Old 01-23-2013, 06:59 AM   #1
dnorton
Member#: 218997
07 WRX Mikey Tuned
JE/FSR built,35r 1300c
Default KING Bearings ??
What are you guys doing about the King bearings coming in two different styles and not being able to match halves ?
I've spent my time and money twice now trying to get this straight thru IIR who I purchased them from, it seems they just come this way, old style MB5382XP-STDX and new MB5382XPG.
Heck I even ate the first mistake and kept the sets and reordered just to get the same sets again. I know for a fact they, IIR called the REP for King so we'd get this straight but no such luck, makes me think this is what they have, old style and new style so you can not match standard bearing half with a under size half ?
While I ws waiting on this set I went with ACL Race bearings on the last build and all turned out great but this build they wanted King, guess I'll have to stay with ACL until someone tells me where I'm going wrong or where to purchase the correct bearings ?
Thanks,
dnorton is offline   Reply With Quote
Old 01-23-2013, 09:13 AM   #2
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
Call king. Talk to Diane and see if she can help, option 2 as I recall.
gotsugg is offline   Reply With Quote
Old 01-23-2013, 09:17 AM   #3
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
I got my set from MA Performance, I first ordered the MB5382XP's I returned them for the MB5382XPG'S they have them listed as 2 different part numbers. the 2nd time around I got the correct bearings.
jnorth85 is offline   Reply With Quote
Old 01-23-2013, 11:43 AM   #4
kakarot09
Member#: 182375
08 Sti
Wrbm
I don't see them listed as two different parts. Looks like they have the mains for the number three thrust position, the mains for number 5 thrust position and the rod bearings.
http://www.maperformance.com/subaru-...gine-bearings/
Did you have to call to get the other part number?
I wonder if it is just because they have extra stock of the first gen ones and are trying to get rid of them.
kakarot09 is offline   Reply With Quote
Old 01-23-2013, 12:05 PM   #5
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
I order direct and always ask to have the older style, if they don't have them I use a different bearing.
Haven't been brave enough to guinea pig a new set
good luck Dennis.
Flat 4 Motorsport is offline   Reply With Quote
Old 01-23-2013, 01:04 PM   #6
kakarot09
Member#: 182375
08 Sti
Wrbm
I want to use the newer design though. Don't be a sissy it's not like thousands of dollars ride on the bearings lol.
Edit btw I'm just kidding
Old 01-23-2013, 04:13 PM   #7
jnorth85
Member#: 76785
SRP
I didnt see the XPG's on the internet either, but once I called them and asked specifically for them they had them in stock and were able to ship them to me
Old 01-23-2013, 05:54 PM   #8
ILikeBeans
Member#: 173053
I bought XPG's as well this time instead of ACL. I won't be doing a teardown at any point in the near future (probably shouldn't have said that out loud...) but I do send oil samples to Blackstone for analysis so I'll know if anything funky is going on with them
ILikeBeans is offline   Reply With Quote
Old 01-23-2013, 07:47 PM   #9
dnorton
Member#: 218997
07 WRX Mikey Tuned
Thanks a bunch for everyones help, I can't believe they got this wrong twice, the first time I kind of understood but the second time I was standing in front of the order taker at IIR and listen while he called and explained to them what I needed and they still sent the old and new style sets.
I should listen to Phil and go with ACl Race and be done with King until they get this straight.
Old 01-24-2013, 06:10 AM   #10
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Yup you should, why keep testing new stuff when your measuring anyways.... ACL and you would have been done...
Bamofo is offline   Reply With Quote
Old 01-24-2013, 06:38 AM   #11
dnorton
Member#: 218997
07 WRX Mikey Tuned
You are 100% correct !!! like I said, while I was waiting on these I built a short block with ACLs and had to use both sets but in the end it came out perfect.
Should have stuck with what worked but the guy wanted KIng.
Old 01-24-2013, 09:07 AM   #12
jnorth85
Member#: 76785
SRP
I enjoyed not having to buy 3 sets of bearings to assemble my motor and get the proper clearances for me it was worth the cost savings.
Old 01-24-2013, 10:04 AM   #13
wrxadam05
Member#: 84070
2015 Fiesta ST - E30
500whp GRB STI
Not sure how you guys are having issues. If you ordered XP you get old bearings, if you order XPG you get the new style bearings.
Nobody wants to be a guinea pig? LOL, you guys crack me up. Just so you aware, someone has already done all the "guinea pig" work for you.
http://vtcar.com/
They are who helped design the new XPG bearings with King. I have personally assembled over 15 engines with the new XPG bearings with no issues. Larry's Auto Machine has used King XPG bearings without issues, and the local shops around me have also made the switch to King. From my experience their tolerances bearing-to-bearing have been much better than ACL. I have yet to grab two random bearing halves of the same stamped size be more than .0002" off from each other.
wrxadam05 is offline   Reply With Quote
Old 01-24-2013, 08:13 PM   #14
dnorton
Member#: 218997
07 WRX Mikey Tuned
^^ Well I'm not sure how I keep getting screwed up with getting the right set's I'm looking for...All I want is a set of main bearings that are standard size for a 2.5 crank and one set that is .001 under sized. I've asked for this till I tried of asking since they keep sending me the old style and new style...MB5382XPG IS ONE SET THEY SENT AND THE OTHER IS MB5382XP STDX...I have two set's of each now.
Old 01-24-2013, 08:31 PM   #15
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
^that really sucks but Id make one more phone call to see if they can fix the mix-up
Old 01-25-2013, 02:11 PM   #16
wrxadam05
Member#: 84070
500whp GRB STI
I just looked through my inventory and it looks like they don't have a XPG STDX yet... I just emailed them to check. I actually haven't purchased a single set of HX bearings in XPG yet or needed too.
I'll let you know what my rep over there says.
Old 01-25-2013, 03:11 PM   #17
kakarot09
Member#: 182375
08 Sti
Wrbm
Maperformance added the xpg's to their site now too. That was nice, an email and a couple days later they're there.
Old 01-25-2013, 04:22 PM   #18
wrxadam05
Member#: 84070
500whp GRB STI
Good to see they are still on top of things after I left! (Used to work there for 4.5 years.)
Old 01-25-2013, 04:53 PM   #19
jnorth85
Member#: 76785
SRP
I had to deal with a little mix and match with the part numbers last week so im sure they wanted to avoid that process again
I explained to them that it wasnt just a new part number, but there were major differences in bearing design.
Old 01-25-2013, 08:03 PM   #20
dnorton
Member#: 218997
07 WRX Mikey Tuned
You know it !!
I spent another 134 shipped and was standing in front of the kid who took my order and I heard him tell his supplier what I wanted. My dumb butt stood there and seen the numbers match what I had already and I said something to the young man but he assured me I'll get what I'm looking for, that didn't happen.
You know I like the King bearings and it's my fault I'm having to deal with this issue since I talked the guy into wanting Kings in his build. Maybe it's just me but for the most part getting the numbers I'm looking for it takes two sets of bearings, mains and rods. I use one set of standards and one set of extra oil clearance.001...I can get an even number across the journals and pins this way.
Old 01-25-2013, 10:57 PM   #21
Flat 4 Motorsport
Member#: 295846
WRX FP HTA GT3076R
Sexual Chocolate
98.9% of the time two sets of bearings are needed.
Old 01-26-2013, 09:50 AM   #22
jnorth85
Member#: 76785
SRP
My king bearings mains and rods were All with in .0005 of each other (maybe less but I had a dial bore gauge).
I was happy to have everything installed and not have to use various different bearing sizes. The ACL's that came out of the motor were all STD sized, the motor however was assembled around 2009
Old 01-26-2013, 03:10 PM   #23
dnorton
Member#: 218997
07 WRX Mikey Tuned
I guess it's all in what tolerance you are looking for..I had a build where I used standard set for mains and came out.0007-.0009 across the journals and the motor runs great but again the kid doesn't have a 35r running e85 either. He's rods came out .001 but I've seen .0003 and .0005 to .003 on rod clearances, this is why I've always been one who advocates taking the time to mic a motor instead of just buying a set of bearings and throw them in, it's a 50/50 chance they are taking.
I've seen the same thing with drop in pistons but I don't want to start that debate :-)
Old 01-27-2013, 06:23 PM   #24
dnorton
Member#: 218997
07 WRX Mikey Tuned
Well not sure if this is going to hurt anything but I'm kind of screwed if I'm to get this short block out the door any time soon.
Journals 1-3-5 with standard King bearings measure .00045 and journals 2 and 4 measure .0015 all standard. So with two styles of Kings new and old can I use them together?
So to wrap this up to make sense, journals 1-3-5 have the old style King bearing with .001 extra oil clearance and 2-4 have the new style King bearing standard...So does anyone see an issue with this ?
Old 01-27-2013, 07:26 PM   #25
Serkan
Member#: 180514
2004 Sti
the old style bearings in 1,3,5 yield .0045 or 0.00045 ?
Serkan is offline   Reply With Quote
