#26 | |
Member#: 84070
Vehicle:2008 GRB STI, 05'LGT Veloster, Yukon XL,Ruckus |
Regarding the header, It looks alright for someone looking to have no front core support, and mounting the radiator in the back or insane v-mount. I think doing a production run of them, even at a low quantity would only beneficial if you have the spare material and can wait awhile for ROI.
#27 | |
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
I don't see why not, it's just a different flange.
#28 |
Member#: 103631
Vehicle:2004 STI Black |
I'm curious about your design for a rear mounted radiator in general. I have my own thoughts that involve hacking up the rear of the car. I'm interested if you have one envisioned that doesn't do that.
#29 |
Member#: 198281
MAIC
A radiator in the back will require penetrations through the budywork no matter what. The trick is doing it to provide adequate airflow and/or improve vehicle aerodynamics at the same time.
#30 | |
Member#: 93646
MWSOC
Vehicle:Many Track Records Let us help you go fast! |
#31 |
Member#: 196882
MWSOC
Vehicle:08 WRX |
If you did just the header with a v-band flange right after the 4-1 collector, I would be VERY interested. This has kept me away from the holy header, I love the header, but the rest of it is worthless for my application.
#32 |
Member#: 181995
Tri-State
Vehicle:2003 WRX WRB |
Yeah I'm wondering if something like WReXd mentioned would work; sort of like a lot of 4G63 manifolds are. My friend runs a twin scroll setup that has two wastegates basically welded to the collector. Seems to work for him.
#33 |
Member#: 200987
MAIC
Sounds a lot like what Turn In Concepts and I were asking for last winter
![]() I hope you bring it out, as I don't even want to make another manifold for my own car ![]() I would suggest rotating the turbo up and more in front of the crank pulley to help those of us not scavenging oil out of the turbo. |
#34 | |||
Member#: 198281
MAIC
I gotta ask... Why the aversion to running a scavenge pump? |
#35 |
Member#: 63192
NWIC
Vehicle:02 wrx 9.5@146.9 / 1.3 60' |
Weight and more thing to have to worry about is what i would think.^^^
#36 |
Member#: 198281
MAIC
eh, it's a couple pounds (all down low at that) and the service interval is 10,000 hours. With the reduction in tubing I bet it's still lighter (vs a rotated setup) even with the extra pump. I know compared to OEM bits the kit is WAY lighter.
#37 |
Member#: 316296
Vehicle:2006 STIROID GT3794@30psi |
Can we see this header on a car?
#38 |
Member#: 198281
MAIC
#39 | |
Member#: 316296
![]() I would be interested, but if it came down to it, I would probably fabricate my own! I feel like a lot of people willing to tackle a front mount setup have the means to fabricate everything. Doesn't mean some wouldn't buy, though! |
#40 | |
Member#: 64908
Tri-State
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
You will see the header next week hopefully. I am just waiting on my turbo to show up.
Next week it will be ![]() Just want to point out that this header design Chris has envisioned will be getting put to the test on my 800+whp GC8 build. Chris is the man, just talking to the guy over a couple of emails really shows you how much he ACTUALLY knows.. not just theories or guess work... Plus he will not put out a product until he has tested it for tons of miles. Industry needs more guys like Chris/KillerB and less money hungry schemers. Jr |
#41 | |
Member#: 316296
#42 | |
Member#: 333602
Chris is the man! my few chats with him have been really amazing, he's good people! -Matt |
#43 | ||||
Member#: 198281
MAIC
![]() There are some decent fabricated setups out there, and some not so much. I think the advantage we have is the ability to design and engineer a setup before cutting a piece of metal, and testing before it gets bolted to your car. Some shops that will fabricate a setup on the fly, and you are the tester, that I don't get. Quote:
Thanks for the kind words Jr! Quote:
![]() Quote:
#44 |
Member#: 198281
MAIC
#45 |
Member#: 163108
International
Vehicle:07 EuroDM STi 2.5L Silver |
#46 |
Member#: 198281
MAIC
It was originally part of our low-mount kit that puts the turbo low and to the side like post 43
We cut it apart and put the turbo straight out front just for fun. This was never mounted to a car, but it would make for one highly efficient setup for anyone that has a dedicated drag car. |
#47 |
Member#: 266208
hmmmmm...
I would love to do something different like this! |
#48 |
Member#: 141754
Tri-State
Vehicle:04 stock wrx ;) z31 project, passat dd |
Run with the idea again and work on locating the turbo up like Xdrian did and soon to be Jr's car (Junior2jz) your radiator location still leaves enough room to stick the inlet there and just have to put a cone on it for street use.
#49 |
Member#: 198281
MAIC
I have a difference of opinion. I like it low so the exhaust goes straight out of the turbine. I'd rather have a bend in the inlet vs the exhaust. Plus I like an amount of distance on the inlet since flow from a cone filter tends to be craptastic.
#50 |
Member#: 198281
MAIC
Pictured funky header is gone.
Thanks guys! |
