Old 01-22-2013, 02:04 AM   #1
chrisd87
Member#: 344446
2012 Wrx sti
Default 2010 Sti engine in 2008 wrx...Plug and play?
So I recently picked up a 2008 Wrx with a blown engine for peanuts (broken ringland seemed to put it out of service). I stripped the whole engine and I'm ready to buy a new shortblock and all the garnishing. It then struck me that for the same price I can buy a complete Wrx sti engine (I'm about to buy a 2010 smashed Sti...for peanuts). Now my question is; would the 08+ Wrx STI engine work plug and play in the 2008 wrx? Would a simple swap of engine and Ecu put it all to work? I believe the Sti doesn't have acvs cams but logically if i swapped out Ecu's I shouldn't have a problem. Is there anyone here than can confirm what would work/wouldn't?!
Chris
chrisd87 is offline   Reply With Quote
Old 01-22-2013, 02:40 AM   #2
Kinjirra
Member#: 258345
2013 WRX
Plasma Blue
Chris
Sounds interesting and If you did a complete swap I cant see it not working(complete as in full harness, dash etc etc etc). Otherwise I'm sure there will be some splicing and other fun stuff to deal with though not totally sure on that. Either way best of luck
Kinjirra is offline   Reply With Quote
Old 01-22-2013, 12:07 PM   #3
LUMBERZACK
Member#: 340009
2007 STi
48W
Might as well put the STi tranny in there too while you're at it.
LUMBERZACK is offline   Reply With Quote
Old 01-22-2013, 01:43 PM   #4
AWD Freak
Member#: 262593
Chris
That's cause 2008 and newer Sti's have dual avcs.
AWD Freak is online now   Reply With Quote
Old 01-23-2013, 09:27 PM   #5
roadtrip1098
Member#: 185688
2006 STi
WR Blue
The blocks are the same, the heads are different. A friend of mine had an 08 WRX that blew the motor and he replaced the short block with one from an STi, no wiring issues, no ecu swap. With the STi motor you're gaining a forged crank. As others mentioned though, you may want to use the STi transmission and other drivetrain components and at that point, you may as well do a complete swap (ecu and everything) and turn the WRX into an STi. Is the 08 by chance a sedan? The idea of an 08 STi sedan without the ridiculous fenders is kind of appealing.
roadtrip1098 is offline   Reply With Quote
Old 01-25-2013, 08:46 PM   #6
chrisd87
Member#: 344446
2012 Wrx sti
thanks for the replies, the car is a hatchback. Turns out I would be swapping only the engine from the Sti, which I was told involves swapping ecu's... which could cause some confusion due to BCM and TCM communication differences. I will most likely rebuild the Wrx engine inless I know for sure I can plug the Sti engine/harness into the wrx and simply re-tune ecu and maybe change up heads with the wrx to keep factory exhaust avcs gears.
Old 01-25-2013, 08:46 PM   #7
chrisd87
Member#: 344446
2012 Wrx sti
Dual= intake and exhaust?
Old 05-03-2014, 11:49 PM   #8
MiguelGL
Member#: 389844
Chris
Chris, I want to know if you do your swap cause I'm in the same situation like you. Want to drop an sti engine in a 2010 wrx.
thanks
MiguelGL is offline   Reply With Quote
Old 05-04-2014, 10:23 AM   #9
norexyet
Member#: 39149
11 elantra
yea i said elantra
Correct. Both intake and exhaust cams are avcs. As for the guy that said you gain a forged crank with an sti motor. That's not true. Both motors use the same one.
norexyet is online now   Reply With Quote
Old 05-04-2014, 11:20 AM   #10
chrisd87
Member#: 344446
2012 Wrx sti
I ended up building a shortblock and swapping out my damaged wrx heads for b25 sti heads, engine has been running strong ever since. The Sti swap can be done although you will have to swap everything over. Swap over an Ej257 shortblock and call it a day.
