#51 |
n00b Moderator
Moderator Member#: 140114
MAIC
Vehicle:06 18G Semi Built SGM WRX |
Have you taken the advice to not drive the car and drain the excess? There hasn't been a real "mix" of ideas. Once you finally told us you put in 5.28 qts we knew you overfilled it.
Drain the excess oil. Check the dipstick. Drain more if necessary. Check again. Etc etc. Chalk it up to being new/dumb and learn from it.
#52 |
Member#: 269388
SCIC
Vehicle:2011 Impreza WRX obp |
is it a new exhaust? that could explain the burning smells
nonetheless, i dont think it's condensation. I live in socal and had a buncha condensation and the water doesn't instantly just vaporize all together. It did it slowly.. over like 10+ mins. Im thinking coolant from headgasket |
#53 |
Member#: 271207
BAIC
Vehicle:2011 WRX SWP |
its still smoking even after i drained the oil
#54 |
Member#: 291274
MWSOC
Vehicle:2004 Impreza WRX STi PSM |
Buy a cooling pressure tester, pump it up to the correct system PSI and see if it leaks down.
If that passes with no pressure loss.. Find a good block tester with blue block tester fluid.. napa sells it and others, do the block test and report back, that way you will know if you have any head gasket issue i.e. exhaust gasses in the cooling system |
#55 |
Member#: 300551
SCIC
Vehicle:2002 DD wgn 6 spd 2.1 kel 272's meth 2.5xtr |
2011 do you not have a warrante? Never mind see the mod list guess not!
#56 |
n00b Moderator
MAIC
Story time.
Back when I worked for a Chevy dealer we had a kid drain the transmission, and double fill the oil on an Aveo. Customer brought it back 30 minutes later, smoking horribly. We drained the entire thing, then let it run for a day to get rid of all the extra oil residue that had built up in the vehicle/exhaust. Basically it needed to have all that extra crap burnt off. It was completely fine. Now is this car an Aveo? No. But the same thing happened, to a degree. |
#57 |
Member#: 255776
MWSOC
Vehicle:2010 LR WRX MPS and PAR powered. |
An Aveo is never completely fine. It has a fundamental problem. It's an Aveo.
But I agree. OP will likely be fine. |
#58 | |
Member#: 54523
BAIC
02-12 Turbo EJ20/25 = 4.8 quarts 02+ Non turbo EJ25 is 4.2 quarts. By the way, I hope you're not filling your 18g semi build EJxx with only 4 quarts. Not going to last long running almost a quart low. Last edited by CatchMyDrift; 12-09-2012 at 04:32 PM. |
#59 |
Member#: 54523
BAIC
As for the OP, if you're really concerned about it, here are a few things you could check to make you feel better/find some answers:
- Compression/leak down test - Pull spark plugs and check for oil on the plug - Autozone rents a kit that allows you to test the coolant in your radiator for exhaust gasses. This will help to let you know if your head gasket is blown. |
#60 |
n00b Moderator
MAIC
Weird how my OWNERS MANUAL says oil capacity= 4.2 quarts. Or as stated earlier 4.4 with a filter. I also check my dipstick after the oil change, and at every gas fill up. Something the OP didn't do. But thank you for being so concerned that I am not filling the motor I built, with the correct amount of oil.
![]() Note: I do not say putting 4.8 quarts in is a bad thing, many Subaru shops will put that in as the MAX fill capacity. This is key, MAX CAPACITY. It still boils down to him putting anywhere from .5-1 full quart OVER what is called for. With the design of our motors, this is not a good thing. But please, come educate me. ![]() Last edited by HinshawWRX; 12-09-2012 at 07:16 PM. |
#61 |
Member#: 279502
South East
Vehicle:2002 WRX PSM |
#62 |
Member#: 271207
BAIC
So i drained the oil and put the correct amount in and its still smoking (30 miles driven since oil change) :/
#63 |
Member#: 255776
MWSOC
Well...Time for a compression test...
#64 |
Member#: 311522
South East
Vehicle:2012 WRX Icy Silver Metallic |
Give the driving around a few more days, when you overfill your oil it gets everywhere. Its probably sitting in the intake and bends of the exhaust. Are you misfiring? Any sluggish behavior? Excessive fuel consumption?
#65 | |
Member#: 271207
BAIC
Compression and leak down is scheduled for Friday. YESSSS EXXESSIVE FUEL CONSUMPTION!!! ive noticed im getting like 50 miles per qtr tank (ALL city driving) ~18.5>19 MPG i usually get around 20-22 just city driving. no misfiring at all and i havent given it much throttle so idk about the sluggist |
#66 |
Member#: 340561
from the video the white smoke almost has a blueish tint to it.
hopefully you can figure it out and goodluck. |
#67 |
Member#: 291519
NESIC
Vehicle:2011 OBS Black |
Doesn't look like condensation to me. To much smoke that dissipates to quickly. I do see there is a little smoking after the start but condensation doesn't usually ramp down so quickly. I'd be looking at possible head gasket.
#68 | ||
n00b Moderator
MAIC
#69 |
Member#: 334146
NWIC
Vehicle:1999 Subaru Legacy 2000 Chevy Silverado 1500 |
My car smoked a good amount right when I would start it up, but after about ~10 seconds it goes away, it definitely caused me some worry, so I had it brought into the local Subaru mechanic over here, and after some snoopin' around, we found it to be a valve problem. He easily got it fixed and all is good now.
So, I don't know if this helps or not, but the smoke you have, looked very similar to the smoke I had. Valves were the problem on my car soooo.... Maybe it's the valves? (just a guess...) |
#70 |
Member#: 175565
MAIC
Vehicle:2005 STI CGM Built 351whp/368tq |
That was fun reading all 3 pages, why not take it to your local reputable Subaru tuner and have them diagnose it for you.
#71 |
Member#: 291519
NESIC
Fail to see where it has been determined to be anything yet.
#72 |
Member#: 269388
SCIC
update please!
I always thought my condensation was normal till i took off the intercooler and there was a bit of blow by |
#73 |
n00b Moderator
MAIC
Update was the guy overfilled the oil in the engine and ran it like that for over 300 miles. A "bit of blow by" in the intercooler is completely normal.
#74 | |
Member#: 271207
BAIC
Your help and the help of other NASIOC members was nice to have. Thank you all. |
#75 |
Member#: 324552
https://www.youtube.com/watch?v=hgUcfqBoebw here is a link to a video of what my subaru is doing.
Here is the story, I pulled to motor to change the clutch ( and get to the headers for lava wrap) I fixed my stuff and put the motor back together. When I would try to crank it, it would turn over, get to about 2k rpms and then cut off. I assumed there was a problem with the idle control valve and unplugged them, battery, and went through what I figured would reset the ecu's settings for the idle control valve. Well I was right. But now... it cranks up and idles really nasty and has tremendous amounts of smoke. here is a video of the first crank after I reset the idle control stuff. any ideas? (I would have posted this in a new thread but I am too noob to be allowed to.) |
