can't do anything about subzero temps, winter blend, and wind.
My Buick however in the same conditions is only getting 20mpg....
Old 01-25-2013, 03:12 PM   #3121
ans2k
Member#: 315631
2012 Impreza Sport
sooooo.....yea im just going to put this right here http://forums.nasioc.com/forums/show....php?t=2427586
Old 01-25-2013, 07:53 PM   #3122
vwgti123
Member#: 335945
2013 Sport Limited
So I am not crazy.. thank god. Where do I sign up?
vwgti123 is offline   Reply With Quote
Old 01-25-2013, 08:31 PM   #3123
hemophilic
Member#: 301213
2012 Imp. Sp. Ltd.
Blue/Silver
I didn't realize the reimbursement was annually for the duration of ownership. I want to sign up now.
Old 01-25-2013, 08:38 PM   #3124
ans2k
Member#: 315631
2012 Impreza Sport
i could use some money. so i suppose small claim law suits? then move our way up like the honda hybrid civic lady. and then bam! so who wants to do the petition?
Old 01-25-2013, 08:58 PM   #3125
chrispsti
Member#: 342676
11' lexus isf
sti sold 2011 Lexus isf
have to drive 90 minutes each way to a basketball tournament tomorrow with 3 other good size guys. curious to see how the wifes car will do carrying some beef!
chrispsti is offline   Reply With Quote
New Impreza owner, low mpg? stuffedcabbage Newbies & FAQs 34 09-25-2012 10:10 PM
2012 Impreza Reviewed - Whytecliff to Seymour brendan_mac Vancouver Impreza Club Forum -- VIC 16 12-23-2011 01:12 PM
NJ Impreza owners - sighting Dan G General Forum Archive 76 10-06-2000 12:24 AM
Md or Va Impreza owners - I have an Impreza related question. Snoopy General Forum Archive 1 06-05-2000 08:08 AM
