Old 01-04-2012, 02:01 PM   #26
King of Poop
Member#: 177880
2002 Wrx Wagon 6sp
Where can I get some cake
^ok its January...whats new
King of Poop is offline   Reply With Quote
Old 08-13-2012, 09:28 AM   #27
stubbie
Member#: 296397
1999 Legacy GT Wagon
granite
Been a while, here's the scoop.
Got the engine back form the shop and have finally installed it in the car. i have how ever changed my mind and decide to install a whipple 1.6 in over the eaton for the obvious advantages it has over eaton roots. how ever i moved into a new place with a garage and basement to work in the increased rent has slow down the savings a lot so i haven't purchased the blower yet. i will be selling the brand new Ebay TMIC i bought and the 2 Eaton blowers i have soon along with an STi oil cooler.
since im scrapping the roots i have change my manifold plans a lot. I'm still aiming for the STX IM style but with a litlle more OEM looks.
till i get the blower im using the recked short block and a set of junk yard heads to mock up the mainfold will i break in the new engine.
also i am having a 6" drive pulley made to drive the blower vs the more common serpentine style that others have been going with. this will give me a 2.5:1 drive ratio.
stubbie is offline   Reply With Quote
Old 01-25-2013, 02:28 PM   #28
stubbie
Member#: 296397
granite
Been a while since i last updated my build. Its been a long slow process gathering the materials i need and i am still working on that but i now have the biggest of the purchase list.
Whipple twinscrew supercharger.
GM 2bar Map.
Lc-1 wide band with gage.
Spare manifold for slicing and dicing.
And my EJ257 short block, build installed and broken in.
Its going to take a while but im going to build my setup on the old shortblock with the spare parts i got at the salvage yard. i will do my best to take as many pictures as i can and document this build over the next few months. I will not be able to dedicate my time and resourses as i just bought a house, have a fence to build, heating/cooling system to update but supercharger will be installed.
Old 01-30-2013, 09:05 PM   #29
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Hmmm....just saw this thread (I haven't been on here as much as before). Nice sounding build, I sorta liked the idea of a SC Legacy for a number of reasons.
Where in NJ are you? I may very well have seen you at some point if you're central or north.
Old 01-31-2013, 10:38 AM   #30
stubbie
Member#: 296397
granite
i like the idea that a wagon with all wheel drive should have a good low to mid range power band. I work in the Bordentown area and am now residing in PA. Its cheaper to live in PA than jersey these days.
This is the current development of my 3D rendering of the blower to the throttle body. It going to be a slow build but that is ok with me. i need to get my micro CNC mill back up and running and finish moving into my work shop.
Old 03-24-2013, 09:46 PM   #31
stubbie
Member#: 296397
granite
ATI custom blower pulley just arrived with my ATI balancer
Old 07-24-2013, 03:27 PM   #32
stubbie
Member#: 296397
granite
Just wanted to drop in some new pics.
Old 07-25-2013, 11:34 PM   #33
tersplat
Member#: 337888
2003 WRX Wagon
World Rally Blue
did you build that manifold? That is awesome work if you did the casting!
tersplat is offline   Reply With Quote
Old 07-26-2013, 08:22 AM   #34
stubbie
Member#: 296397
granite
i wish! nah thats the stock ej25d manifold. im had it glass beaded clean so when i start cutting and welding on it the work will go smoother
Old 08-01-2013, 02:02 PM   #35
stubbie
Member#: 296397
granite
new render of my manifold with the blower on top.
Old 08-20-2013, 07:03 AM   #36
stubbie
Member#: 296397
granite
Default New render, work moves on.
Honey do chores are never over. but here is a little more render
Old 08-21-2013, 12:48 AM   #37
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Man, that looks so good. Good work (theoretically haha)
geronimo81 is offline   Reply With Quote
Old 08-25-2013, 01:26 AM   #38
Half Crazed
Member#: 321842
2008 STi
Twin charge it ftmfw.
(subscribed)
Half Crazed is offline   Reply With Quote
Old 01-24-2014, 10:55 PM   #39
stubbie
Member#: 296397
granite
Default jan 2014 update
Heres an up date. To much stuff to do not enough time and now its 8* out side WTF! Anyway setting up a mock block in the back room of my job. been updating my cad models like crazy with the new info.
need some help from anyone with parts floating around. I need dimensions of the Crank timing sprocket ( Height and Diameter)
Any one with a WRX block, i need a rough dimension of the crank case vent in center of the block. (from the bell and some point off the left or right of the engine. and the diameter of the vent.)
Old 04-12-2015, 11:29 PM   #40
wrxodee
Member#: 162183
2ooo 2.5 RS
So what happened?
wrxodee is offline   Reply With Quote
Old 04-13-2015, 09:55 AM   #41
dahoseman
Member#: 330468
2008 STI
I'm curious about this also. I would love to have a supercharged EJ also. I love my Subarus and I love AWD, but after having owned large-displacement engines (CTS-V), the EJ is a little frustrating in lower RPM. While I enjoy power above 4000rpm, the first half of the tachometer is essentially useless. I miss having the tires chirp by tapping the gas right off of idle. A supercharger would be great. I like the compound setups that I have seen with a supercharger for low/mid RPM which re-compresses air fed in by a turbo that spools later in RPM.
Any updates?
dahoseman is offline   Reply With Quote
Old 04-13-2015, 11:07 AM   #42
dahoseman
Member#: 330468
2008 STI
How about taller intake runners and bolt the supercharger to the block below the manifold?
Yikes! Is that a supercharger? (My build thread) Y_I_K_E_S Normally Aspirated with bolt-on Forced Induction Powertrain 64 11-13-2010 04:28 PM
Questions about EJ25/EJ22 Hybrid High Compression engine Zac86 Normally Aspirated Powertrain 3 04-15-2009 10:13 PM
Poll: RS-RA swap or Supercharged Hybrid? Matt Monson Subaru Conversions 120 01-27-2007 04:50 PM
Will this work between NA ej25/22 hybrid and my OBS trany? opious Transmission (AT/MT) & Driveline 0 04-24-2006 11:29 PM
What will be better for an n/a ej25/ej22 hybrid? ej22 or ej22t HLA heads? lotus2843 Subaru Conversions 4 08-09-2005 03:13 PM
