#26 |
Member#: 259184
MWSOC
Vehicle:2008 Subaru WRX Silver |
I have this and i sorta fixed it? i guess. I took off the extra trim piece (aka splitter) cause its attached to the rubber with plastic bolts. i could get some pics if you want. just message me.
#27 | |
Member#: 292246
International
Vehicle:2011 Diamond in the Dust |
I looked at the splitter and removing it is simple, but this is going to compromise the effectiveness of the tmic. I'm guessing the SPT part doesn't require this mod? |
#28 |
Member#: 259184
MWSOC
Here are some pics.
#29 |
Member#: 339148
Tri-State
Vehicle:2011 WRX Sedan Silver |
So Mr. Wrex, how did the fitment turn out with the Cusco, Process West, and metal splitter? I am getting a PW TMIC with the metal splitter and I am worried that it will make contact with my Cusco.
#30 |
Member#: 326861
SCIC
Vehicle:2010 wrx wrb |
how close are you? I have the same cusco bar and when i close my good the back plastic tab on my scoop barely makes it inbetween my avo TMIC and the bar, i would just loosen everything and just try to push the bar back a little further
#31 |
Member#: 117796
MAIC
Vehicle:2011 sti obp |
sad to see that the post which stated to most useful information was ignored. these bars do absolutely nothing for our cars except add curb weight, and reduce wallet weight. if you are having fitment problems then take it off, problem solved.
#32 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2007 Lotus Elise (From General) |
FMIC and scoopless hood.
Problem solved. My WRX had the scoopless hood and FMIC along with a tein front strut bar when I bought it. I've since removed the bar and sold it to help fund new wheels. I think this is a good option for you too. You would like new wheels, right? |
#33 |
Member#: 339148
Tri-State
IDK people knocking the front strut bar, I understand if that is the ONLY brace you have. Then surely it is useless. But in my case, I have Whiteline sways, KB end links, Bilsteins and Yellow Springs, and an assortment of bushings, pitch stop, etc. I feel like when I added the front strut brace it reinforced all the bracing I had done under the car, from up top. The car tracked a little better and it was more responsive to steering wheel input. That being said, I have noticed a larger need for a rear strut bar, as the back has become noticeably laggy.
#34 | |
Member#: 332887
Tri-State
Vehicle:2012 WRX stage 2+ DGM (sedan) |
#35 | |
Member#: 117796
MAIC
TIC (best in the business as far as suspension goes in most of the members' opinions around here) and quite a few others hold this opinion as i was interested in this mod and was told repeated testing and use had yielded no true performance gain. You have also been given the same advice by people with years of racing experience/instructing on this forum. cough...jack...cough All that being said, it's a relatively cheap mod that looks pretty when you open your hood. We all know that cheap mods are hard to find when it comes to these cars, and who doesnt like a little engine bay bling. If it makes you feel like the car is more responsive by all means, confidence is half the battle right. Once i have done the other suspension work i want, (i have a nice long list from TIC, of which they removed half of the original parts i inquired about, citing that they were not needed and had no documentable performance gain) i will probably throw one on when i turn in my water jug full of change for some cash. Like i said who doesnt like a little bling under the hood. |
#36 |
Member#: 339148
Tri-State
Bling bling, every time I come around yo city
Bling bling, pinky ring worth about fifty Bling bling, every time I buy a new ride Bling bling, Lorinsers on Yokohama tires, bling bling |
| Thread Tools | |
| Display Modes | |
| FS : 02-07 WRX/STi Cusco Front Strut bar & STi 26mm Whiteline front sway bar | 04jaxwrex | Suspension/Brakes/Handling | 4 | 03-08-2012 01:52 PM |
| 02 07 cusco front strut bar rear wagon strut bar | refuse | SCIC Private Classifieds | 3 | 09-05-2009 04:51 AM |
| wrx cusco front strut bar, ebay strut bar and new ebay H brace | ubi_scoobi | SCIC Private Classifieds | 12 | 07-26-2009 12:19 AM |
| FS:(socal) wrx 02-07 cusco front strut bar, ebay rear strut bar & new ebay H brace | ubi_scoobi | Suspension/Brakes/Handling | 1 | 07-23-2009 03:27 AM |
| Intercooler that will clear cusco front strut bar? | NYCshopper | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 11-04-2002 02:42 PM |
