Old 01-25-2013, 07:53 PM   #1
paN1k
Member#: 218607
2013 WRX
Ice Silver
Default Idle Questions
I was having some idle issues where if I was sitting in traffic and the radiator fan would kick in and raise the idle past 1k and it would fluctuate and return to normal after the fan kicked off. I cleaned the MAF sensor and the car not only gets better gas milage but when the fan kicks on it doesn't fluctuate as much, it will go to 1k for a few seconds and return to normal.
Is that normal for the idle to go up when the radiator fan kicks in? It's much better than what it was, just thought i'd ask.
paN1k is offline   Reply With Quote
Old 01-25-2013, 08:28 PM   #2
c130turboprop
Member#: 293873
2006 Subaru WRX STI
check your battery voltage and grounds... if battery doesnt have enough juice, the draw could put strain on the electrical system/alternator, and cause the motor to rev to get current flowing from the alternator. not saying this is the problem, jus something to check
c130turboprop is offline   Reply With Quote
Old 01-25-2013, 09:41 PM   #3
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
First off, was your a/c OR defroster running?
Old 01-26-2013, 12:40 AM   #4
paN1k
Member#: 218607
2013 WRX
Ice Silver
neither! thermostat was set to 75 but knob was set to off.
