Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 01-14-2013, 08:00 PM   #26
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
I've done all the above with my 4s. Mine connects fine but no track up or down. I know when Apple did 6.1 update it won't connect to alpine in wife's car. Don't know if its the same here?
Splinter51 is offline   Reply With Quote
Old 01-14-2013, 08:36 PM   #27
Hate
Member#: 304868
2015 WRX
I haven't had any issue with my 2013 Impreza. I have to connect each time I get in the car but I get full call features, and track up/down with track number and length in the display. I absolutely love being able to play music wirelessly.
Hate is offline   Reply With Quote
Old 01-14-2013, 09:10 PM   #28
SleepNMnky
Member#: 302491
2012 Impreza 2.0i Pr
Dark Grey Metallic CVT
Having to reconnect each time you get in the car IS AN ISSUE. You shouldn't have to do that.
Old 01-16-2013, 07:34 PM   #29
laughsewcreate
Member#: 343846
2012 Forester
Default Memory Full
I got a new iPhone 5 and gave my old iPhone 4 to my daughter. I've had nothing but problems ever since. I read that I needed to delete my phone and rename it. I did all of that and now when I turn on Bluetooth, I get the "discovering device" and nothing happens. When I attempt to pair the audio, it says "memory full." Help!
laughsewcreate is offline   Reply With Quote
Old 01-17-2013, 07:49 PM   #30
Splinter51
Member#: 343328
2011 Wrx sedan
Rally blue
You still have phones paired that haven't been deleted. I had to use the steering wheel controls to delete mine.
Old 01-19-2013, 09:44 PM   #31
Krazyjohnny
Member#: 330435
I have just lost the ability to stream my music via Bluetooth from my iphone 4s in my 2013 WRX non nav premium audio. WTF!
Krazyjohnny is offline   Reply With Quote
Old 01-25-2013, 03:36 PM   #32
briwasson
Member#: 308571
2012 Sport Premium
I've been having the same issue ever since I got my iPhone 4S. Previously had my Blackberry connected to BT on my 2012 Impreza Sport Premium and it worked fine. Switched to iPhone and now I have to manually connect each time I get in. Once it connects everything works fine. I've deleted and reset it up several times, but haven't tried the voice command setup yet. I'll give that a shot. Seems pretty obvious that it's an iPhone issue, since my Blackberry worked flawlessly with it.
briwasson is offline   Reply With Quote
Old 06-22-2013, 12:15 PM   #33
GeeDub70
Member#: 311596
2012 Sport Premium
Originally Posted by SleepNMnky View Post
I did remove the iPhone 4 first. On another forum someone suggested pairing it with the voice commands instead. That seems to have worked. Thanks!
I just did the pairing using the voice control not thru the dash radio and it worked perfect the first time.....I did do it the first 10 times thru the radio and it did not work.....I was the definition of insanity LOL...
GeeDub70 is offline   Reply With Quote
Old 06-24-2013, 10:33 PM   #34
faceman
Member#: 278362
2011 2.5i Hatch
Grey
Just to add my two cents, I have a 2011 Imprezza 2.5i Premium non-nav and had to 'Forget Device' on my iPhone and then delete the phone via the radio buttons. Then used the voice commands to pair the phone. Now it reconnects automatically again. No more manual connecting each and every time.
faceman is offline   Reply With Quote
Old 08-05-2014, 01:39 PM   #35
shiftpgdn
Member#: 193302
2013 WRX
Originally Posted by Karl in MN View Post
Anyone else having this issue? My iphone5 paired fine on my 2012 limited. My issue is that when I answer an incoming call using the steering wheel controls the radio mutes for a split second, the radio returns for about 2-3 seconds, and then finally the phone call comes over the Bluetooth connection. The time counter for the call increments this whole time so it looks like it has been connected the whole time.
It does this even after clearing everything out of the Bluetooth set-up and even if I use voice commands to pair the iPhone5.
I've got this same issue. Additionally I occasionally lose bluetooth completely and can't reconnect until the car has been turned off and then back on.
shiftpgdn is offline   Reply With Quote
Old 02-09-2015, 09:06 PM   #36
jssherm
Member#: 413118
How do you use the voice commands to pair the phone? I have the Harmon Kardon touchscreen with Navigation. When I hit the handsfree button there is no command for setup or pair phone available.
jssherm is offline   Reply With Quote
