Welcome to the North American Subaru Impreza Owners Club Thursday February 11, 2016
Old 05-23-2012, 02:42 PM   #1
ColeBerkenbile
Member#: 316278
2010 WRX Sedan
Default Removing BlueConnect
has anyone with factory installed blueconnect taken theirs out? Im trying to get the parts together to uninstall it as theres no bottom to the cavity to even set a mat on. Im wondering if this is normal? thanks
ColeBerkenbile is offline   Reply With Quote
Old 05-24-2012, 03:30 PM   #2
iRonin
Member#: 267774
2010 WRX
Electric Boogaloo Blue
No, the cavity should have been in there. It should've been resting on the bottom of it. The grip mat that goes in there should have been removed, but that should have been it.
Last edited by iRonin; 05-24-2012 at 03:31 PM. Reason: hrm, reread, changed answer
iRonin is offline   Reply With Quote
Old 01-26-2013, 03:42 PM   #3
bradze
Member#: 103208
2011 Outback
Azurite Blue
i know this is old but i have an '11 outback and am taking out my blueconnect. does the black wire that goes into the blueconnect go to the microphone? some kid wants to buy it for his mom's legacy and im assuming that same harness i disconnected is in that car as well. im really hoping all i have to do is move a few panels to get that mic out. anyone know?
bradze is offline   Reply With Quote
Old 01-27-2013, 03:42 PM   #4
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
See Subaru's installation instructions so you can reverse the procedure and ensure that you include all of the parts and harnesses the kit came with. Link:
http://techinfo.subaru.com/search/index.html
(select Publication Type "Accessory Installation Guide" and optionally filter by your model/year and/or keyword such as "BlueConnect" or "Blue Connect" -- there are different guides listed both ways ).
The kit includes a T-harness that taps power from the factory radio harness. You must unplug that T-harness from your car and include it with the control module and mic -- the other car won't have those.
SVXdc is offline   Reply With Quote
Old 01-27-2013, 04:48 PM   #5
bradze
Member#: 103208
2011 Outback
Azurite Blue
just the fact that the microphone is screwed down is enough to make me not want to do this. its not worth my time. giving most of the parts i dont need to my friend so he can put it in his wrx.
Removing Rear Window Trim LTM87 Interior & Exterior Modification 7 05-22-2015 02:33 AM
Blueconnect+Footwell Illumination Install Question aaronn Car Audio, Video & Security 2 08-28-2012 09:58 PM
BlueConnect now available on Impreza and Forester rsholland News & Rumors 11 02-25-2010 03:14 PM
Best rust removal/ remover?? Cusco Service & Maintenance 3 05-21-2003 04:14 AM
removing defi pod -- broken tabs, how do you remove whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-23-2003 02:49 AM
