Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 01-26-2013, 12:59 PM   #1501
Juicy2013WRX
Member#: 336351
2013 WRX LIMITED
Dark Gray Metallic
I would like to go to a larger wheel and tie combo on 2013 wrx hatch. 245 or 255 / 40/ 18 x 9 or 9.5. With an offset of + 40 to +53. Do not want to roll the fenders. Will there be rubbing issues?
Juicy2013WRX is offline   Reply With Quote
Old 01-26-2013, 01:22 PM   #1502
Mach V Dan
Member#: 12029
Please edit your post to not include the Wall of Quote.
The answer to your question is yes. If the offset is on the lower end (+40), and the tire is a 255/40R18, it might rub. 255/35R18 would be safer.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 01-26-2013, 02:38 PM   #1503
Juicy2013WRX
Member#: 336351
2013 WRX LIMITED
Dark Gray Metallic
--Dan
Mach V
Thanks for the response. I'm looking to go slightly larger, without rubbing. 245/40/18 closer to a +53 offset would be safer?
Old 01-28-2013, 04:29 PM   #1504
Speeddemon420
Member#: 334964
2013 WRX
I have done a lot of reading in this thread and am still not sure what tire size I should go with. I have a set of gramlight 57D's - 18 x 9.5 +38.
I want to put a set of Michelin SuperSports on these. I was thinking 265/35/18 or 275/35/18. For both of these I will need to roll my fenders right?
Speeddemon420 is offline   Reply With Quote
Old 01-28-2013, 04:35 PM   #1505
J_Maher_WRX
Member#: 290307
The Super Sports run VERY wide. The 255's on those are square on 9.5" wheels. You definitely don't need to go any bigger. You will need to roll the rear fenders, though not much.
J_Maher_WRX is offline   Reply With Quote
Old 01-28-2013, 05:13 PM   #1506
Speeddemon420
Member#: 334964
2013 WRX
Thanks for the advice. Would I be able to run a 255/40/18 with the stock suspension and the rear fenders rolled?
Old 01-28-2013, 06:10 PM   #1507
J_Maher_WRX
Member#: 290307
Definitely don't want to run 255/40's, that's an extremely tall tire over 26" diameter. Stock WRX tire is 25.3" diameter, while stock STi is 25.7" diameter. Due to the WRX's taller gearing, going with a slightly shorter tire like the 255/35 (25") will help gearing. And the STi in turn will benefit from a slightly taller tire as it has fairly short gearing. So if you have an STi, the size you mentioned would work fine. If you own a WRX, you want the 255/35s.
If you do go with the taller tire though, you will def need to get more aggressive with the rolling, and potentially even have to roll the fronts though I'm not sure on that one.
Old 01-29-2013, 10:10 PM   #1508
Mach V Dan
Member#: 12029
That would easily fit, since that's the OEM STI tire size and offset.
--Dan
Mach V
FastWRX.com
Old 01-30-2013, 07:55 AM   #1509
zolaman
Member#: 299059
12 WRX hatchback
People here needs to read this entire post before asking a question. I read from pages 1-56 and it helped me choose the wheel/tire spec for my needs. Most answers are already here...just saying.
zolaman is offline   Reply With Quote
Old 01-30-2013, 11:21 AM   #1510
Juicy2013WRX
Member#: 336351
2013 WRX LIMITED
Dark Gray Metallic
--Dan
Mach V
FastWRX.com
Thank you very much Dan.
Old 01-30-2013, 12:26 PM   #1511
mosc
Member#: 177401
2015 STi White
Dave, how much strut clearance does this platform have? OZ makes the Ultraleggera in 18x9" +55 (clears brembos). Theoretically that gives a lot of fender clearance for 265 or even 275 but that's a whole lot closer to the strut than stock. Thoughts?
mosc is offline   Reply With Quote
Old 01-30-2013, 03:20 PM   #1512
Ultimateone
Member#: 48025
15 Mustang GT
What would you guys recommend for a wide 255/35/18" tire? decent pricing
Ultimateone is offline   Reply With Quote
Old 01-30-2013, 04:19 PM   #1513
NWsoobie
Member#: 289516
2012 WRX
ISM
Take it to PMs.
NWsoobie is offline   Reply With Quote
Old 01-30-2013, 04:54 PM   #1514
xing1399
Member#: 345426
love the fitment on these rotas
xing1399 is offline   Reply With Quote
Old 01-30-2013, 06:02 PM   #1515
zergling
Member#: 195573
2012 WRX
--Dan
Mach V
FastWRX.com
Conti DWS, 275/35R18.
Swift springs.
Yes.
--Dan
Mach V
FastWRX.com
Thanks to Dan's post on his Rota D-Force thread, I now have a(nother?) very useful data point as far as fitting Conti DWS tires (which I happen to currently run year-round).
- 275mm at +40 offset clears on swift springs and rolled rear fenders. (97.5mm of tire after the hub)
- Swift springs for 08+ STi's are 252 lbs/in front and 235 lbs/in rear and drops 0.8"
- In comparison, RCE "regular guy" black springs are a little stiffer at 275 front 250 rear, (275/250) are slightly stiffer than swifts (252/235), so that makes things slightly even better
- Since I want to run "only" 255/35/18 or 255/40/17 of the same tire, I can in theory go with an offset as low as +30.5 and still be ok. Though I think I'll stick to +35 to +42
zergling is offline   Reply With Quote
Old 01-30-2013, 07:43 PM   #1516
NWsoobie
Member#: 289516
2012 WRX
ISM
Originally Posted by NWsoobie View Post
Take it to PMs.
Sorry. I meant to and brain pooped it.
Old 02-03-2013, 11:40 PM   #1517
b0yt0y
Member#: 334294
2013 WRX Sedan
WR Blue
Hi guys! I just got my 2013 wrx a month ago and I'm still new in this kind of stuff. Would a 18x9 +40 wheels and 265/35 R18 tires work on my 2013 wrx sedan? Will there be issues? Would it look nice on the car? I'm not planning to drop the car for now, so that means no rolling right?
Thanks in advance
b0yt0y is offline   Reply With Quote
Old 02-03-2013, 11:50 PM   #1518
J_Maher_WRX
Member#: 290307
Thanks in advance
Read the first page of this thread.... Lol in short, yes, no, your opinion, yes...
Old 02-04-2013, 12:38 AM   #1519
mcuzzin
Member#: 292732
2007 FXT
SGM
Any recommendations on rear camber setup?
I am currently lowered on fortune auto coils and have no rear camber adjustment. I am maxed at -2.5* on stock wheels/tires. When I go to a 17x9 +30 or 18x9.5 +38 with either 255 or 265 tire, will there be a need for more camber? (+rolling rears of course.)
mcuzzin is offline   Reply With Quote
Old 02-04-2013, 10:33 AM   #1520
b0yt0y
Member#: 334294
2013 WRX Sedan
WR Blue
Thanks for the reply
Yes sir! I did read the first page and other pages, but all i see there is 18x9.5 and I'm just aiming for a 18x9. If I'm fitting on 18x9.5 I wouldn't be asking this question. Since I don't know if everything will work fine on a 18x9 +40 - 265/35R18 without dropping it, thats why I asked people here.
Thanks again
Old 02-04-2013, 10:45 AM   #1521
Nawratil
Member#: 306659
2012 Impreza WRX
Obsidean Black Pearl
It is thinner so it will fit even easier than the 18x9.5
Nawratil is offline   Reply With Quote
Old 02-04-2013, 01:39 PM   #1522
sc00by4life
Member#: 97135
Thanks again
this is why you need to learn how to use offset calculators to calculate comparable fitments with different size wheels...
use some common sense.
Old 02-04-2013, 02:13 PM   #1523
J_Maher_WRX
Member#: 290307
Thanks again
Think about it, if a 18x9.5 will fit fine, a half inch smaller width wheel with the same size tire and offsets will obviously fit fine.. It'll have even more clearance
Old 02-05-2013, 09:55 PM   #1524
Cathartic
Member#: 336202
Default PSS on Work XT7's
Firstly, my thanks to everyone who has posted all of the fantastic info in this thread. It has been extremely helpful to me (though I definitely still have lots to learn).
I've been looking at the Work Emotion XT7's in the 18x8.5 +46 5x100 size for my 2013 WRX hatch (stock suspension). Unfortunately, they don't seem to come in 9.5 with the 5x100 bolt pattern, so I'm limited to 8.5 if I want these wheels. From what I have learned in this thread, that size should be perfect for my needs anyway, and avoid the need for fender manipulation (not that I'm opposed to rolling - I just think 245's or 255's on the higher offset wheels will meet my current needs and won't happen to require the roll).
So, my question... I would like to go with Michelin Pilot Super Sport tires and have been reading in several places that they run quite wide. Given this, I have to imagine that the PSS in 255/35/18 would be way too wide for the 8.5's. But what about 245/35/18? Do they run so wide that even the 245's would be too wide for the 8.5 wheels? I know that stock STI's are 245's on 8.5's, so under normal circumstances, the fitment should be fine - I just don't know how abnormally wide the PSS's are.
If the 245's will fit well, then I think going with Sc00by4life's favorite size of 245/35/18 might be the way to go. Otherwise, I'll need to consider other tire/wheel choices.
Any thoughts/feedback would be appreciated!
Cathartic is offline   Reply With Quote
Old 02-05-2013, 11:06 PM   #1525
J_Maher_WRX
Member#: 290307
Well I personally said **** it I'm going to run 255/35s on my 8.75" width wheel, even though it has a tread width of 9.5". The 245 you are referring to has a tread width of 9". Here is a link to a 2011 wrx with 18x8.5" wheels and 245/40/18 PSS:
http://www.clubwrx.net/forums/suspen...rx-2011-a.html
As you can see, it doesn't appear to bulge too dramatically, and you clearly are benefiting from the wider tread. For comparison, a 255 PSS had 9.5" tread while a 255 Hankook v12 Evo has only 8.7"!! Almost a full inch of difference between tread width, which is clearly substantial. So like I said I'm going to run 255's on my 8.75" wide wheels, it should bulge only ever so slightly than the car in the above link, which I don't think will be too bad. I like the meaty look anyways as long as it is proper fitment
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
