Old 01-24-2013, 12:11 PM   #1
stikilla
Member#: 117796
2006 Corvette
white
Default USB Port trouble
Good morning all,
I drive a 2011 sti hatchback for reference. I recently purchased an iphone 5 and when I plug the charger into the USB port inside the armrest it does not seem to be charging or having any interface whatsoever. I was wondering if anyone else has run across this problem. Could very well be user error on my part. Thanks for the info.
stikilla is offline   Reply With Quote
Old 01-24-2013, 12:19 PM   #2
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
Originally Posted by stikilla View Post
Good morning all,
You have to switch the radio over to usb to be able to draw power from the hub. Just get a y-adapter and plug it into your cigarette lighter.
Schikane is offline   Reply With Quote
Old 01-24-2013, 12:21 PM   #3
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
I'd wager that it would charge an iPhone 4/4s, and just can't charge the 5. On my 08, the stock radio wouldn't charge 'newer' nano's that I use for music, but did work with the generation 1 Nano. It would play the newer ones, just not charge them... I'd wager that's what is going on with you.
That all being said, the stock radio is horrible, and the 'weak link' in the car's audio. If you get a replacement headunit, newer, it should support your iPhone 5. Just be sure to get a signal to noise ratio of > 92 or the new radio will sound as crappy as the stock one.
Hope this helps!
Napalm3nema is offline   Reply With Quote
Old 01-24-2013, 12:21 PM   #4
stikilla
Member#: 117796
2006 Corvette
white
User error as expected. Haha. Thank you for the response. I figured I'd just get a usb port that plugs into the lighter.
Old 01-24-2013, 12:22 PM   #5
04shizzel
Member#: 186206
16 sti
CWP
Have you put the radio on the usb setting, and turned off bluetooth?
If your bluetooth is active the usb will not work. hopefully yhis will be helpful.
04shizzel is offline   Reply With Quote
Old 01-24-2013, 12:34 PM   #6
LUMBERZACK
Member#: 340009
2007 STi
48W
I don't know what I would rather have, the AUX port that my 07 came with or a USB in it's place. Hmmm.
LUMBERZACK is offline   Reply With Quote
Old 01-24-2013, 12:35 PM   #7
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
In my case it wouldn't charge no matter what. Could be different with his 11 however. <shrug>
Academic now for me. I tossed the stock headunit and the aftermarket charges, and the car now has a decent sounding stereo. I'd say an 80% improvement over stock. (that's with stock everything, and just replacing the head unit)
P.S. If this IS the fix for him, doesn't that mean he can't listen to the radio and charge his phone at the same time? That seems rather fail-like to me?
Old 01-24-2013, 12:40 PM   #8
stikilla
Member#: 117796
2006 Corvette
white
yeah that is a crappy situation. but in a pinch if i needed the juice then whatever. My hope is that it will interface and i can just listen to a playlist or 2 while it charges. ill be figuring it out after work today.
Old 01-24-2013, 12:54 PM   #9
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
1050 Triumph Speed Triple
This. I had the same problem on '13 Crosstrek XV. Brand new car and USB wouldn't work. I was pissed off.
But, yes. If you flip it to the USB mode on the radio, the USB port will have power and then you can go back to radio, bluetooth, whatever.
No, you just need to flip it to USB once, then the port is turned on. After that, you can go back to whatever else.
Old 01-24-2013, 06:39 PM   #10
WRX boarder
Member#: 328399
2012 WRX Limited
My experience has been this only happens with the iphones. My usb will charge all my other accessories without going into the usb mode.
WRX boarder is offline   Reply With Quote
Old 01-24-2013, 09:29 PM   #11
Schikane
Member#: 337700
2013 WRX
Ice Silver Metallic
I have the 3S and it was a no-go for me as well.
Old 01-24-2013, 09:39 PM   #12
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
This^
Plug phone to USB, switch head unit to USB, verify phone is charging, change head unit to whatever I want to listen to. Phone stays charging.
I just wish that you could use the iphone touchscreen while in USB mode. Hate using the stock non navi radio to sort through 100s of artists to find the one I want to listen to.
That's why I would plug in my phone, switch to USB and quickly change it to Bluetooth. This let me charge my phone and still use the phone to select songs. Pain in the ass but it worked.
That always worked with my iphone 4, have not tried with my 5 yet.
Old 01-24-2013, 09:44 PM   #13
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
USB port does not charge my iphone 4S...doesn't matter what I have the stereo set to. And I don't remember the manual saying the USB port would charge a device, but I'm not totally sure and only tried with my iphone.
garzdos is offline   Reply With Quote
Old 01-24-2013, 10:39 PM   #14
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
I also have an iPhone 4S. If its not working for you, my guess is that you have a faulty USB port.
Old 01-24-2013, 11:08 PM   #15
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
So if you plug your iphone 4s directly into the USB port in the console it charges your phone? No matter the settings on your stereo?
Old 01-24-2013, 11:12 PM   #16
JJL91
Member#: 320380
2012 wrx
rally blue
You must put it on USB first. It will then activate the USB function and charge your phone. Once that happens you can switch your stereo to any other function ( cd, fm and am) and your phone will continue to charge.
JJL91 is offline   Reply With Quote
Old 01-25-2013, 03:20 AM   #17
garzdos
Member#: 333423
2012 WRX Hatch
Dark Gray Metallic
That was it! I've always used the bluetooth connection for music and stuff so I never even used the USB function...
But tell me this, is there some advantage to using the USB connection with my iphone versus the bluetooth connection, other than ability to charge? Am I missing something?
Old 01-25-2013, 07:14 AM   #18
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,12
I use the USB port to charge because its out of the way compared to the cig lighter. But I use BT for the music playing.
To each their own. I think the USB port would be more for if you had a USB drive with all music. The equivalent of a road trip mix tape. "Hey guys, check out this mix tape!!"
Old 01-25-2013, 02:35 PM   #19
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
Hopefully this will help some of you understand as to why your various iDevices may not work as expected in your cars. I have a 2008 WRX with the factory iPod (30 pin) dock and this is what I've found out.
It will not charge an iPhone4 in the stock configuration. The reason for this is because the 2008 factory 30 pin connector is wired to use the firewire pins to charge the device. Apple moved away from this in 2008-ish. I have a 5th Gen iPod Nano that also does not charge in the car. You can fix this by getting an adapter that remaps these pins. I have one of
thesethese
and it works for both my iPhone4 and my iPod Nano.
My 2008 WRX will also not control, or play any content from, my iPhone5 (using a 30 pin to lightning adapter), but it will charge so long as I'm using the adapter linked above. I actually emailed SOA about this and they said that the iPhone5 will not be supported in my car, ever. The reason for this is due to the way the head unit interfaces with the device. When Apple launched the new dock connector and various adapters for it they had to make a choice of which legacy technologies they were going to continue to support. I believe that in the 2008 WRX head unit, Subaru is using Apple's Legacy iPod Out protocol to control the device. I'm calling this legacy because Apple no longer supports that protocol over Lightning. I actually have access to the tools to confirm all of this (I'm an infotainment engineer at an OEM), but I'm lazy, its cold outside, and there is enough evidence in the reply I got back from SOA combined with a bit of google sluething around what works and doesn't work with Lightning to figure all of this out.
I've chosen to focus my time on finding an aftermarket solution that will fit my needs. I talked to some engineers at Apple (the real engineers, not the "geniuses" at the Apple store) and they've noted that in the aftermarket space, head units from Pioneer and Alpine seem to work the best. They also noted to stay away from the App Radio models in the aftermarket space due to the same sort of compatibility issues that my 08 head unit is currently experiencing.
I realize that most of this isn't terribly relevant to those of you with newer vehicles, but it isn't something I've seen discussed before. Hopefully it will provide some search fodder for people in the future.
bigmaninjapan is offline   Reply With Quote
Old 01-26-2013, 05:23 PM   #20
Wilsmick
Member#: 344969
2013 WRX
It's definitely not just limited to older vehicles. I just bought a 2013 WRX and I'm having the same issues every here is describing. Replacing the stock HU seems like my most likely path forward.
Wilsmick is offline   Reply With Quote
Old 03-12-2013, 09:50 AM   #21
wayfasterthanyou
Member#: 303801
07 STI Stg2
Pearl White
----/ a.aA
AA
A
A
A
A
A
AA
A
A
AA
A
A
A
A
A
A
A
A
A
wayfasterthanyou is offline   Reply With Quote
Old 03-12-2013, 06:58 PM   #22
tKbox
Member#: 340490
2013 WRX Sedan
I've been able to charge my EVO LTE through the USB port since day 1. I don't even have to have the HU on and I can use Bluetooth at the same time. Maybe it's something they fixed?
tKbox is offline   Reply With Quote
Old 03-14-2013, 03:18 PM   #23
bina12834
Member#: 349481
2013 XV Crosstrek
i have the XV Crosstrek and i think (ill have to confirm) that when i plug my iphone 5 into the usb port it automatically changes over to that source.
bina12834 is offline   Reply With Quote
Old 03-15-2013, 11:26 AM   #24
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2005 Forester 2.5XS
Upgrade to iOS 6.1 or later. Apple removed this restriction. Works great on my iPhone4.
Old 03-15-2013, 01:43 PM   #25
jerz_subbie
Member#: 221589
2013 WRX hatch
Nice to know thanks. One more reason to download 6.1.2... I'm always just worried about bugs like the map and security things.
jerz_subbie is offline   Reply With Quote
