Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 01-25-2013, 03:52 PM   #1
Pickler
Member#: 301247
09 Impreza 2.5i MT
Default phase 2 EJ253 variable cam timing?
was just wondering if the impreza 2.5i camshaft timing can be advanced or retarded by the ecu? sort of like how the bmw vanos advances or retards timing up to 12 degrees? or does AVLS just vary which cam shaft is opening which intake valve only?
Pickler is offline   Reply With Quote
Old 01-26-2013, 03:45 AM   #2
rocketperson7
Member#: 283968
MBP
Nope, you have a SOHC engine
you basically have VTEC, not VANOS
Old 01-26-2013, 11:12 AM   #3
GrundleJuice
Member#: 165749
The subaru AVLS system on the 253 can only switch between low lift and high lift cam lobe profiles on one intake valve. The other intake valve is always on high lift. It's an on/off thing, not a infinitely variable lift type system. Cam timing is not changed.
Old 01-27-2013, 01:29 AM   #4
Pickler
Member#: 301247
09 Impreza 2.5i MT
ok thanks for the vtec and vanos comparison. but im not sure what sohc has to do with this? is there a connection between sohc powertrains and variable valve timing? i mean the 1.8L by honda has variable valve timing...or do you just mean sohc subaru engines?
Old 01-27-2013, 02:11 AM   #5
rocketperson7
Member#: 283968
MBP
AVCS, VANOS, really any technology that advances/retards the valve opening does so by phasing the cam lobes with respect to the cam gear
if you were to do with a SOHC engine, you would change both the intake and exhaust opening/closing, which would net you nothing
Old 02-10-2013, 04:15 PM   #6
Pickler
Member#: 301247
09 Impreza 2.5i MT
ok i still don't understand, this excerpt from subaru impreza service manual claims to have different valve timings based on different engine speeds for the SOHC 2.5L:
it still seems to me that the 09 2.5i can vary intake valve timing.
Old 02-10-2013, 11:00 PM   #7
rocketperson7
Member#: 283968
MBP
no, it doesn't
the higher lift cam that it switches to opens and closes earlier/later
again, you have vtec..NOT vanos..
